Question about MSI 865GVM3-V Motherboard
MY USB 3.0 PIN ARE SORTED,SO NO POWER FOUND - MSI 865GVM3-V Motherboard
  • 2,509 Answers
Enable USB3 in the Bios?
Posted on Jan 03, 2011
How to remove password from hp computer
You must clear the cmos. Unlplug from power socket open the desktop and search for a 3 pin socket that sort 1 with 2 or 2 with 3 and naming cmos clear. Sort with other pin if you see sort 1 with 2 then pull the jumper and sort 2 with 3 for few seconds 2 or 3. Then pull again the jumper and sort the old one selection. You can remove and the battery (c2032 usually).
May 04, 2014 | HP Hewlett Packard Pavilion A6200N PC...
XBOX had no power, so I found and repaired bent USB port pins, then the XBOX came on with three red lights. Any DIY repair possible?
Thanks for your question. To fix the 3 red lights what you will need to do is stop the heat getting to the GPU and the CPU and to do this you can use a good Xbox 360 Repair guide or of course you can send it in to microsoft.
Jan 09, 2013 | Microsoft Xbox 360 Console
Do you have any user manual for front panel usb
http://www.msi.com/product/mb/PM8M-V.html
(MSI PM8M-V H, is version 2.0 )
Hover your mouse cursor on the Download tab.
(Overview / Specification / Download / Support / etc.)
In the drop down list, click on - Manual
Under the subheading - Download, click on the blue -
M7104v1.0.zip
[ This is a Zip file. A Zip file is a file that is compressed, to send easier. The above manual is for the M7104v1.0
It will work for the version 2.0 also.
You need a program to 'Unzip' it. (Decompress)
If WinZip is not working on your computer, go to 7-Zip, and download for free.
If you need guidance in downloading, and unzipping, post back in a Comment ]
There are two USB headers on the motherboard for the Front Panel,
JUSB1 and JUSB2. (Junction USB 1 and Junction USB 2)
Looking along the bottom of the motherboard, FROM the Right going towards the Left;
JFP1 header; (Front Panel main wires)
Header with 4 pins on the Top row, and 5 pins on the Bottom row.
JFP2 header; (Dual color Power On LED, and Speaker)
Header with 4 pins on the Top row, {Speaker}, and 3 pins on the Bottom row.
JUSB2 header.
JUSB1 header.
EACH USB header will support TWO USB ports in the Front Panel.
JUSB1 supports two,
JUSB2 supports two.
For each USB header there are 5 pins across the Top, 4 pins across the Bottom.
The pins are numbered EVEN across the Top, and ODD across the Bottom.
Starting from the LEFT side going across to the RIGHT side;
on the TOP row for JUSB2 and JUSB1;
Pins 2, 4, 6, 8 and 10.
on the BOTTOM row for JUSB1 and JUSB2;
Pins 1, 3, 5, and 7. There is NO pin 9.
A) Pin 2 is VCC
B) Pin 4 is USB1-
C) Pin 6 is USB1+
D) Pin 8 is Ground
E) Pin 10 is USBOC
Pin 10 is N/C -> Not Connected.
It is there, and Pin 9 is not there, to key which way a connector can go on. Only ONE way.
F) Pin 1 is VCC
G) Pin 3 is USB0-
H) Pin 5 is USB0+
I) Pin 7 is Ground
There is NO pin 9.
(The USB technology used is USB 2.0)
http://pinouts.ru/Slots/USB_pinout.shtml
Let's read together,
Under - USB pinout signals;
"USB is a serial bus. It uses 4 shielded wires: two for power (+5v & GND) and two for differential data signals (labeled as D+ and D- in pinout). NRZI (Non Return to Zero Invert) encoding scheme used to send data with a sync field to synchronise the host, and receiver clocks. In USB data cable Data+ and Data- signals are transmitted on a twisted pair. No termination needed. Half-duplex differential signaling helps to combat the effects of electromagnetic noise on longer lines. Contrary to popular belief, D+ and D- operate together; they are not separate simplex connections."
See the USB examples in the link above, where it labels the contact pins?
The MALE connectors are shown on the Left side.
The FEMALE connectors are shown on the Right side.
