Question about GE Washing Machines
I need the white part on the back of the timer (GE wisr309dt bww Washer) don't know the name
GE has a lot of timers with many different numbers.
Check list of timers on following link to identify timer.
http://waterheatertimer.org/GE-timers-and-manuals.html
For the most part, except for more expensive box timers from Intermatic and Tork, I don't know of parts for timers.
However if you can identify the timer and describe the part better and describe what the part does, somebody at fixya might have a good substitute.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Posted on Jan 04, 2011
I don't know where the color cables go on the timer pals shaft for my ge dryer
you need to find wiring diagram it should be in the console with the timer the wiring diagram will tell you which wires go where
Aug 26, 2012 | GE TIMER PLAS. SHAFT - WE4M366
Hi.. i have wisr309dt bww GE washing machine and i need a replacement belt... on the belt it writes 109b4949 p014 wh01x2788 ... can you please direct me where to buy the belt
FixYa is sorry but this Forum does not normally supply parts, part numbers, prices or other details direct; it's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web. Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained on many makes and models, probably over many years ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 01, 2011 | Washing Machines
I have GE side-by-side refrigerator, model GE GSS25LGM BWW. The tube from bottom of freezer door to water dispenser is leaking. It probably got damaged during our move when we removed and door and sat it...
I am sorry no repair I know of. As a repair tech we have to change doors often due to the same waterline freezing. there is no way in without damage to door . however you can buy the door from GE for about 300-400 dollars or do without ice & water thru door. Sorry I hope this helps
Aug 18, 2011 | GE GSS25LGM Side by Side Refrigerator
I have a new GE 15306 Mechanical Time Switch and need to wire it up to 2 white and 2 black wires that I had on my old timer. I need more information on the wiring than is on the diagram on cover of metal...
http://waterheatertimer.org/images/GE-15306-wiring-250.jpg
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
GE 15306 is a version of 120Volt Tork 1101 indoor-outdoor timer sold at Home Depot under GE name and number.
You have 2 cables.
One cable comes from Breaker box, and other cable goes to Load (light, fan, motor, pump).
Each cable has black and white wire.
1) Cable from breaker box: Black wire H Hot connects to to terminal L.
Notice there is a metal bridge that connects terminal L and terminal 1.
If metal bridge is missing, use a jumper wire and connect L and 1.
White N Neutral from breaker box connects to terminal X.
2) Cable going to Load:
Black connects to terminal 2
White connects to terminal X.
So both white wires are on terminal X.
Jul 14, 2011 | General Electric GE 56941 24-Hour Outdoor...
I am installing a ge #15070 basic timer and there are 3 wires. Which wire do I attach to the ground?
GE 15070 timer does not have ground wire.
I assume this timer is double insulated, just like some power tools and electronics only have two prong plug.
Leave bare ground wire attached to other bare grounds in the box, and shove grounds to back of box.
I have one of these timers installed.
Timer has red, black and white wires
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
How to wire GE 15070 timer:
1) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and slide switch to ON-or-OFF. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
5) Add a comment for more free help.
6) Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 13, 2011 | GE Vacuums
Am replacing an old wall timer with a GE Smart Digital Timer. The old timer had two black wires connected to two black wires from the wall. The new timer however has red, black, white and green wires. I...
I've tested these timers.
Here's what to do:
1) Connect green to bare copper
2) Switch has 2 wires. For now, connect these two wires to timer-black and timer-red. Choose either one.
3) In back of wall box are white neutral wires twisted together and covered with wire nut. Timer-white wire connects to these white neutral wires. This action gives power to time clock.
4) If wall box does not have white neutrals described above, then connect timer-white to bare ground wire. Bare ground connects to neutral busbar in breaker box.
5) Turn on power and click manual override button or switch. If lights turn on, timer is wired correctly. If lights do not turn on, then reverse timer-red and timer-black wires.
Nov 16, 2010 | GE 60minute Automatic ShutOff Timer Switch...
New switch GE model 15265 ... to light up 2 lightbulbs outside. Old switch all cables are black. Those who light up the tester are the hot=Red/black?? Those which do not light up are white?? Green I know...
Manual for GE 15265
http://waterheatertimer.org/pdf/GE-15265-manual.pdf
15A timer works fine on two bulbs, up to 1440 total watts.
If old switch has 2 screws plus green ground screw, then timer is right.
If old switch has 3 screws plus green ground screw, 15265 doesn't replace 3-way switch.
Timer-green wire connects to bare ground wire
Old switch has 2 screws with wires on each.
One wire is Hot-from breaker and this connects to timer-black wire.
One wire Goes-to-lights and this connects to timer-red wire.
If you get these two wires reversed, timer will not work, so reverse them.
It will not blow circuit if the timer-red and timer-black wires are reversed.
Timer-White wire is the confusing wire for everybody:
Timer-white wire runs clock motor located inside timer.
In back of electric box are neutral white wires that are twisted together and covered with wire nut.
Connect timer-white to these neutral wires.
If box does not have neutral white wires, connect timer-white to bare ground wire.
Nov 13, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Ge top load washer
Model number is on the top of the control panel on a white or silver sticker. It sounds like you have a bad timer, probably about $100 for the timer, maybe a little less.
Jan 07, 2009 | Washing Machines
Drain pump/motor not draining.
actually it sounds like there was or is something in the water pump (like a string or metal underwire from a bra). before replacing the water pump i would look inside it and check for foreign objects.
  1. unplug the machine, but leave other hoses connected
  2. use a butter knife or putty knife to open the front panel; at the top seam between the top panel and the front panel is 2 metal clips (about where the edges of the lid are). push these strait in to release the front panel.
  3. once the front panel is off then you should see the water pump on the right side. it has 2 large black hoses and 2 wires attached to it.
  4. take off the water pump (two 3/8 bolts) and look inside it.
some pictures borrowed from fixitnow.com, allpar.com, applianceaid.com and repairclinic.com
  • if you need to buy a new pump, then they are around $50 at repairclinic.com
  • or shop around; GE Washer Pump part # WH23X10013
  • here is a cheap one on ebay:
http://cgi.ebay.com/GE-WH23X10013-Washing-Machine-Washer-Water-Pump-Motor_W0QQitemZ170239837032QQihZ007QQcategoryZ20714QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
let me know if you get stuck
Mike
Jul 30, 2008 | GE WJSR2070B Top Load Washer
Washing Machines Logo
127 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
