Question about Sony BDP-S300 Blu-Ray Disc Player
Willnot play new avatar think player needs an update
  • Sony Master
  • 890 Answers
I suggest that you install the latest firmware update to resolve the issue. Please click here to download the latest firmware update.
It is recommended to use CD -R disc to create the firmware update disc.
I hope you're clear with downloading the update from support page.
Once you download and save the file in the folder in the computer, you can double click the file to extract.
You will be prompted to save the UPDATE_BDPS300_VER0550.ISO file in a folder.
Most of the customers will be making mistake here after...
We need to use a burning software which is capable to burning discs from ISO images. ISO image is nothing but a RAW format of burned image.
I will give you the instructions to burn using Nero.. Steps will be almost same in all ISO capable software.
Open installed nero software from computer. You may locate it under Start Menu programs.
Go to File Menu (Some times you will get a wizard where you can select the Image Burning option or burn ISO option)
Navigate the extracted .ISO file we saved in the computer.
follow the onscreen instructions.
Insert the disc when ever Nero asked to insert
Hope this helps. If you need any assistance. Please get back to me. I will be more than happy to assist you. Thanks for understanding.
Posted on Feb 05, 2011
It willnot play tron but will play avatar
It sounds like you need to update the firmware on the player.
http://www.blu-ray.com/firmware/firmware.php?id=24
This link has the download you need and instructions on how to do the task.
Apr 23, 2011 | Samsung BD-UP5000 Blu-ray and HD-DVD...
Samsung BD-C5500C with latest firmware will not play audio track out on fiber optic to yamaha receiver when playing Avatar BR. Works on Avatar's main menu screen but stops once the movie is started. Same...
I don't think this is a software update issue. Just as you said that the player has the latest firmware installed on it. Software update and latest firmware are the same thing.
I think this is a incompatibility issue. The disc is not 100% compatible with the player and that is why there is no audio via sound.
But one more thing you can try is to enter the player's menu, under settings, check audio settings. You can change the sound settings to mono, save settings and try again.
Good luck.
Feb 06, 2011 | Samsung BDC5500 Player
I have the latest software version for the BDPBX2 11.4.008 when I try to play the Avatar Bluray DVD I get the following message: if you experience problems playing back this DVD go to...
I have Avatar Blu-ray movie and it plays on my BDP-BX2 11.4.006 version. Take it back and get it exchanged. Try new one. May have to go to another store since the same shipments (bulk) that are at your store are ALL the same. I have done this 4 times with 4 different movies and 2 of them worked. I'm getting the .008 update but, I'm starting to think the Blu-ray disc are the problem since I have one that is made in Mexico??? I don't think they are all being made correctly. Too Cheap!
Nov 07, 2010 | Sony BDP-BX2 Blu-Ray Player
For avatar how fix samsung bd c5500c blu-ray
If this is a Blu Ray Disk then your unit needs a firmware upgrade to be able to play the new Blu ray format. Contact Samsung for the upgrade file, burn to a DVD and run. The update will allow your unit play the new BR Format.
Please rate my help ++++Thanks for uisng FIXYA
May 28, 2010 | Samsung Televison & Video
Element EDBCO11 + Avatar = problem
Avatar bluray disc uses some super-new technique for copy-protection, which many players don't support yet. If you already upgraded to the latest firmware, you can only contact your dealer and ask them - or wait for even newer firmware.
May 12, 2010 | Element Electronics EDBCO11 Blu-Ray Player
Tried to play Avatar and it will not play..
You need to update the firmware. You also need to know the model number of your bd player. Aquos is not enough.
Firmware is available here:
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
May 07, 2010 | Sharp AQUOS Blu-ray Disc Player
Blue ray won't play Avatar?
There is a firmware update for the BD-HP22. I had the same problem with Avatar but after I installed the firmware update, it loaded and ran smooth. Use the USB flash drive that came with the player or any other usb flash drive to load the firmware update. Check the link below for instructions and update file from Sharp's website.
May 03, 2010 | Sharp BD-HP22U Player
Avatar will not play on my BDP-S300 Sony blu ray. Any recommendations on how to fix this?
I recommend you go to the Sony website and find if there are any updates for your blu ray player. If there are they will have you download the update, unzip the download to a new file, copy the file to your DVD burner, and install the DVD Update into your player, press "play" OK a couple of things and shazam! Updated! That is unless your lens just needed cleaned, Good Luck.
May 03, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Sharp BDHD16 won't play Blu Ray Avatar movie, updated to latest software update which is PF09120100 ( which is also update for sharp BDHP17 machine) file then updates it to the level of a BDHP22 level. ...
Version PF9200400 is the most current version and it was released on 4-26-10.
When the unit is updated to that version it should play the bluray. If you continue to have problems with playing blurays you might need repair as the drive may need to be repaired. If your unit is in warranty you can call Sharp and speak to someone in aquos advantage dispatch to get a refurbished unit as an exchange if you don't want to send the unit in to be repaired.
Apr 26, 2010 | Sharp BDHP20U Blu-Ray Player
Bd hp210 will not play disc (sharp)
I have the same problem but I did download the updates for both my Sony and Sharp Blu Rays and Avatar played wonderfully but unfortunately a few days later both players stop playing all Blu Rays. Has anyone had the same problem?
Apr 26, 2010 | Sharp BD-HP21U Blu-Ray Player
Sony BDP-S300 Blu-Ray Disc Player Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
