Have a Kenmore Elite He3T washer. When using the Cold/Cold cycle we are getting hot water instead of cold water.
  • Brian Tubbs Jan 03, 2011
    This is a problem on an older washer that has been working fine for many years. The problem just started so the hot and cold are not inverted.
  • Washing Mach... Master
  • 19,396 Answers
Hi.
Check the water inlet at the back of the appliance. If it is dual inlet, the hot and cold are inverted. If this is single inlet, then you are probably connected to the hot instead of hot water line.
Regards.
Ginko.
Posted on Jan 03, 2011
  • Ginko
    Ginko Jan 03, 2011
    hi.
    In that case, if inlet is dual (hot and cold hoses) you have an inlet valve that is stuck open.
    If machine is single inlet (self heating), then you have either a plugged element or a defective control board. A plugged element means that the heating element stays on all the time.
    I think that all the HE3 have dual inlet. try closing and disconnecting the hot inlet and see what happens.
Kenmore Elite front loader has hot and cold water reversed
I assume you verified the hoses are not crossed at the back of the machine??
:D
A better troubleshooting method is to call for a cycle of hot water and check that the proper solenoid on the water valve is being sent the signal. If it is, the water valve should be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore HE3t Frontloader Fills Up With Water After Cycle
inlet valves have possibly gotten dirt in them and need replaced . quick fix , is turn the water valves off behind the machine
Nov 07, 2017 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore he3t door locked cant reset or open
Kenmore HE3t sanitary cycle setting has changed. Water temp selection only allows Hot/Cold selection but should offer the Extra Hot selection. All other settings test out properly. Is there a way to reset factory settings for cycles?
Jul 08, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washer fills with water when the machine is not running
Either the hot or cold water valve is not closing completely. In either case, the mixing valve assembly will require replacing.
Feb 04, 2009 | Kenmore 42924
Should the washer be hot after the rinse cycle?
Try cycling a cold/cold wash and see how that comes out.. if it comes out hot then your water inlet valve is letting hot water in when it shouldn't.. conversely, try cycling a hot/hot wash and see that it does indeed come out hot... ( quick tests to verify performance)..hope this helps.
Sep 18, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore elite HE3t code problem
check your water supply make sure that you have both hot and cold water on at all times. Pull the hoses off and see if the screens on the water valve in the back is clogged.
Aug 10, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer
sounds like you have a bad water valve,,either that or a bad water temp select switch,(doubt that). way more common is a bad water valve.
Mar 22, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
