Question about Transmission & Drivetrain for Jaguar XF
Transmission rumble between 70/80 mph - Transmission & Drivetrain for Jaguar XF
  • 115 Answers
Ussually pending tire ratings, it is the tire of wich is only balanced for certain speeds up to 80 mph. Have it balanced for 105-125 MPH of wich will resolve the problem. Z rated tires will be easier to balance for this speed. So take it to your local tire shop. If the problem somehow prersists, check your half shafts coming out of the tranny to the wheels. Their joints might already be worn out and need replacing.
Posted on Jan 05, 2011
98 Honda crv transmission between 20-45 mph let up on the gas and accelerate there is a rumble, bank clank noise if I dtep harder it stops what is the cause
It is more than likely some of the bearings in the transmission are worn, when you step on the gas it puts pressure on the bearings thus noise stops but it will get worse and eventually collapse get repaired now to avoid further damage. Topsi
Oct 17, 2014 | 1998 Honda CR-V
Rumbling at 40-45 mph, minor oil and coolant leakage
Get a oil change our put liquid our bleach were you put the liquid for the oil change
Mar 05, 2014 | BMW 325xi Cars & Trucks
Rumble in transmission between 45 and 55 mph
If it is only between those speeds, Possible loose prop shaft, or a worn universal joint?
Dec 20, 2013 | 1995 Buick Century
Intermittent rumbling sound in transmission at ~30 mph when going uphill and easing up a little on the gas. very much like driving over a rumble strip on the highway like they put in front of toll booths....
Do you have the problem when you turn on the car as well? I had this same problem, turns out the alternator was going bad. A few months later the alternator went. After the alternator was replaced, the problem went away.
Jan 05, 2011 | 1998 Ford Explorer
Engine rumble or trans rumble
universal in the drive shaft
Nov 16, 2009 | Cars & Trucks
2000 Lincoln LS rumble from 40 - 45 mph
See If the pitch changes when you swerve the car from left to right. You don'e have to swerve hard enough to scareanyone, just enough to load one side more than another. If the pitch changes, you likly have a bad wheel bearing or tire. Tires will make any noise a wheel bearing will so switch tires first side to side and see if the problem fgollows the tires. If not then check the wheel bearing.
Also and maybe first:
The fact that the noise is limited to such a narrow speed could also indicate an aerodynamic issue such as a roof rack or bike rack or somthing like that having moved and is now vibrating.
Feb 07, 2009 | 2000 Lincoln LS
Transmission
Had the same problem on a 2007 Corolla. The check engine light was on, had hard shifts, and a DTC code of P2716. The computer had to be updated. I would take it in and ask them about this TSB.
http://matrixowners.com/tsb/T-TC014-06.pdf
Jul 09, 2008 | 2007 Toyota Camry
Transmission & Drivetrain for Jaguar XF Logo
159 people viewed this question
Top Jaguar Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Spyro Matiatos
Spyro Matiatos
Arnie Burke
Arnie Burke
Are you a Jaguar Vehicle Part and Accessory Expert? Answer questions, earn points and help others
