SOURCE: riello burner will not pump oil to nozzel to burn.
Revisit the photocell:
1. Check if you connected the socket end, into the two pins properly, as it is possible to miss a pin.
2. Try to borrow a working photocell or use yours in another burner to make a determination.
SOURCE: Riello oil burner RDB with
If the moror just humes then locks out, more that likely the capacitor (small white cylinder like object below control box), get yourself a 5uf capacitor, 2 wires, jobe done!!
SOURCE: Riello oil burner RDB Hi everybody i have a
does it have the air damper installed? You can add a magic heater to the flue and dump heat into your basement.. thats maybe 5 to 10 percent more efficient
