Question about Acer Aspire TimelineX 5820T-5951 Notebook
Using HDMI cable (tried several) appears 'No signal' on the monitor (tried several). VGA connection works fine and BenQ (HDMI) icon appears in the device menu. According to Windows all drivers are up to date.
I am having this problem too. Did you ever find a solution?
Posted on May 07, 2011
I am receiving a CABLE NOT CONNECTED error when I connect my vga monitor to my laptop using an VGA to HDMI cable
If you actually have a cable with HDMI on one end and VGA on the other, it will probably not work. HDMI uses a digital signal and VGA uses an Analog signal, there needs to be some circuitry somewhere that handles the conversion. You are probably getting Cable Not Connected because the monitor is scanning for an Analog signal and not recognising the digital signal coming in over the VGA port.
Get a HDMI to VGA converter
Jan 22, 2017 | Vga Computers & Internet
Monitor vga connection hdmi
You can check these:
1. Connection: Make sure that both ends are connected properly,
2. Monitor: Most newer monitor has 3 options: VGA or DVI or Automatic. Test the "Automatic" and "VGA" options.
3. Cycle your display option using your laptop keyboard (Alt + F4). Please tap the F4 several times (to change the option to Mirror, Laptop Display only, External Monitor only)
Dec 25, 2013 | Packard Bell iMedia Computers & Internet
I run a PC with the newest sandy bridge hardware and a Msi GTx 560 Twin Frozr II video card (dual Dvi-I input and a mini-hdmi input). I also have a BenQ G2222 monitor (one VGA input and one DVI-D input),...
The problem might be with your ram. Try taking it out and putting it back in. You might also have a problem with the video card. Make sure it is secure and screwed in.
Mar 19, 2011 | Computers & Internet
My DVI has no signal but my VGA does! what do i do? Please help me!!!
Your HP2009M monitor supports (3) methods of accepting signals from a computer. They are: 1) VGA, 2) DVI and, 3) HDMI.
You would connect the computer to the monitor using one connection only. Generally the VGA is the least desirable as it is an analog signal. The DVI and HDMI method provide digital paths into the monitor and often perform better. Your computer may only offer 1 or 2 connection choices, so you'll have to choose a cable type that is supported by both the computer and the monitor. The HDMI choice will pass audio signals to the the speakers in the monitor without needing to run a second cable between the stereo audio jack of the computer and the audio input jack of the monitor (located next to the HDMI jack) or to a set of external speakers (unless of course you prefer the external speakers).
The message you're seeing is normal. Once the monitor is connected to your computer, there will only be one active selection; VGA, DVI or HDMI. Since you're using the analog VGA jacks and cable, it is expected that you'll see a message that there is no signal present on the DVI (and HDMI) inputs when attempting to view signals on other inputs.
I hope this helps and good luck! Please rate my reply, thank you.
Feb 26, 2011 | HP 2009M Monitor
When i connect the hdmi lead to monitor from my pc the sound does not work but when the vga cable is connected it works fine is there a solution to this problem
This could be a bios setting to say what sound device is active when you use HDMI. If it's trying to send the audio signal through the HDMI cable, you'll need to have a way to handle that signal on the monitor.
Feb 26, 2011 | Computers & Internet
How do you connect LG W2261 VP Monitor to HP Pavilion 6310uk Desktop
The computer has VGA, DVI-I (dual link) and HDMI ports. The monitor has VGA, DVI and HDMI but only came with a VGA cable. Some computers have recently come with shielding covering all of the ports except the one that is currently live. Thus, check your hardware; the computers I've seen with only one active port, the HDMI port was active before resetting the video options. So get an HDMI cable (it will provide the best signal in addition). If the DVI-I port is currently live, you should get that cable as well and then change the settings to enable the HDMI port.
I hope this helps.
(you do not need to get the super-expensive cables; the low end ones will be fine. However a single link DVI cable is not the same as a dual link cable; sometimes using the wrong cable leads to no signal to the monitor.)
Oct 12, 2010 | LG W2261V 22" LCD Monitor
LG W2361V 23 Vga to HDMI Cable Not Working
You have a cable problem as no such thing as a VGA to HDMI cable exists.
HDMI is a didital signal and is thus not compatable with an anolog VGA signal. HDMI to DVI cables however do exist as both are digital signals.
Hope this helps.
May 28, 2010 | LG W2361V-PF 23 in. Widescreen LCD Monitor
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
No Display from new Acer Desktop AX1700
check all power cable. check vga cable,
Jan 26, 2009 | Computers & Internet
Acer Aspire TimelineX 5820T-5951 Notebook Logo
219 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
