Question about HP DesignJet 450c InkJet Printer
Request for designjet plotter info
What's the recommended replacement model for a designjet 455ca plotter?
This is a wide-format engineering plotter.
My hp 450c plotter works properly in vista. First I' ve tried unsuccesfully to add new printer through windows menu. Then through Autocad menu (plotter manager) I added the specific plotter.
Posted on Jul 15, 2008
Z6100 banding verticle in black
When you banding vertical do you mean Across paper feed direction OR With paper feed direction?
If its across the feed direction the chances are thje issue remains with the individual printhead, Print out a quality maintenance print to find which Printhead is not working as well as wanted, then replace ( or clean using the plotters control panel under image maintenance.
Errors along the feed direction can be down to Software/ Main Pca /
Mar 11, 2014 | HP DesignJet Z6100 Wide Format InkJet...
Trailing cable burns
The smoking and melting cable are the result of a short cicuit.
The problem is going to be determining which end the short is occuring on. It most likely is the carriage end of the cable that is the culprit. Most likely you will need to replace the carriage assembly and of course the trailing cable as the new one may have also been damaged.
You may need to use your fingers to check if the top of the carriage assembly (where the cable connects) is also getting hot (warmer than normal).
C7769 60376 DesignJet 500 800 Print head carriage assembly C7769 69376... Trailing Cable for HP DesignJet Plotters Wide Format Printers
Jan 29, 2014 | HP DesignJet 500 InkJet Printer
Quality marks on a HP wide format
Ck to see if the "spittoon" is full. This is the box on one end (depending on model, that the plotter uses to clean the print head nozzles.
The newer plotters use pigmented ink which builds up in the "spittoon" and forms what looks like a small mountain of gunk. When the carriage assy passes over this, it picks up a little bit on the print head and bottom of the carriage assy and lays it down on the paper.
You can remove and clean the "spittoon" but it is a real mess and replacements are not very expensive. Remember to clean the bottoms of the print heads and carriage assy when you perform this repair.
May 28, 2013 | HEWLETT-PACKARD Hp - DESIGNJET Z3200 24IN...
Hp design jet 500 error code 5613?
System Error: 56:13
Problem
Description:
Error in the Drive Roller Encoder Sensor quadrature.
Corrective Action: Try the following:
Switch the Printer Off and wait a few minutes. Switch the Printer
On again and check if the Error Code has disappeared.
If the Error Code continues, replace the Drive Roller Encoder
sounds like the media motor encoder is dirty or has failed , there are videos on you tube on how to get to the sensor ,OR if your not up to it I would recommend Belmonte Business equipment as being much cheaper than HP to resolve your issue
Nov 29, 2012 | HP Hewlett Packard Designjet 500 42" Wide...
Cannot find driver for my 750c for windows 7 how can l install my 750c to windows 7
There are free software you can download for this designjet 750c by finding at websearch like yahoo.com or msn.com. Just type the driver name for this printer and you can download it for free. Most of the printer driver now can be downloaded online with free cd key. Just let it try. or Maybe the printer you are installing is not compatible with windows 7. try to read you printer's user manual.
Nov 11, 2010 | HP DesignJet 750c plus InkJet Printer
How can I replace the belt for the ink carriage
Here is an HP Support Forum where a user has posted a detailed procedure for the belt replacement.
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=846691
The Service Manual is needed. It's available at:
http://www.hylink.com/PrinterManual.html
Designjet 430, 450, 455C - Service Manual
DesignJet 430, 450C, 455CA - Quick Reference Service Manual
As mentioned, it's a delicate and time consuming operation. I replaced my belt two years ago with little problem. (Be sure to clean the old degraded belt gunk off the drive pully too!)
It's not a job for "Beginners". More like "Intermediate" or "Advanced".
Good Luck!
This is the part I ordered. It was $15
WARNING: THIS IS FOR THE "E-SIZE" MACHINE.
If you have the smaller one, you must research the part number for that.
Carriage belt (E-size) - Long/wide belt attached to the carriage 15.00 0.00 15.00 1 15.00
Oct 21, 2009 | HP DesignJet 450c InkJet Printer
HP Designjet 500ps 24" Plotter- screen says to replace printheads
Printheads are available everywhere, you replace them your self. Machine will usually indicate just one bad print head at a time.
Dec 22, 2008 | HP DesignJet 500ps InkJet Printer
HP 755CM
**you need a good driver:
whilst ordinary printer drivers may treat plotters like very large, slow, desktop printers, our driver uses the native vector graphics capabilities of your large format plotter to render CAD and line drawings at maximum speed.
Go here
www.plotterdriver.it
Third Party Product;
and they are those recommended from HP, Autodesk and work great with Corel Draw, Power Point, Micrografx Designer, EXCELL, Lotus, Word and all vectorial-oriented Windows applications, under W95, W98, WME, NT 4.0, W2000, WinXP, Win VISTA.
You'll find all informations
Aug 08, 2008 | HP DesignJet 750c plus InkJet Printer
My plotter does not recognize always that a printer cartridge is seated and will print without cyan
A model # would help. HP makes cleaning kits for the majority of DesignJet plotters that includes a tool to clean the contacts in the carriage that holds the printheads. Other than that, you could try a chamois swab (I think you can still get them at Radio Shack) dipped in 91% isopropyl alcohol (shake of the excess) and try cleaning the contacts that the printhead comes in contact with. Oxidation and/or ink can cause a bad connection that gives you the no printhead error. Reply with the DJ model # & I will be happy to get you the cleaning kit part #. Here is link for to the cleaning kit for the DJ 330, 350C, 430, 450, 455CA and 700.
http://www.hp-bazaar.com/cartridge.php?product=HP-C6247A&type=HEW Hope that helps you...
May 30, 2008 | HP Office Equipment & Supplies
HP DesignJet 450c InkJet Printer Logo
223 people viewed this question
Seeker5211
Seeker5211
