I would like to purchase display monitor - Computers & Internet
    Sergeant:
  • 223 Answers
Just try in ebay.com or amazon.com you will get best and cheep ones.
Good luck ! if you think your problem solved don't forget to rate :)
Posted on Jan 03, 2011
Monitor does not display. it can produce program sounds
That usually means it is a faulty and really would not be worth repairing.
If you need it for a reason then i am sure you can purchase second user CRT monitors very cheaply or a new or used LED/LCD display.
Aug 26, 2013 | HP COMPAQ 7540 CRT Monitor
I have a dell laptop with windows 7. i just purchased monitor samsung b2330 23". everything looked great. now for some reason, everything looks normal on my laptop, yet on the monitor looks like it is...
  1. Open Display Settings by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
  2. To designate the primary display, on the Monitor tab, click the icon that corresponds to the monitor that you want to designate as the primary display, and then select the This is my main monitor check box.
  3. Select the screen resolution and color quality for each monitor that you're using.
Oct 03, 2010 | Samsung Computers & Internet
Monitor does not display windows. It says the monitor is working fine, check the feed to the monitor from the computer. I assume that the graphics card is the problem, as the last couple of times the...
have you isolate the monitor very much? try to use other monitor. if other monitor shows some display then your old monitor is defective. replace a new one. but if the other monitor does not shows some display the your video card is defective. you have to purchase new video card.
Mar 15, 2010 | Computers & Internet
I just purchased two 40in lcd samsung monitors and connected them via vga to a digital player. One monitor works fine and displays the picture correctly. The other monitor is only displaying the top left...
If the two monitors are identical adn the player works on one then it should work on the other.
Try plugging the monitor that appears "broken" into another device (such as a PC) and see if it works or not.
Dec 09, 2009 | Samsung Computers & Internet
I have purchased a Asus en6200le card for dual monitors at work. I have also purchased the correct DVI-I to VGA adapter so i can run 2 vga monitors, but i still cannot get the second monitor to show how...
Right-click the desktop, and then click Properties.
In the DisplayProperties dialog box, click the Settings tab.
Click the Display list and select your external monitor. If you do not see multiple monitors listed, your computer hardware may not support Dualview. You can still use MaxiVista to configure a second computer as an additional display, however.
Select the Extend my Windows desktop onto this monitor option. Click Apply or OK
Jul 17, 2009 | ASUS EN6200LE/TC256/TD GeForce® 6200LE,...
No monitor display
Return the monitor. I had one like that and I replaced it with a Dell.
Mar 23, 2009 | Acer AL2016W 20" LCD Monitor
My new 22" monitor won't come on
restrat your computer then press continue F8 key untill u get menu
then go to enable vga mode or safe mode or last known god configuration. set your display resolution in display properties to 1024*768 pixel then try.
Oct 05, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Connecting Apple Studio Display 17 ( LCD ) to Apple G4 Cube
Check the connector coming from the monitor and see if any pins are crushed or touching. It may be shorting power going to it.
Mar 02, 2008 | Apple Studio Display 17" LCD Monitor
Studio display m7649 picture will not come up when connected to toshiba laptop
I am not sure how youve manage to connect these 2 items. You did not specify whic Portage you have, but even the most recent only has SXGA video port. The Apple cinema display connector is ADC. APPLE DISPLAY CONNECTOR. No computers on the planet have this port except for apple's. It's basically a modified DVI connector. In order for you to use this monitor with your computer, you would have to purchase a DVI to ADC connector , which is another APPLE only item and selld for $100 new. You would then have to purchase a SXGA to DVI adaptor...It sounds like a costly endeavor, and with a connections your Portage's onboard video card , amynot even support the resolution for this monitor.
Hope this helps.
Oct 17, 2007 | Apple Studio Display 17" LCD Monitor
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
