Question about Neff B1421 Electric Single Oven
The oven cooling fan stays on after oven is turned off and will not turn off
The fan runs when power to the cooker is on but the oven itself is not switched on.
Probably the cooling fan. There is a cabinet thermostat on most ovens these days (Especially wall or underbench models) to keep the cooling fan running after the cooking has finished and oven turned off. This fan will run for a few minutes to cool down the outside of the oven so it doesn't burn / discolour the surrounding cabinet or workbench. If the fan stays on all the time, I would say that the thermostat has probably jammed in the run or on position.
Mar 21, 2017 | Ovens
Why fan stays on for hours after turning oven off
There is a thermostat inside that controls the cooling fan. It will keep it on until it is cool, it is a safety feature.
Aug 12, 2014 | Ovens
Cooling fan will not turn off, it has been on for 4 days.
this could simply be the TOC is stuck open, this is a thermostat which activates when a certain temperature is reached and the parts cost very little
Apr 11, 2014 | Ovens
Oven fan stays on
some ovens have a cooling fan that is controlled by a temp sensor, this will keep the fan running until the area where the sensor is cools. probably normal if it turns off after a while.
Jan 31, 2012 | Ovens
Have a stoves 720 es main oven fan does not stay on to cool oven after switch off> also the oven will not trun back on when it is still hot or warm ? will
First things first. There are two fans. One in the bottom oven and one to provide background cooling. The background cooling fan turns on when anything is turned on. (Fan oven/top oven/grill). Just operate the top oven for a moment and this should cause the cooling fan to operate. There is a printed circuit board that controls the cooling fan and for how long the fan should stay on once everything has been turned off. (About 7 mins). If this fan is not running then the fan/motor could be faulty, or the circuit board or the resistor on the fan terminal block. The reason the oven will not turn back on is that the residual heat in the oven unit as a whole against the fan oven, is probably too high which causes the overheat device to operate.
You will have to take the oven out of the kitchen carcass, take the top and rear panels off and get an electrician to test and found out which item is not working/failed. Try espares for parts.
Jan 24, 2011 | Stoves 720EF Electric Double Oven
How do i turn the fan off.
If you mean the oven fan that will turn off on control switch.I think you may be talking about the cooling fan.This is to cool the electrical panel on the top front of cooker. It comes on after the oven heats up and may stay running for 15 or 20 minutes after cooker is turned off it will turn off after the unit has cooled down sufficiently for the controller.
Hope I helped.
Good Luck.
May 07, 2010 | Electrolux EOB6636X Ultrafan Electric...
Should the fan on my built in electric convection oven come on during normal 'bake' mode (ie not 'convect' mode ?
There is a fan for cooling down whole oven, it can turn on and off during the regular bake or broil cycle to cool down the oven on the outside. It's controlled by its own thermostat, so it will even stay on for awhile when you turn the bake off.
Mar 03, 2010 | KitchenAid KEBC107 Electric Single Oven
Fan noise
It is a cooling fan, and, yes it can be replaced.
Please rate my solution.
Thanks.
Nov 22, 2009 | GE Ovens
Turning off oven.
The fan only comes on in the back of the oven when convecting and Automaticaly turns off when you open the door. The exhaust fan coming from the front stays on for qutie a while, maybe 2 hours or so till the oven cools. I think it is just a function of the oven. A good thing in the winter but uses a bunch of airconditioning in the summer
Oct 23, 2007 | Electrolux ICON 30 in. Double Wall Oven
Neff B1421 Electric Single Oven Logo
274 people viewed this question
Top Neff Ovens Experts
ashburton
paulcarew
bobby1964
Level 1 Expert
Are you a Neff Oven Expert? Answer questions, earn points and help others
