Question about Philips MCD908/37 System
I have a Philips MCD908 only had it 6 months it started making a buzzing sound from the speakers.so i took it back to richer sounds in leeds it was under guarantee. they replace it. Now 12 months later the same problem again when i turn it on it has a 30 second warm up for the valves then the buzzing starts if i turn the volume knob off it stops. but turn it to any number on the volume scale the buzzing starts. the shop will not take it back out of guarantee
SOURCE: Sound Problem
Hello people.
First of all, you must be carefull with flatcables and with statics and ressolder all the heatsinks zones, prior to the big one where the output audio amplifier chips are mounted. Ressolder no matter you can´t see anyting wrong.
After it reassemble the pcb mainboard and gently press the pcb over M62446. It´s the volume and tone control. If the sound fails, it must be ressoldered. (SMD, not easy for beginners, and therefore not recommended) or replaced.
Check other components on the enviroment.
Press gently to test.
Ressolder is recommended for all the main board.
Charlie
Posted on Nov 29, 2007
  • 20 Answers
SOURCE: Philips HTS3450 System Problem buzzing/clicking sound on startup. Now nothing.
As I found somewhere on the internet; there are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #: 272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. Make sure you match the polarity properly when replacing. Your unit will be as good as new and will proibably last forever now.
Posted on Jul 18, 2008
I had the same problem except my volume would just decrease after a few minutes of being on like someone was pressing the volume down buttton. If I walked over to the subwoofer and gave it a knock on the top the volume would instantly come back on where I had it set before. I took WheatService's advice and replaced the 470uF/25Vcapacitors and everything is working great now. I am very pleased. BTW, the parts at radio shack were like $3.00. I needed a desoldering tool, which I would recommend for this job...the one with the suction ball. I also needed some more soldering wire for a total repair cost of about $17. If you have all the tools the capacitors will cost you $3.00. Philips wanted to send me a replacement unit for $100.00 and I'm sure the local repair shop would have been the same if not more. Thanks again, WheatService!
Posted on Aug 12, 2008
SOURCE: Philips 30PF9946/12
power on, can hear sound but no picture.
any suggestions
Posted on Aug 31, 2008
SOURCE: Philips Soundbar HTS8100
put it in the bin
Posted on Sep 11, 2008
My Marshall MG50 DFX Has an awful buzzing sound that comes out of it after startup.
I would check C22 and C24 the main smoothing capacitors. They can fall out at worst or just have bad solder at best.
Mar 20, 2017 | Music
My philips speaker (sub) has no power at all when i plug it into the outlet, is it fried? now i have to use the 2 small ones plugged in straight to my desktop computer. ( i just recently got these from...
it might be that no sound drivers have been installed or your sound settings are incorrect if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
if this fails to fix the problem you might have warranty if the speakers are only one month from purchase date
hope this helps
Jul 13, 2011 | Philips SPA2360 21 Speakers
May computer is about two months old. Everything works fine except the sound. When you listen to something music or talking it makes a buzzing noise then continues on for a bit longer sounding good , then...
Your computer with your speaker is under warranty. Have your pc and your speaker check and replace by your reseller. Doing anything with your pc right now will make your warranty VOID.
Sep 12, 2010 | E-Machines eMachines Desktop PC
I have had a rather disoncerting lw level buzzing
I had the same after about 15 months. It seems to happen when charging the iPOD. I took it back to John Lewis, it was returned to B&W and came back repaired 8 working days later. I was very pleased with the service. As an added bonus B&W restarted the 2 yr guarantee.
Jul 27, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
PC Speakers Buzz at Random Times
bad connection broken fratured wire just touching dirty or oxidized plug connection
Aug 01, 2009 | Philips MMS 321 Computer Speakers
3 lights blink and a loud buzzing sound.
Color wheel you can get one at the following link with instructions on how to replace it
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Dec 16, 2008 | KLH HTA-4906 System
Philips HTS3455/98 System "NO SOUND" PlZ Help!!
There are two capacitors on the power board that are 470uf/35v. go to Radioshack and buy two catalog #272-1030 470uf/35v radial lead capacitors. if you have soldering wick and a soldering iron, then this will cost you under $3.00. when you remove them, the capacitors have a white strip with a negative sign on it. match this up with the shaded area on the board. put it back together, and it will work, and last a long time. I have this same system, and it wouldn't play any sound. so, I replaced the capacitors. Hope this helps!0ccab8c.jpg
Nov 30, 2008 | Philips HTS3450 System
Buzzing noise
If the sound goes out completely, try hitting the mute button (to mute it) and then hit it again (to un-mute). I've found that this work-around typically gets it working, at least.
Jan 03, 2008 | Philips HTS3450 System
Philips MCD908/37 System Logo
126 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