Your USB ports will be FEMALE, on the Front Panel.
They are also the A style. USB A style. The Top example to the Right.
Just noting the following in case for some reason, the wires coming from those contact pins in the female USB connector, are not color coded correctly;
Even after you have the wires sorted out, as to which contact pins they go to, DOUBLE-check again. Do NOT just go by the color code of the wires.
Why?
You do NOT want to accidentally connect the +5 Volts (VCC), to the Ground!
Explaining further;
You connect the VCC wire, (Red), of the USB port in the Front Panel, to the Ground pin on the USB header on the motherboard.
(Which means the Ground wire of the USB port, (Black), will probably also be connected to the VCC pin, on the USB header of the motherboard)
Zzzzzzap! There goes your front USB ports. Both USB front panel headers on the motherboard, will be DONE!
Make sure!
Going on;
1) VCC or Vcc, goes back relating to Transistor technology.
Just think of it as the Positive, or power wire.
It is.
It is 5 Volts DC.
2) GND is Ground. It's a DC circuit, and you have a Positive, and a Negative, or Ground.
3) USB1-
That is -> Data-
USB0 is for one USB port in the Front Panel.
USB1 is for another USB port in the Front Panel.
[ Each USB header on the motherboard can be connected, to TWO USB ports on the Front Panel.
Therefore for the two JUSB1 and JUSB2, you can connect Four USB ports in the Front Panel ]
Data- on one USB port in the Front Panel, goes to USB0-
Data- on the other USB port in the Front Panel, goes to USB1-
4) Data+
Same thing.
Data+ on one of the USB ports in the Front Panel, goes to USB0+
Data+ on the other USB port in the Front Panel, goes to USB1+
EACH side of JUSB1 and JUSB2, will support one USB port on the Front Panel.
Two sides per JUSB1 and JUSB2 = 4 USB ports on the Front Panel.
For additional questions, or clarification to anything I have stated above, please post in a Comment.
Regards,
joecoolvette
Jul 20, 2012 | MSI Computers & Internet
I HAVE A NEW CASE, & NEED TO CONNECT THE FRONT UBB & AUDIO LEADS. CAN YOU HELP, CHEERS
Hi there, first check the image below. You've got USB 3 and 4, and AUDIO section. For the USB, pins 1 and 2 represent front panel USB power on both 3 and 4. As for AUDIO connection, pin 1 is Front Panel Microphone input signal, pin 3 is Microphone Power, pins 5 and 6 are for Right Channel audio signal to Front Panel and pins 9 and 10 are for Left Channel audio signal to Front Panel.
You can find more details in the motherboard's manual, page 23 and 24.
Jan 23, 2011 | EliteGroup P4M800PRO-M478 Motherboard
System shutdown in 15 seconds
Shut the power down to the computer all the power and pull the power cord out, remove all usb devices except the mouse and keyboard, Turn the unit back on and see if this fixes the problem, if it doesn't then you will have to go into the computer and clear the c-mos this will allow you to get into the bios screen from there you can set up the computer again. Check you manual for the instructions on bios reset, most times it is just pins 2+3 that need to have a jumper installed to reset it. READ THE MANUAL PINS 2+3 APPEAR ON MANY THINGS ON THE CIRCUIT BOARD
May 31, 2010 | ASUS P5PE-VM Motherboard
My tower won't turn on it keeps flashing yellow, no response. What can I do?
take everything out of tower plug in keyboard power and video see what happens
do not unplug power to mb two seperate plugs a 20 pin and a 4pin
Oct 31, 2009 | Dell OptiPlex GX270 PC Desktop
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Panasonic Plasma Monitor TH-42PWD7B - Convert to TV screen?
hi yvonne not sure if you sorted this but using this lead should get you sorted
http://www.maplin.co.uk/Module.aspx?moduleno=4702
the phono blugs ae used for audio and bnc plugs on the back of your panny are for the video
Apr 04, 2009 | Panasonic TH-37PE30 37 in. Plasma...
P4VMM2 motherboard
You can download the manual from here (Europe) or here (US).
Sep 17, 2008 | EliteGroup P4VMM2 Motherboard
MSI 865GVM3-V Motherboard Logo
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
