Question about Brown Stove Works TM210 Gas Kitchen Range
Oven control valve wont shut off gas completely
This could be due to a build up of grease or tiny food particles behind the control tap handle;
1/ Gently prise off the handle ( it comes towards you )
2/ Wash handle in warm soapy/detergent water, till clean, then dry.
3/ Use a lint-free cloth or a sponge with warm soapy water to soak the tap control spindle and a plastic knife to clean off any stubborn bits.
4/ Wipe clean , replace handle part, try turning off.
Jaylo264
Posted on Jan 03, 2011
There is no gas getting to the oven in my frigidare oven
Hello kdccampbell2 - Does "LOC" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. Press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Confirm the shut-off valve on the gas pressure regulator is in the "ON" position. This valve shuts off gas to the oven (typically located on the back left-hand side of the range). I do not suggest re-lighting the unit, as this may cause harm to you and possible damage to the appliance. Contact a professional to move forward accurately and to assist with the repairs.
Jan 27, 2013 | Frigidaire FGF316 Gas Kitchen Range
Oven wont ig night but broiler works
Hello - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Granting that it does, you can try confirming that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. If after the basic troubleshooting, you continue to experience the issue I would suggest contacting a certified technician to assist in the full diagnosis and repair of your range.
Oct 22, 2012 | Frigidaire FGF316 Gas Kitchen Range
Oven wont light
This can be caused by a weak/inop hot surface igniter or a defective gas control valve.
One thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on and the igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing after the igniter is fully on. This may loosen up any debris inside the control valve housing that might be causing the problem. If the oven burner comes on then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve sticks again after trying this procedure(burner does not come on) then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad. You can also verify that the oven run-away valve is not closed. This valve will be located at the back bottom of the range at the gas regulator. There will be a tab on the regulator housing where the gas pipe goes to the oven. This tab will lift up to close gas flow to the oven. Sometimes these valves can stick causing the oven to stop working. You can try moving this tab back and forth to see if it loosens any debris in the valve. Move the valve while the oven is on and you will be able to hear the burner come on after moving the valve if that was the problem.
Remember be very careful doing any of these procedures. Good luck and have a safe holiday.
Jul 04, 2010 | Tappan TGF320 Gas Kitchen Range
Maytag Prec touch 750 lower oven takes too long to preheat
This is a common problem that happens when the oven gas control valve is sticking. This can be caused by a weak hot surface igniter or a defective gas control valve. One thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on,igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing. This may loosen up any debris inside the control valve housing that might be causing the problem. If the oven burner comes on then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve stick after trying this procedure then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad.
Mar 23, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
Fridgidaire gas stove oven glow lights up but oven doesn't come on sometimes then I smell gas, other times it comes right on with no problems
Mar 16, 2010 | Kitchen Ranges
Why does the Oven take so long to light?
It sounds like it might be a sticking gas control valve for the oven or the hot surface igniter for the oven might be weak. You will need to turn the oven on and off completely several times until the problem happens. When I say completely I mean turn on the oven control and watch the igniter start to glow. Then when the oven burner comes on(should within a minute) shut of the oven control and wait for the igniter to stop glowing completely and burner to shut off completely. Then repeat the process again. If you try it about 10 times and nothing happens then the problem will be difiicult to identify. If you turn on the oven control and the igniter comes on but the gas burner does not then try giving the gas control valve(located in brolier/storage compartment) a tap with a wrench. If the burner suddenly comes on then the control valve was sticking. Try repeating the shut down/turn on process again. If it does not do it again you may have fixed the problem...if it does you will need to remove the igniter and test it with an ohm meter(should read at least 500 to 800 ohms). If the igniter is testing good and glowing brightly then the gas control valve would be the suspected problem. And remeber to be very careful when doing these testing procedures so you do not hurt yourself.
Nov 12, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
I have a 7yr old Maytag gas slide in oven that sometimes lately takes a long time to reach it's set temperature. Other times it sails right up to the set temp. It works fine other than this. Any...
It sounds like it might be a sticking gas control valve for the oven or the hot surface igniter for the oven might be weak. You will need to turn the oven on and off completely several times until the problem happens. When I say completely I mean turn on the oven control and watch the igniter start to glow. Then when the oven burner comes on(should within a minute) shut of the oven control and wait for the igniter to stp glowing completely and burner to shut off completely. Then repeat the process again. If you try it about 10 times and nothing happens then the problem will be difiicult to identify. If you turn on the oven control and the igniter comes on but the gas burner does not then try giving the gas control valve(located in brolier/storage compartment) a tap with a wrench. If the burner suddenly comes on then the control valve was sticking. Try repeating the shut down/turn on process again. If it does not do it again you may have fixed the problem...if it does you will need to remove the igniter and test it with an ohm meter(should read at least 500 to 800 ohms). If the igniter is testing good and glowing brightly then the gas control valve would be the suspected problem. And remeber to be very careful when doing these testing procedures so you do not hurt yourself.
Nov 11, 2009 | Maytag MGR5750 Gas Kitchen Range
My Amana gas oven won't heat up gas smell strong
Sounds like a sticking gas valve or a defective hot surface igniter. Open the broiler drawer or remove the bottom cover in the oven compartment. The oven usually has a hot surface igniter or a spark igniter. Turn on the oven and watch for the hot surface igniter to start glowing. It should glow very bright. Once it is glowing the burner gas should come on. If you hear the gas come on it should light right away. If there is any delay shut off the oven and stay back. Let the gas clear out then inspect the area near the igniter and make sure the burner is not plugged(the little holes may have debris in them). If you turn on the oven and the igniter comes,glows brightly,no gas is heard but you can smell gas it is either a blocked burner orfice/assembly or sticking gas control valve. Try giving the burner and gas control valve a tap and see if it comes on. If you tap the control valve and it starts working then shut of the oven and try it several times. If it starts to come on and off now you may have cleared whatever debris was causing the problem. If it does it again then it could be the control valve or a weak hot surface igniter. The igniter can be tested with a ohm meter. Most of the time when I get this complaint it is the oven control valve that is sticking. Be very careful when doing these procedures....gas can build up in the oven compartment very quicky and flash if ignited. Always have the gas shut off valve at the back of the range within reach and the electrical outlet in case you need to unplug it.
Sep 13, 2009 | Magic Chef 9122 Gas Single Oven
My professional series oven preheats and then stops heating.
HI, there may be some issues within the dual safety gas valves. they mat be malfunctioning. these valves control the gas flow and if the shut prematurely, it will disrupt the heating process. You could also have a sensor issue as well but, im sensing that this abnormal shutdown is being cuased by a fualty Dual oven safety valve assembly.
Please rate and god bless:)
Apr 15, 2009 | Frigidaire GLGF386DC Stainless Steel Gas...
Oven control valve
Yes the valve is bad. Replace it and your good to go.
Aug 27, 2008 | Ovens
Brown Stove Works TM210 Gas Kitchen Range Logo
132 people viewed this question
Top Brown Stove Works Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Brown Stove Works Kitchen Range Expert? Answer questions, earn points and help others
