Question about Grundig GR-1000 DVD Player/VCR
Combo dead. no display ac present on power supply fuse. fuse ok.
  • 141 Answers
IC processor chip probably deadif you can't access either unit you probably need to get a new one, replacing the IC Chip usuallt costs more than the Combo itself
Posted on Jan 03, 2011
Need wiring diagram to figure trickle charger out
Check the stator for AC output to the charge rectifier, if present stator ok, then check DC on DC side of rectifier if not present change the rectifier, ssuming all fuses have been tested
Nov 08, 2013 | Generac Electrical Supplies
Hi i have a hitachi ax m140 power amplifier there's no standby light dead can you help please
Check the power supply rails on the secondary side of the power
transformer.
• Check the presence of AC outputs on the transformer secondary
windings
• Check the diodes and capacitor circuit
• Check the regulator circuits
Post image so we can undestand better ( only if possible )
and guide you accordingly.
Aug 02, 2012 | M-Audio Audio Players & Recorders
What should i do when my television doesn't turn on?
if your unit is dead set totally no power at all even led indicator the first step is check your AC outlet make sure the supply is present then check broken AC cord for your TV unit. then next step is to open the back cover for trouble shooting, try to use your senses first to diagnose defective part smell burnt parts, wirings, connector or even PCB. look for blown fuse and leak capacitors especially the output filter capacitor at the power supply which cause sometimes by over heat where in the capacitor casing explode, the temperature was exceed to the rating.and then use digital tester try to power on check the output voltage of power supply if present and normal according to its label.
Apr 28, 2011 | JVC Televison & Video
No power to monitor. Red light does not come on.
Hello The TV is completely dead no power indicator,nor standby light. Probable main fuse failure, but first make sure your AC feed is present, try another electrical fixture in the TV ac outlet you are using to make sure the outlet is alive. If this is not the case then check the main fuse(located inside the TV) not recommended if you are not qualified to work on electronic equipment. A blown AC fuse usually is an indicator of more serious problem further in the power chain(power supply/HV circuits, etc.)
Nov 24, 2010 | Fujitsu Plasmavision 42" TV
Don't Swith 0n
so ac supply is ok battery is ok then mother board is dead i worry pls check it out
Dec 12, 2008 | Fujitsu Siemens AMILO Pro V7010 Notebook
Ac power Symphonic sc309D blows fuse- Dc power ok
The most likely problem is a shorted diode, I suggest replacing them even if they do not test shorted while not under load. If it is not the diode rectifiers, there is probably a resister in the power supply that is shorted, remember also that it can also be both. Lastly, it can be a capacitor within the power supply.
I Wish You Well
Dec 03, 2008 | Symphonic SC309D 9 in. TV/VCR Combo
Dead power supply.
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20 minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Nov 17, 2008 | RCA DRC8300N DVD Recorder/VCR
Dead md-350wps
first remove all the dust from smps then check power cord output by multimeter whether right or not ok then open and you will find one fuse there check it without supply if open then replace it if not then check whether a.c. supply reaches or not if present then check the thermister resistance it should be low also check the dry solder if present then remove it please check dc supply at primary filter (big cylendrical capacitor) if not present then 4 bridge rectifier diodes may faulty replace it
Oct 23, 2008 | Mad Dog Multimedia SurePower (MD-350WPS)...
Dvd player is completely dead.
First thing to check is the power cord with it unpluged. Do you get a resistance there or is it open?? If its no reading at all then the power transformer or fuse or current limiter resistor is open. If you do get a reading then you know your power transformer primary is good. Next measure the AC volts comming from the secondary of the transformer. AC volts? Good! Now Find pin 1 or the end pins on the microprocessor. 5 volts present?? No theres your problem get a schematic and troubleshoot the power supply. Yes 5 volts? Measure the display any volts on it?? Ok im sure by now your gonna say no to one of these and like I said get a schematic and conferm all the voltages are present in the power supply. Most common dead problem in dvd/cd players is the power supply ie transformer,regulator, ic, ect, ect. Good Luck
May 10, 2006 | LG DVD 5183 DVD Player
Grundig GR-1000 DVD Player/VCR Logo
123 people viewed this question
Top Grundig Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
