Cannot get the window to open so I can change my security code. Ideas?
  • 4,281 Answers
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Jan 03, 2011
Reset password on wireless router
That more than likely mean you have put the password in wrong or you are using the wrong authentication type.
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the WirelessNetwork Connection and select Properties. When the Properties window openclick the Wireless Networks tab. Click on the SSID for your wirelessnetwork that you connect to and the Properties window will open. You canchange the Authentication Type to match the type set in your wireless routerand you can also change your password or Network Key to make sure you have itin correctly.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left ofthe open window and click Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center thenlook to the left and select Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
Jun 08, 2012 | NetGear N300 Wireless Router
Thinkpad having limited to no connectivity
More than likely your password is wrong or the Authentication Type such as WEP, WPA, WPA-2 is wrong.
Click Start/Control Panel/Network Connections then Right Click on the Wireless Network Connection and select Properties. When the Properties window open click the Wireless Networks tab. Click on the SSID for your wireless network that you connect to and the Properties window will open. You can change the Authentication Type to match the type set in your wireless router and you can also change your password or Network Key to make sure you have it in correctly.
Click Start/Control Panel/Network and Sharing Center then look to the left of the open window and click Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
Click Start/Control Panel/Network and Internet/Network and Sharing Center then look to the left and select Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
May 11, 2012 | Lenovo ThinkPad T420 Notebook
Dell inspiron 8000 password authentication system
Are you talking about the authentication process on trying to connect using wireless?
That means you probably don't have the password or theAuthentication Type set correctly.
May 10, 2012 | Dell Computers & Internet
Cannot get the internet to work
That means you probably don't have the password or the Authentication Type set correctly.
May 08, 2012 | Computers & Internet
How do I get my router codes?
From a wired connection, open a browser window and enter the IP address for your router (by default it is 192.168.1.1 ) which should bring up a window requesting a user name and password. Enter "admin" for both, and that should get you into the settings.
If you think it may have been changed, you can look up your IP address by opening a command prompt (click "run" and type "cmd" in the prompt.
When the window comes up type in "ipconfig/all" look under your local area connection for default gateway. This is your IP address for your router.
A word of warning: Once you enter the DLink screen, you are now in the settings for the router itself. If the router & wireless are working, don't change any other settings for PPOE, bridging, or PPP settings, etc. because you may accidentally make new problems for yourself.
The settings for wireless including security codes are under "Wireless settings". From here you can view or change the security codes, turn on or off wireless networking. You can click the manual settings to see the current security password, or to make changes to it. Naturally, changing the password will also require the new password to be entered on any other devices that use this connection (a tablet or laptop, etc.).
That should get you going. If you have further questions etc. feel free to post back.
Please also remember to leave feedback so I can get credit for helping you.
Thanks,
Vern
Jan 07, 2012 | D-Link Computers & Internet
I can't change my security code hw can i change it ? it is 12345 the dafualt one , and i want to change it how ?
I suggest you leave the security code alone, it is used to clear the phone call logs etc.
I recommend to put a pin code on the SIM card to lock your phone's keyboard. When you open your phone or unlock the keypad to access the phone's menu etc. then you need to enter the 4 digit pin code. This also prevents anyone accessing your phone unless they have this pin code.
Sep 09, 2011 | Nokia Classic 2700 Cell Phone
When i update my panda internet security 2010 i take an error code 401 i have windows vista home premium
The error code 401 is due to a conflict in Vista's virtualization system. Here's how to fix this: Click on the Windows logo at the bottom left (Start), write APPDATA in the text box and click Enter. On the window that will open go to the Local > Virtualstore > Program Files. Delete the folder called either Panda Software or Panda Security. Open the antivirus. Enter your update details again and update your security solution.
Jan 28, 2011 | Encore Panda Internet Security 2010 3...
I forgot my security code to open my pda
Hi Friend,
Please follow the steps in order to retrieve the security code:
1. Click Start \ Run \ type cmd and hit enter
2. In the black window type ipconfig and hit enter.
3. Note down the default gateway and close this window.
4. Open the web browser and type the default gateway and hit enter.
5. If you have not changed the default password then type admin as password and leave the username blank.
6. In the router setup page click Wireless and then click Wireless Security.
7. Note down the pass phrase or the shared key.
You can use the key to connect the wireless devices with the router.
I hope this will resolve the issue.
Regards
Chiranjeet
Dec 09, 2010 | Computers & Internet
My security code and i want to unlock it
Enter the lock code instead of the security code. After then to change the security code.
  1. Go to menu and there open settings.
  2. There open security settings.
  3. There will options such as change lock code or change security code etc.
  4. If you have forgot security code then you can't change it, better change lock code as your desired password.
  5. To change first get into change lock code and enter old lock code and after that input new password and its all done.
Aug 14, 2009 | Lands Phones
Security code for 6500 classic
go flash the phone it will free you frm code request ok
Jul 10, 2009 | Nokia 6500 Slide Cellular Phone
Computers & Internet Logo
David Payne
David Payne
