Question about Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator
First discovered icy build up on back wall of freezer and on some containers that were in that area. Then got sour smell in refrigerator so thoroughly cleaned the entire refrigerator with the smell returning. The refrigerator doesn't seem to be cold enough. I had to throw several vegetables away that were there for less than a week. Happened 2 weeks in a row. Yesterday, discovered that from the ceiling of the refrigerator in the back, there is a frozen ***** that is starting to drip. Looks like it could be from the freezer??? I upped the temperature in the refrigerator slightly yesterday but everything seems to be the same.
  • lindast590 Jan 06, 2011
    Good morning helpmech,
    I did as you instructed. I just plugged the refigerator back in last night and will be putting food back in later this AM.
    Just a few more questions if I may. If there is a defrost problem, how long does it typically take to show signs of such again? I'll certainly be looking more closely at this point but just curious and will be helpful for planning purposes. Also, any idea on how much, approximately, it'll be to get this fixed???
    Thanks for your help,
    Linda
  • lindast590 Jan 12, 2011
    Dear helptech,
    Well, my refrigerator is finally fixed - or I think so - so far so good. I truly believe we pinpointed the problem. It ended up being the evaporator motor which we replaced yesterday. Unless something burnt out that motor because something else is wrong that's effecting that part, I should be good to go. Thanks for your help. Just thought I should get back to you with this info since it wasn't a part you listed that could have caused the problem I was experiencing.
  • Kenmore Master
  • 5,370 Answers
This problem is mostly due to defrost system not functioning as required.The ice is getting frosted and this is clogging the ventilations but this frost is not getting defrosted.The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the refrigerator section and the refrigerator section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. Now this problem which you mentioned. In this problem the freezer is getting cold but its not defrosting.so the frost build up gets more and more.But the fridge section is not getting cold.And the defrost is not functioning so the water leaks when suddenly the defrost starts for few minutes. ---------------- Before replacing any parts or doing any troubleshooting its advisable to do a manual defrost reset procedure.:-----
The manual defrost reset procedure is as follows: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. The defrost board and the defrost thermostat/heater is not functioning properly and it has to be checked and replaced.You can get the required parts from online sites like:--- www.repairclinic.com or from searspartsdirect online site.---------This will help.Thanks.Helpmech.
Posted on Jan 03, 2011
  • raj somaiya Jan 06, 2011
    In about next 10 hours,you will come to know,that there is same problem.The frost will again start building up and same problem will be seen.But if the manual defrost procedure has solved the problem.Then after 10 hours,there will be no leak or over ice frost collected problem see.But after 4 hours the unit will get the cooling cycle started.Then in next 6 hours it will show the symptoms of problem,if it still exist.Now if the problem is there,then cost of thermostat will be near to $20.Cost of heater will be near to $70 and cost of defrost board will be near to $120.But first it has to be started by just replacing thermostat.If still the same problem.Then heater and defrost board are to be checked.And the faulty one has to be replaced.-------------------- This should help.Thanks.Helpmech.
  • raj somaiya Jan 12, 2011
    Thank you very much for this update.thanks.
I have an amanarefrigerator freezer that is emitting a horrible sour smellHave done everything I know how pleasetellme what could be wrong
Rotten Food Particles--Soured Dairy Products--2 of many--will have to be taken apart to be checked.
Feb 27, 2015 | Refrigerators
MFL62184410 fridge has a sour smell
Try using an open box of Arm and Hammer baking soda and let it stay in there for awhile. It may absorb the odor.
Dec 02, 2011 | LG LFX28978 (27.6 cu. ft.) Bottom Freezer...
I think my evaporator fan is out everything in fridge is warm to touch and ice is built up on freezer wall at rear of freezer and ice cubes will not freeze solid.also do not hear fan running any more
Hi there
I have found some stuff for you to read hope this helps you. Let me know how it goes.
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas: Evaporator coils Condenser Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt. Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Thank you for writing to fix ya.
Best Regards Richard
Dec 27, 2009 | LG LRBN22514ST Bottom Freezer Refrigerator
Not cooling enough
I had the same problem and I discovered it was the defrost element that was shorted out which keeps the ice from building up located behind the back freezer wall.
Aug 09, 2009 | Refrigerators
Fridge-side not cold enough
Evaporator coils
Condenser
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
Jul 29, 2009 | Hotpoint HSS25GDMWW Side by Side...
Unknown water leak from the ice maker, thus freeze build up
the frost on the back wall tells me its not defrosting.this will happen 2 to 3 times a day.if defrost system working their would not be frost.hencethe term frostless.to con firm this sence you defrosted this unit it should work in all ways for a day or 2 lets stop here and you let me know what happens
Dec 31, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
My subzero fridge is not cooling like it should. milk will sour in about 2 days. Im trying to find a list of dealers in the Brewton, Alabama area. Im having a hard time finding someone to do a service...
Your issue is;
"my subzero fridge is not cooling like it should. milk will sour in about 2 days. Im trying to find a list of dealers in the Brewton, Alabama area. Im having a hard time finding someone to do a service call, thanks, Daniel"
Before contacting a servicer, you may want to check on a few simple things first.
1. Are all doors closed and sealed tightly all the way around?
2. Are the cold controls properly set or adjusted high enough?
3. Is the condensor coil clean?
4.Frost build up in freezer on the back wall. This issue would be a defrost cycle problem and may require a technician.
This link should allow you to connect with a local service agency
http://www.magicyellow.com/category/Appliances_Household_Major_Repair/Montgomery_AL.html
This link may also be of some help.
http://www.constructiondeal.com/service/Appliance-Repair.552.html?rid=5&aid=552
Please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 24, 2008 | Refrigerators
WHIRLPOOL 25.3 CU.FT MODEL ED5FHEXNT00
If the frost is on the back wall of the freezer then you most likely have a defrost problem or a bad evaporator fan motor.
Jan 08, 2008 | Whirlpool ED2FHEXN Side by Side...
Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator Logo
106 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
