Question about Frigidaire FRS6R5ESB
Dear tech i'm having defrost problem with my frigidaire side x side.the tech guy change the control board and the fridge work well for 1 week.we check the defrost heater and thermo switch,seems ok.put it on manual defrost yesterday and it defrost now it start to ice up again.could u tell me what else i have to do
22yooper
  • 828 Answers
SOURCE: GE Profile SxS Refrigerator wont defrost after new heater installed
If one coil was burnt out and you replaced the heaters and defrost terminator switch I would recheck the continuity through the defrost heaters. You can do this with an Ohm meter with the refrigerator unplugged. If you had an open coil in one of the heaters you did not have to replace the thermo disk. If you have a complete circuit through the heaters try using the old thermo disk. If you have a meter you can check the voltage from the heater connection on one side to the inlet side of the thermo disk with the refrigerator running in the defrost mode. You should read 115-125 Volts on the meter. This reading tells you that the defrost timer is supplying power to the heater circuit.
Posted on Apr 30, 2008
Krazytech
  • 725 Answers
SOURCE: Frigidaire side by side model# FRS6LR5EW6
Sounds like a defrost problem or a plugged drain... to get it to work temporary defrost the freezer. Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks.
To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain.
The defrost systems is:
HEATER-DEFROST
THERMOSTAT-DEFROST
Adaptive defrost control
Start with the adaptive defrost control board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
Frigidaire - referance model FSC23F7DSB3
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A �d� in the freezer temperature window and �F� in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. �d� and �F� will be displayed until the defrost cycle is complete. (approx. 8 minutes)
Heater / Thermostat
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Posted on Aug 10, 2008
abhishek33
  • 1239 Answers
SOURCE: Fridge stopped working, freezer still works
HI
If the compressor doesn't run, it is likely that the defrost timer is malfunctioning. This part is located near the compressor. To test the defrost timer:
Step 1:
Unplug the refrigerator.
Step 2:
Disconnect the wires from the timer and timer motor. Remove the timer from its brackets by backing out two retaining screws.
Step 3:
Test the defrost timer with a VOM set to the RX1 scale. Clip one probe of the VOM to each defrost timer -- not motor -- wire, and turn the timer control screw shaft until it clicks. If the defrost timer is functioning, the meter will read zero. If the needle jumps, the defrost timer is faulty. Replace it with a new one of the same type.
Step 4:
Connect the new defrost timer the same way the old one was connected.
To check the defrost timer motor, clip one probe of the VOM to each motor wire, setting the scale to RX100. If the meter reads between about 500 and 3,000 ohms, the motor is functioning properly. If the meter reads higher than 3,000 ohms, the timer motor is faulty. Replace it with a new one of the same type. Connect the new motor the same way the old one was connected.
Posted on Dec 07, 2008
farfield
  • 462 Answers
SOURCE: fridge condensation - freezer thawing
OK now I'm wondering are theses numbers your getting 4 -9 the actual temps of the refrigerator and the freezer? and do they feel this cold and correct to you? I know the refrigerator side shouldn't be below 34 or so and definitely not below 32. If this is correct and the numbers are not settings but temps. (Now if you have a touch pad its electronic. If it has knobs it has a separate defrost and thermostat and are electro-mechanical)
If electronic Your control board and possibly defrost control are out.
It would more likely be the sensors going to the board(s) It will both sensors have the possibility of causing your problem. 1 will control the run of the compressor (and this one could and probably is connected to the inside coil) and 1 will control the air damper tween the refdg and freezer compartments, and may turn on the inside fan operation too.
(this would be my first suspect if these are degrees numbers). Look at the thermostat control see if it is attached to the indoor coil (usually the tube leavign the indoor section. If its not attached its not sensing the coil temp and when goes into defrost wala its not senmsing temps like its designed to do. Look for a broken clip or possible a plastic wire tie that holds this sensor in place.
Please get back to me with what you see - find on this look up.
