Question about Mitsubishi WS-65809 65" Rear Projection Television
My 65 mitsubishi has started to have squiggly lines through the picture when you first turn it on. the picture also goes concave then back to normal. After awhile, it stops, but is happening for longer periods of time. It is about 10 yrs old. There is also a blur to the picture. With the price of t.v.'s today, would it be better to try and fix or just bite the bullet and get a new one?
  • 675 Answers
Sounds like the convergence circuit is starting to fail...there are kits available for this set from tvrepairkits.com . The kit isn't all that expensive but the labor to have someone put it in may be expensive.
Posted on Jan 03, 2011
All of a sudden the picture turned green with concave lines running horizontal. Whats the problem?
Let me post a few photos and you tell me if your problem looks anything like them.
If this is the case confirm the Mitsubishi model number to me and I will tell you what is involved to repair the set.
If this information or the photos were helpful rate this solution as I do this here for free.
SD TECH
Next photo:
Dec 18, 2009 | Mitsubishi WS-65513 65" Rear Projection...
My rear projection tv has squiggly horizontal lines in the picture. Sometimes when I turn it off and then turn it back on it goes back to normal but it is steadily getting worse. Any suggestions would be...
I have seen this on quite a few Mits's as they are getting to that age. This is usually related to bad caps in the signal path. I could go into more detail if I knew the exact Model Number (it will start with WS or VS) Example VS-60609. But the caps are usually near the 5v regulators.
Jul 09, 2009 | Hitachi Televison & Video
Picture quality
Contact your local service rep as this sounds like a "not so easy fix' related to the main board or power supply (known issues with Mits boards, especially the capacitors). Cleaning, resetting, re-configuring will not likely make any difference. Verify the problem occurs across all input modes (such as DVD, etc). before taking any service actions.
Jun 25, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Picture Problem
I have the same situation. Called my repairman, who knew exactly that it needed a "570 kit" . It will be repaired this week. Cost $360
Sep 26, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Red and blue colors go across the screen. picture looks concave.
Greetings joanne7,
The issue you are having could be caused by your television needing the convergence adjusted. During production your televison has the three picture tubes that are converged to form a single image on the screen. Over time these can come out of adjustment.
If you go to this link http://download.jazel.net/misc/filecache/b8/b89bca4c8b740315d378e8ed030461c5_1227-517SeriesOwnersGuide.pdf and check pages 57 and 58, it gives you a very detailed guide on adjusting your convergence. I am aware this model number is slightly different than yours, but I own a 47" Mitsubishi and this is the exact procedure we use to do our convergence so I am confident it is fairly universal.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 25, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Picture problem on mitsubishi medallion ws 55819 model....picture convergence messed up on left and right side of screen (center fine)...problem goes away and set "re-adjusts" after it's been turned on for...
Well I have a Mitsubishi WS-65413 65 in. Rear Projection Television and when I power it on in the morning it looks as if the picture on the bottom of the screen is bending and parts of the picture "double up" but like the person above me said after it gets warmed up it goes back to normal but every 3 or 4 hours it might get messed up for a min...Anyways: Is it the picture tube going out?? If so how does anyone know how much it would cost to repair/replace & What is a "Convergence Module"?? I don't know if my T.V has one of those or not but if it doesnt is that the problem perhaps?? Please help me or ill be forced to go outside... :-( ..... thanx 4 the help ppl!! -
- Zachariah-
May 10, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Problem with picture
my tv got blue line acroos screen and a yeloow shade on top of screen What can i do
Nov 19, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi HD 65" thin squiggly line in upper right corner that moves
Is the problem there on every source? DVD playback ok?
Suspect signal source  box.
May have bad connection since move.
Is the problem same on every channel,if source is cable direct?
Please provide more info if more help needed....T.
Oct 17, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
147 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
