Question about Intel D845GVSR Motherboard
Power switch is not working properly - Intel D845GVSR Motherboard
    Problem Solver:
  • 10 Answers
U can change the cabinet,,or u can use a separate switch for power.try it.
Posted on Mar 29, 2011
No brake lights when brake pedal is pushed
check first wirring is work properly, and check lamps are work properly. If not then change lamps.If works properly then check connectors, and paddle switches are work properly. If not then change the connector and paddle switches.
Aug 26, 2012 | 1995 Toyota Camry
Power windows locks and mirrors
Sounds like the master switch is not plugged in properly, this is the switch in the driver's door.
Jun 07, 2012 | Cars & Trucks
Compaq presario desktop will not turn on
Check the power cables if it is working properly.
See if your AVR didn't blow a fuse or the switch is working and the led light are lighted or is powered on.
Test your pc's switch if it is still established contact and not unpluged from *********** board and is working properly.
Test your power supply by unpluging all plugs that is connected to your motherboard and try to short out, the green and black wire from pin 4 and 5 see picture below. Just put a small length wire at pin 4 and five and you'll be able to know if it is working just fine.
Connect it to your computer again if it is working properly.
Press the power switch.
If it still is not working, try to disassemble your processor, then press the power switch.
If it still did'nt work or still doesent turn on, then your motherboard is the broblem and needs to be replaced. Have a nice day friend, and hope this could help you analyze.
Aug 19, 2011 | Compaq Presario 5000 PC Desktop
Power switch not working.
Hello, we are not sure about why the power switch is not working, maybe busted, maybe dirty, or simply not responding, make sure that the cable is properly seated, make sure the power cable is working properly as well, if not you can bring it to local repair center. Thank You for using Fixya.
Mar 06, 2011 | ViewSonic VX2035WM LCD Monitor
My HP laptop can not switch on and people told me that the motherbord is not working
The power that is supplied in motherboard might have not working properly. I mean to say power supplier is not working properly.
Jan 17, 2011 | HP Computers & Internet
Samsung samtron monitor does not work
Please check whether the power cable is properly inserted...
The power button of this model fails with time.You need 2 press it tightly and hold it till the LED is on....
try this...
Hope this helped...
Dec 21, 2009 | SAMTRON 55V 15" CRT Monitor
My Backup light are not working on my 98 Pontica Grand Prix.
First check for power at the light sockets and make sure they are properly grounded. The neutral start switch should also be the backup light switch (located on the transmission at the shift lever). If vehicle is starting in the correct shift positions, likely it is adjusted properly. However, have someone watch the backup lights and move shift lever through the gears. if while moving lever lights flash, switch may be slightly out of adjustment. Pink or dark blue wire should be power supply to switch, light green should send power to lights.This is powered by a 15a fuse on the fuse panel.
Apr 06, 2009 | 1998 Pontiac Grand Prix
Maytag washer fills but doesn't agitate
I took the control panel off and played with the lid switch a little and found the agitater would work intermittently. I bypassed one of the switchs (it appeared to have two switches mounted on a plate) and the washer would work properly. I used information I found on RepairClinic.com to help understand my problem and see a picture of the switch for my washer, so I contacted them to purchase the part. I installed the lid switch assembly and it now works great.
Mar 06, 2009 | Maytag LAT2300 Top Load Washer
Intel D845GVSR Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
