Question about HP Office Equipment & Supplies
I am unable to print any documents ... this has been since yesterday. I have unplugged the printer and replugged, closed down the computer and restarted ... cleared all the excess printing jobs ... now what?
  • 190 Answers
Dear customer,
First, check the software by updating your printer drivers.
To go there, Right-click My Computer --> Properties --> click hardware tab --> click device manager --> click on Ports --> double click on printer port.
Now check to see if the status window says it's working probably. You can click on the driver tab to update the driver.
Secondly, it could be a hardware problem. Did you replace the ink with a new Brother cartridge or a refilled one?
If all else fails, do contact Brother directly for technical assistance.
Posted on Jul 09, 2008
  • Ajith Kumar Jul 10, 2008
    Please Rate the Solution.. Thank You..
Hi I have a Lexmark S405 from yesterday it has stopped copying documents, the scanner works perfectly and the printer seems to be working however when I put a document in to copy it either prints me out a...
Try to reset the printer. Unplug the power adapter from the printer. printmastert_38.jpg
Wait at least 10 seconds before replugging the power adapter into the printer. When the printer completely boots up, try to make a copy a again. If problem continues where it is partially printing copies or having print quality issues, you may need to update the printer's firmware. Firmware update for the S405 is available at http://bit.ly/s405fw.
Apr 12, 2011 | Lexmark Interpret S405 Wireless All-in-One...
How to stop a printing job
Hello.
Just press on "Printers And Faxes" in "Control Panel" and double click the printer you use.
Locate and press "Printer" on menu toolbar in this new window and then "Cancel All Documents".
If this procedure is taking too long, shut down your computer and unplug your printer, then restart computer, replug printer. Try to "Cancel All Documents" again
Good Luck
Jan 25, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
An incorrect document was sent to the printer. The printer continues to try and print the documents and will not stop. Is there a way to "erase" the memory of documents in the printer "queue"?
Hello.
Of course there are. Just press on "Printers And Faxes" in "Control Panel" and double click the printer you use.
Good Luck
Jan 25, 2010 | Lexmark Forms Printer 2381 plus Matrix
I am unable to print a document. I "tell" the printer to print, it goes through the 1st step, then a message comes up saying "jobs stopped". I select utilities, I am asked to "select printer from list". No...
Under the cover , on the right side there is a tinny stick of plastic that pushes a switch when you close the cover. put a small piece of paper to assure that the stick prees the switch when you close the cover. Try and good success.
Oct 27, 2009 | HP DeskJet 932c InkJet Printer
I am unable to print documents from computer. I
There is a switch on the right and the cover press it when it closes.Put a small paper to help the cover small plastic stick on the right to keep the switch pressed. Then you will print normally
Oct 26, 2009 | HP PhotoSmart 7960 InkJet Printer
My Brother HL2940 will not go on to a new print order but tries to repeat a long document I printed yesterday. I unplugged/replugged and even removed the print icon containing the print information from my...
Switching off the printer should have cleared the print job. Don't know what version of windows you have so instructions vary slightly but you need to go into Control Panel, Printers and double click on your printer. This will show the jobs waiting in the print queue. You can right click the print job and select Cancel. Should clear it. If it doesn't let me know and we can go into the printer spool folder and delete it from there.
Sep 01, 2009 | Computers & Internet
Can't print documents
I fiddled around with the Owner/Administrator commands and discovered that one of my grandchildren logged on with "different user" and my computer was not set for that user to have access to the printer. Duh!
Jan 03, 2009 | HP PSC 1210 All-In-One InkJet Printer
Print unable 51
Problem with purge station or encoder strip and/or disc defective.
Needs replacement.
Jan 15, 2008 | Brother DCP 130C All-In-One InkJet Printer
Lekmark x9350
Try first doing a thorough clean of all printheads, cartridges too, then unplug all usb and power cords after turnig off. replug all and try again. I f no better, uninstall and reinstall printer.
Aug 12, 2007 | Lexmark X9350 All-In-One InkJet Printer
Seeker5211
Seeker5211