Posted on Mar 18, 2009
Sea Breeze
  • 4655 Answers
SOURCE: 3 YEAR OLD FRIDGE. DEFROST PROBLEM. FREEZER NOT
Your refrigerator has a defrost timer located inside the fresh food compartment if bad this will stop the defrost, I did not see a circuit bort for the model ED5FHEXMQ Make sure your model is correct because it will mislead any attemp to give help, Thanks, Sea breeze,
http://servicepartstec.blogspot.com/
Posted on Mar 27, 2009
How do i fix a whirlpool side by side fridge freezer. every two weeks i need to defrost, I have changed heater bar and have changed the bi metal thermostat, where is the defrost timer,
Shireen,
Some models have the defrost timer built into the control board. I worked on one that the control board was in back down near the compressor. I would suggest finding your wiring schematic and check it to see if that is the case. Hope this helps!
May 27, 2015 | Whirlpool Refrigerators
Hi Guys, I have a small fridge and it is having
Change the defrost timer in the control box
Nov 01, 2013 | Refrigerators
Frigidaire FRT04L5DM works about 1 week then
sounds like compressor is over amping, check condenser coil ,botom of fridge, make sure its clean, also check contactor coil and points, check fan in freezer if it does not blow strong, u will get ice build up, also turn thermostat from cold to coldest and back to see if the compresor and fan shut off by the control
May 22, 2010 | Refrigerators
How do I as a tech put this fridge into defrost Model# PHS69EJSS2. Ice is forming on the back wall of the freezer and it is also cutting off air supply to the fridge side.
sounds stupid but i would just unplug unit and do a complete defrost/dry out/clean,then leave for a week on full cold.to see if any other problems exist.....also check door seals for air tightness .
Apr 12, 2010 | Frigidaire Pro PHS69EJSS Stainless Steel...
Refrig not getting cold ......frigidaire side by side........6yrs old.....freezer temp is fine.......vacuumed coils and rear of fridge...cleared of all collected dust
when you open the freezer door do you hear the fan blowing,could have a bad evap fan motor,also remove the second bin from the bottom and touch the back wall,if there's snow or frost there you have a defrost problem,could have a bad adaptive defrost board in the fridge section or a bad heater,defrost thermostat,take off the back wall inside the freezer,melt out all the ice with hair dryer,check the heater with a meter and t-stat,you should change out the thermostat anyway,you can cut the wires close to the t-stat,connect the wires so you bypass the t-stat,if the heater doesn't come on change out the adaptive defrost board,i think you click the lite switches 5 times to make it go into defrost,if it doesn't it's probably the board,look at the tech sheet behind the bottom kick plate,hope this helps
Mar 20, 2010 | Frigidaire FRS26H5AS Side by Side...
Kenmore side by side - 10653293201 - freezer frosting up so fridge gets no cold air through vents. Just had control board replaced less than a week ago.
The defrost is not working. Since you changed the board, I would say it is the defrost heater or the defrost bi-metal. You will need a volt meter to verify the solution.
Sep 22, 2009 | Refrigerators
How do I fix my frigidaire fridge the problem is the freezer ices up and no cold air blows into the fridge
Change out the defrost timer and defrost bimetal in the freezer. If yours is controlled by a control board then change the board and the bimetal thermostat in the freezer
Sep 05, 2009 | Refrigerators
Frost on the back of the freezer and temps too high
> I can't locate the light switch
He may have meant the interior light switch that is operated by the door(s).
That is normally an exposed button along one side of the door frame.
Jul 19, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Warm Fridge
the defrost timer/ board is getting stuck in defrost and when you unplug it and plug it back in it resets the defrost timer/control board. you may need to replace the defrost timer/control board.
Jun 19, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Samsung Fridge side by side
It sounds like you have a defrost problem. This will either be the defrost heaters the defrost thermostat or defrost timer. In order to check the heater if you are competent enough you can check that you have resistance across the heater. Alternatively you can rotate the timer (normally in the fridge section abov the thermostat control) around to a defrost cycle (you will normally hear a click) and check to see if the defrost heater kicks in. Please note the cabinet has to be cold in order for the heaters to work. The defrost sensor should also have zero resistance across the terminals when the coil is cold. Please do no attempt the above unless you are practically skilled. A good fridge guy should be able to quickly identify the problem and remedy it. Defrost heaters are generally the first part to fail. Hope this is of some help.
Sep 10, 2007 | Samsung RS2630SH Side by Side Refrigerator
Frigidaire FRS6R5ESB Logo
65 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
