Question about Flotec FP0S3200A-01 1/2 HP 3,200 GPH Plastic Sump Pump
I have a flotec model 1m03w fp053200a-o8 1.5 hp sump pump. It run all the time now, the only way it shuts off is if its unplugged. Do I need to replace it, or can it be repaired? Thanks for your time
  • 927 Answers
If you have the pump pictured, there is a float switch in the big round thing that floats. When this float drops, the switch should open and pump should shut off.
Make sure that the pump plug is plugged into the piggyback type float plug.
Posted on Jan 03, 2011
Sump pump doesn't shut off
The floats could be binding on the pump or may have developed leaks so they don't float. Another possibility is that the switch mechanism is defective
Apr 01, 2013 | Flotec 1 3 HP Submersible Sump Pump -...
My flotec E100ELT Intellishield pump control will not start unless I unplug power cord from pump control then replug to activate pump and high water alarm does not sound.
pump works fine..when plug in directly..sensor unit does not work all the time and is flooding the basement..how can i resolve this...where can i get just the sensor replaced
Jan 31, 2013 | Flotec 1 HP Electronic Sump Pump E100ELT
Pumb only pumps a small amount out of the basin. Float needs adjusting to go all the way down and empty the basin. How do you adjust the float/bulb to travel farther down without shutting off after only a...
Flotec website shows several submersible sump pumps, and pump types:
http://www.flotecpump.com/asp/productapplication.asp?AId=28
Click product, then click on 'parts and literature' to access manual
Here is a Flotec manual:
http://www.flotecpump.com/pdf/FP525%2811-1-06%29.PDF
Manual for this type of sump pump says:
Quote from manual: Automatic float switch is sealed and factory adjusted for
most home sumps. Turn-on water level is 10" - 12" above
pump base. Turn-off water level is 4" - 6".
The manual also says that running the pump when dry will ruin the seals.
This implies that the water level setting is set so the seals will not be damaged
You might be able to dig the sump deeper, but I don't know if that meets your objective.
Oct 24, 2010 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
Flotec Float switch did not automatically shut off,enginburn out
Hi Lamont .. I would first check test the float switch and make sure that it is faulty, set it up in a tub of water and manually move the float switch. see if it cycles on and off. sometimes the float will get hung up on its support or on the edges of the sump pit. If the float switch is faulty then YES it can be replaced,. try a building supply store like home depot or the pl;ace where you got the switch originally.
Please Vote !!
Jun 01, 2010 | Flotec 13 Hp Automatic Submersible Sump...
I have a broken sump pump, Flotec model # FPOF360AC
Same pump, same problem. H/D sells the pumps, but no parts. Here's a link to a vendor of Flotec parts. http://www.pumpvendor.com/Flotec_Parts_List.html
Apr 01, 2010 | Flotec Simer/Flotec/Omni 2105 Swimming...
I have a Flotec FP 4022-10 3/4 hp shallow well pump, it runs all the time and the water pressure is low to the house. I checked for leaks in the system and found none. I also checked the bladders on the...
The foot valve (one way valve) is either very dirty and in need of cleaning, or it is defective and should be replaced. Don't wait, you're wasting a heck of a lot of electricity and wearing out the pump much faster than you should.
Feb 10, 2010 | Flotec 3.4 Hp Floodmate Submersible Sump...
Switching off too soon.
you don't need to replace the switch just raise the upper stop up higher so the float can go higher before turning the pump on, it should have a rubber gromet on it slide it up the rail
Jun 21, 2009 | Flotec 3.4 Hp Floodmate Submersible Sump...
Flotec FP0S3200A-01 1/2 HP 3,200 GPH Plastic Sump Pump Logo
320 people viewed this question
Top Flotec Electrical Supplies Experts
 Kenneth
Kenneth
Paul Nielson
Paul Nielson
Are you a Flotec Electrical Supply Expert? Answer questions, earn points and help others
