Question about Whirlpool GGQ8831L Gas Dryer
Does not heat
Igniter works but gas does not always come on.
  • wbaker5286 Jul 09, 2008
    my husband was able to fix my dryer in one afternoon, and with only trip to the store! thank you for your help.
  • Anonymous Sep 07, 2008
    my dryer will not get any heat
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance. Clicking on the underlined links will take you directly to that page.
If your dryer doesn't heat, check this: Temperature Selector Switch, make sure a positive heat selection has been made. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3479&PPStack=1
This link will take you to the breakdown, disassembly, and part description page.
http://www.repairclinic.com/0100_14.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
When the thermostat calls for heat sometimes the gas pack works fine and sometimes it doesnt work at all . the inducer motor comes on but the burners dont ignite . what could be the problem ?
Could be the igniter or the thermocouple. The blower has to start first and it does but it will run on endlessly without further action unless the igniter heats the thermocouple to open the gas valve and fire the burner.
Dec 15, 2013 | Carrier 3 Ton 13 Seer Commercial Gas Pack...
Oven slow to start heating (sometimes) not always. But once the gas burners ignite then the oven heats up quickly
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
May 11, 2010 | Jenn-Air JGS8750ADS Gas Kitchen Range
Gas only comes on sometimes propane tank is full
check the voltage to the gas valve in cycle if there constant voltage there during ignition then change the gas valve
Jan 14, 2010 | Dryers
Gas dryer-no heat. whirlpool lgr4634eq3. can i
Advise your landlord of the issue and follow his/her instructions.
I have provided some information on trouble shooting the dryer No Heat issue.
Below is a checklist provided by; www.repairclinic.com.
They also provide repair parts, disassembly procedures and diagrams for DIY repairs.
Firstly, ascertain that you have made a positive heat selection, then read on.
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Jul 12, 2009 | Whirlpool LGR5636L Gas Dryer
Gas dryer will not heat up
Below is a checklist provided by; www.repairclinic.com. They also provide repair parts, disassembly procedures and diagrams to assist with all your DIY needs.
Firstly, ascertain that have made a positive heat selection, then read on.
Igniter
Gas valve coils
Thermal fuse
Jul 12, 2009 | Maytag Dryers
Maytag performa dryer will not heat up
maytag performa dryer Model PDGT910AWW
"No Heat" complaint.
Firstly, make sure that you have selected/ascertained a "Heat" setting, then read the checklist below provided by; www.repairclinic.com
They also provide disassembly diagrams and repair parts..
Igniter
Gas valve coils
Thermal fuse
Jul 06, 2009 | Maytag Dryers
Maytag neptune (gas dryer) just stopped heating up...was working fine yesterday. The dryer is 8 years old...never a problem. Does the heating elements need replacement?
Gas dryers utilize a gas valve, ignitor assembly, and a series of coils mounted on the gas valve to provide heat and safety. The gas valve coils are the usual suspect when it comes to a "No Heat" complaint. I have provided a checklist from www.repairclinic.com, for your convenience. They also provide disassembnly diagrams and repair parts.
Firstly, ascertain that you have made an adequate "Heat" selection, then read on:
Igniter
Gas valve coils
Thermal fuse
Jul 06, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore elite gas dryer doesn't always heat or dry clothes
An intermittent heat problem is probably in the gas igniter circuit. I would first check the flame sensor next to the igniter for dust on the glass cover. If you have a trouble door, you can see if the igniter is working. Sometimes gas valve controls will fail. If you have to replace the whole control, check inside the plumbing for filters.
Apr 22, 2009 | Kenmore Dryers
Kenmore 110 gas clothes dryer heats for 20 min then needs to rest for 20 mins before heating again
Cause 1Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer's heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Parts Cause 2Gas Valve Solenoid
Gas dryers have two or more gas valve solenoid coils. The gas valve solenoids open the gas valve ports to allow gas to flow into the burner assembly. If a gas valve solenoid fails, the dryer won't heat. To determine if one or more of the gas valve solenoids has failed, check the igniter. If the igniter glows and goes out but does not ignite the gas, the gas valve solenoid is defective. If one or more of the gas valve coils are defective, we recommend that you replace them as a set.
Parts Cause 3Igniter
The igniter uses heat to ignite the gas in the burner assembly. If the igniter is not working, the gas will not ignite, preventing the dryer from heating. To determine if the igniter has burned out, use a multimeter to test the igniter for continuity. If the igniter does not have continuity, replace it.
Feb 16, 2018 | Dryers
Does not heat
There is NO starter on a gas dryer burner assembly. The burner is controlled by gas valve coils and a glow bar igniter. Once the igniter reaches the appropriate current level, the gas valves open and you have ignition. The common problem is a weak igniter. You need to do a current measurement to make sure the igniter is within tolerance. If it is within specs, then I would agree with docjohn174 about replacing the coils. If its not within specs, you need to replace the igniter. Depending on the type of igniter you have, the current rating is as follows:
TWO BASIC IGNITER TYPES:
Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) – needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
I still need an accurate model number in order to confirm WHICH type of igniter you have.
Oct 03, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool GGQ8831L Gas Dryer Logo
54 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
