Question about iRiver iFP-890 MP3 Player
I overcharged my MP3 player, is there a way to fix it?
What happens if hip street flare 2 overcharged
It should stop charging when its fully charged not overcharge.
Dec 28, 2014 | Audio Players & Recorders
Can you over charge a mp3 player and if so how do you fix it
If your charger/adapter is very light or has an AC voltage range of 100-240 V, it is of a type (switched mode) that is generally intelligent enough to prevent overcharging. The battery set is normally comprised of more than one cell; typically three, and if one of these fails (not uncommon), the device they power will often no longer turn on.
Feb 14, 2010 | SanDisk Sansa e200 MP3 Player
Battery
your battery may be overcharged and overheated, Check the battery with the service center
Jul 09, 2009 | Samsung YP-K3 MP3 Player
Philips MP3 PLayer
Overcharging can damage an mp3 player. I will give you a few "soft" fixes, but most likely you will need to call Philips and see if you are still in-warranty:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Mar 17, 2009 | Philips SA3025/37 Flash MP3 Player
My onyx 2gb mp3 player is broken and won't turn on
my onyx 2gb mp3 player is broken and won't turn on????  It wen't black  one day???? HELP MEEE HELP MEEE HELP MEEE.
Jun 04, 2008 | Audio Players & Recorders
Cracked
If you mean the screen then yes... It's a common problem... The battery will flex the screen if it's overcharged and eventually crack the screen... Microsoft will **t replace it... Sorry... have ** answer to fix it. Just why it happens and that microsoft won't help you with it.
Feb 20, 2008 | Microsoft Zune JS8-00001 Digital Media...
NO SIGNALS ON NWD-B103 SONY MP3
i think that your mp3 players battery has died of use or overcharge and you need a new one so i would take it to a retailer of your mp3 player and see if they can get a new battery for you
Jan 31, 2008 | Sony NWZ-B103FBLK MP3 Player
My Opal Mp3 Player
charged too long, overcharged
Nov 10, 2007 | RCA OPAL M4001 MP3 Player
Mp3 player wont turn on...its been charging for days..
Never overcharge a li-ion battery. You must firstly 're-set' your T8 (refer to your manual, or download a manual from the Samsung website - download centre). Disregard the charging indicator, as this will always show 'charging' when connecting to a pc. If out of warranty, then you may be faced with new battery, as it is possible to fry a battery if left too long. If under warranty, then seek advice from approved Samsung service agent.
Jun 30, 2007 | Samsung YP-T8 Digital Media Player
iRiver iFP-890 MP3 Player Logo
48 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
