Question about ViewSonic VX2235WM Monitor
I have a two year old mac mini plugged into a ViewSonic VP201b monitor. The color on my monitor has been changing and getting progressively worse. Lately there have been times when it is almost sepia color. Help! Please make the answer simple because although I use my computer daily for work, I'm not at all good with maintenance, etc. Many thanks, k.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
your monitor, is failing your unit has a 3 year warranty, so contact http://ftp.viewsonic.com/index.htm
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 03, 2011
  • 731 Answers
Make sure the cable from the monitor to the machine is plugged in securely and thethumbscrews are tight. Check both ends!!
Viewsonic vp201b pink tint on screen
That sounds like possibly a bad cable or a bad video card. Do you have another cable you can try?
Dec 01, 2012 | ViewSonic VP201b 20.1" LCD Monitor
How to degauss viewsonic vp201b lcd
You do not degauss LCD monitor, it does not use electron beams (affected by magnetic field, if the showdow mask is magnetized, it can mees up color display) for making pictures like LCD.
You only degauss CRT type monitor.
http://en.wikipedia.org/wiki/Degaussing
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 04, 2011 | ViewSonic VP201b 20.1" LCD Monitor
ViewSonic VP201b with a black screen
hramirez, Retevo. com says time to retire this old monitor. Its that or you will need to do some extensive reading here on fixya on how and what to look for inside the unit that could be causing your black screen condition!!! Then you will go to YOUTUBE and view some of the many video clips that deal with "lcd monitor repair" and lcd monitor disassembly". Have you noticed any bad, swollen top, elcetrolytic filter capacitors on the units "switch-mode-power-supply/CCFL inverter printed circuit board?? How about any "cold" frosty looking solder joints around the component leads of the power transistors and ferrite inverter transformers? May need to get large magnifying glass to find those pesky little cold solder joints. 12fixlouie
Jul 26, 2010 | ViewSonic VP201b 20.1" LCD Monitor
Vp201b wont turn on
Checkto see if you do have 12vdc output from the power supply module as shown in my pictures: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VP201B/
Look for bad caps (leaking/bulging tops).
May 19, 2010 | ViewSonic VP201b 20.1" LCD Monitor
Display flickers than scrambles.
Most likely loose connection at PC. Check that monitor connector pins are not bent. Ensure that he monitor plug screws are screwed into the connector to prevent plug movement, at the PC and in the case of some monitors, also at the back of the monitor. If this does not correct the problem, there is probably a fracture in one of the solder joints on the VGA board at the connector.
Mar 19, 2010 | ViewSonic VP201b 20.1" LCD Monitor
Monitor distorting in screen halves after warmup
It probably isn't worth repairing as the cost will exceed what you would spend on replacing it.
Sep 11, 2009 | ViewSonic VP201b 20.1" LCD Monitor
Display on mac mini only shows no signal and turns black
his step-by-step guide describers how to obtain and install ViewSonic VA720 drivers for Mac.
1. Define your ViewSonic Monitor device model.
2. Define your operating system to install your ViewSonic Monitor device. Note: Update Drivers in Mac
3. Browse Monitor Drivers.
4. Find ViewSonic Monitor Drivers.
5. Select ViewSonic VA720.
6. Download ViewSonic VA720. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install ViewSonic VA720.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
May 03, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
My monitor changes colors
CRT monitors can last way past 4 years if taken care of. Please give more detail of your problem since there's not much we can tell by your description. What colors? what was the progression of the problem? can you attach a screen shot? Please comment back
Jun 02, 2006 | Dell E551c (Dark Gray) 15 in.CRT...
ViewSonic VX2235WM Monitor Logo
59 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
