Question about Whirlpool GEW9250 Electric Dryer
Dryer makes a screaching sound when turned on
  • 33 Answers
Does it make the screeching sound continually after it is turned on or just when it is turned on and then the sound goes away? Knowing this will help in diagnosing the problem.
Posted on Jan 03, 2011
  • marx36 Jan 03, 2011
    it started doing it in the middle of the cycle so im assuming the noise will not stop. also its a ge adora dryer not whirlpool.
5 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: our ge profile electric dryer has recently started
Your problem sounds like drum rollers is in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Posted on Oct 15, 2009
dmftrucker
  • 1922 Answers
SOURCE: My whirlpool gas dryer makes a screaching noise turns off
your drum glides/rollers are defective on the front edge of dryer where the drum rests,sounds most like the glides are glazed,not roller bearings but check it could be either
Posted on Nov 05, 2009
  • 2694 Answers
SOURCE: dryer makes screaching noise as the drum spins
bad roller or pulley or depending on the dryer like frigidaire there is a bearing that goes on them and will make that noise,next time send brand name and model number
  • 35 Answers
SOURCE: My dryer is making loud screaching noises
Sounds like it needs what are called glides or felt. This is what keeps the metal drum from contacting the metal housing. If this is let go too long the drum can be ruined
Posted on Dec 01, 2009
Why is my dryer is making a high pitch screaching noise?
frigidaire dryers have a rear bearing that the drum rides on,usually when you hear metal on metal sounds it will be the rear bearing
Feb 22, 2012 | Frigidaire FER641FS Electric Dryer
Help - problems with screaching/grinding sound - small smell of burning
Did you remove the filter chute? My dryer was making a heck of a racket and I found a wire inside the blower housing:
Service manual and more
Nov 14, 2011 | Kenmore 659 Electric Dryer
I have a Maytag Heavy Duty Quiet Series 200 Dryer, and when I turn the dryer on is makes a horrible screeching sound. Like metal grinding against metal. What do I do?
That's easy, first of all you must have the Dryer on flat floor I mean verticly right. And try not to put too many clothes to get dried.
Sep 12, 2010 | Maytag Dryers
My dryer is making loud screaching noises. Everytime I turn it on to dry clothes is makes very loud screaching noises.
Dec 01, 2009 | Dryers
Sounds like it is scraping when turned on
You've got some worn out friction pads, rollers, or bearings. Do not run the dryer in this condition... It will damage the drum (if it hasn't already).
You'll need to remove the front to look at the front drum supports and the rear support rollers. Once you are able to see inside the dryer, it should be pretty obvious which parts are defective.
Nov 19, 2009 | Kenmore 73952 Gas Dryer
Dryer makes screaching noise as the drum spins once the dryer is running for 10 min or so. Sounds like the drum needs some WD40.
Nov 05, 2009 | Dryers
Nov 02, 2009 | Whirlpool LGR5636L Gas Dryer
Need blower wheel replaCDED?
If it was your blower wheel it would not make that noise first cheak and see if thewheel has play on the shaft if so then it will need to be replace second turn blower wheel by hand back and forht if there is a screaching sounds if is a dry bearing on the motor .If so if you can live with the sound it will not go right away if not remove motor and replace.If there is play on the wheel you will need clip pliers and normal pliers and remove both clip[ on shaft and clip on shaft revers after install new blower wheel good luck:)
May 07, 2009 | Maytag PYE2300AY Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
79 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
