Question about Lakewood 200I Floor / Box Fan
How do I test the Electric current in the Lakewood Box Fan
Please Help.I have a Volt Meter that my husband uses, but I don't know how it works. Would you suggest in words and pictures how to test the fan. It totally doesn't work. I took off the plastic cages (front and back) and washed them with just water. I put these in the sun to dry. I have fixed other things, but need to know how to use a volt meter, and how to get this fan running in good running order.
Thank you,
Nancy
  • 5,568 Answers
I haven't seen a single-function 'voltmeter' for a long time so I suspect it is a multimeter with volts (AC & DC), milliamperes and ohms functions, if not more.
The function you need is 'Ohms.'
This will have several settings and if it is as most low cost meters, it will have a '200' and a '2K' (or 2000) setting.
The range may be marked as 'Ohms' or might have the Greek letter symbol for this; Omega 'ω'
With the switch in the off position and measuring with the probes across the the AC prongs, you should get an overrange indication which will generally show as a '1' or '2' with no other digits and it may blink as well.
This should be the same as having nothing connected to the probes.
Connecting the two the two probes should display (depending on range setting) perhaps 00.2 to 00.6 on the lowest range and .000 on all other higher ranges.
Turning the switch to any running position should yield some kind of reading on the '200' or '2K' range.
If it doesn't, then either the switch or the motor itself is 'open' meaning that no voltage is reaching the motor.
Because of the low price of these breeze boxes, finding and buying either the switch or the motor is kind of futile; the switch, if you can find the typical 4-position type (Off, low, medium, high) will cost about half as much as a new fan, the motor likely more than the replacement fan complete.
Be advised that having the wrong setting and measuring across a voltage can cause the meter to fail forever.
Don't (!) set the meter to ohms or milliamperes (ma) and try to measure any kind of voltage.
The AC Volts setting is what you need for checking your receptacles, DC Volts for checking batteries for example and the Ohms ranges will be mostly used for problems such as you are having and checking fuses to see if they are blown or not.
The milliampere ranges aren't much use for household stuff and normally are for DC current only.
Hope this solves some mysteries for you ;-)
Posted on Jul 09, 2008
Have 2002 dodge dakota and brake lights don't work-have changed brake switch, checked bulbs, checked the 15 amp fuse and it's ok. what next?
Did you use a DVOM - digital volt ohm meter an test for B+ voltage to the brake light switch ? Who cares if the fuse looks good , if there is No battery + voltage on either side of the fuse it's not going to work . Looking at a wiring diagram to know which wires to check an using a volt meter to test is the proper way to diagnose .
Electric Testing Techniques You Need to Know
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info. year , make , model an engine size. Under system click on lighting , then under subsystem click on exterior lighting . Click the search button then the second blue link, scroll down to the #4 diagram .
Mar 14, 2018 | Dodge Cars & Trucks
2000 mercury mountaineer brake ligts dont work on passenger side only
Do electrical circuit testing using a wiring diagram ,so you know which wires to test. Do you know what a DVOM - digital volt ohm meter is ?
How to Use Multimeter to Troubleshoot Common Problems
Free wiring diagrams at https://www.bbbind.com/free_tsb.html
Enter vehicle info. year , make , model an engine size . Under system click on lighting ,then under subsystem click on stop lamps. Look at any place there is a splice . an check for B+ voltage .
Mar 11, 2017 | 2000 Mercury Mountaineer
Heater,ac fan wont blow.
Could be the blower motor , The blower motor control switch or a blown fuse , You would need a wiring diagram to test the circuit ! Do you have a DVOM - digital volt ohm meter ! Electric Testing Techniques You Need to Know Do you know how to use A DVOM
Oct 03, 2015 | Cars & Trucks
Starter help
Anti-theft system problem .Can't hook up the starter wrong , two wires ,one big one , one small one . Won't interchange .
Is there a little red light on top of the dash pad , does it flash fast when trying to start . Here is a web site for free wiring diagrams . http://www.bbbind.com/free_tsb.html Enter vehicle info. year make , model and engine size . Under system click on engine ,then under subsystem click starting .Click search button then the blue link .Do you have a DVOM - digital volt ohm meter ? Do you know how to use one . Test ,don't guess .
Oct 03, 2017 | 1996 Ford Explorer
How can I clean a Lakewood fan, mine is so filthy and I cannot get in to clean. My husband says it does not come apart.
ok here is what I found....there should be screws on the outside rim where the two fan grates meet....then dust the innerds with a leaf blower or a rag, then use brake cleaner spray to soften the greasy dirt that formed, and again a rag to wipe away any residue....hope this works, it did for me
Oct 25, 2013 | Lakewood HV-18 Floor / Box Fan
2002 ford explorer sport, turn signals not working, hazards not working, side brake lights not working, lights on dash don't light up. Light bulbs are good, just replaced turn signal switch and turn...
Did you look at wiring diagrams to see if all of these have anything in common ? Ground connection , B+ power supply etc..... Then testing the circuit's with a DVOM - digital volt ohm meter . Voltage drop testing .
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Did you replace the indicator flasher relay in AUX relay box 2 ?
Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info. year , make , model an engine size. Under system click on lighting ,then under subsystem click on turn signal lamps . Click the search button then the blue link.
Track it down , where do you have B+ an don't .
Jan 27, 2018 | Cars & Trucks
Need electric wire to plug into fan and then connect to electric outlet Where can I get one?
  • Lakewood is long out of business and a stock cord is going to be next to impossible to find. But I can help you save some money and some headaches trying to find a new cord.
  • If I remember right the 007 utilizes a simple two prong cord. The tip of the cord is simple the fatter end is your ground and the smaller end is the AC power feed. These fans don't draw to terribly much power either.
  • It is a rare occasion I would buy an original cord because they are so darn over priced. Here is what I would do.
  1. Go to your local hardware store and get a cord with a two pron tip on it. This may cost $6 top. Just a medium use cord will work for this fan.
  2. Now you will see the wires for the cord on the back of the fan motor. The hot wire is usually black (In the USA and Canada) The green wire is ground and the white wire is neural. (This is for a three wire setup. For two wire omit the white wire. The wires on your fan should be colored Black and Green. Just remember that black is the hot wire and the other is the ground.
  3. To make this less difficult the black wire off the fan will go to the wire that leads to the small end of the connector and the other wire (ground) will go to the wire (on the new cord) that tracks to the thick en of the connector. Placing your new cored flat and even makes this easier.
  4. You will need to soldier the ends (or crimp the wires together) and make sure you insulate them with liquid electric tape, shrink tube etc.
  5. Total cost should be less than $7.
  6. I did find one place that sells the 3 prong cord http://www.nelsonappliance.com/Power+Cords+for+Lakewood+model+MC42+Fan.html for the fans. If yours should be a 3 prong tip then this one will work too but if memory serves yours is a two tip cord.
  • If you have any questions or comments please feel free to ask but you won't find a stock cord just for this fan because they are out of business.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jun 18, 2011 | Lakewood 007 Floor / Box Fan
My lakewood electric heater plug gets hot and starts melting, I have to use a three prong adapter to plug this in..can u help?
Sounds like heat element is defective drawing too much current. Make sure you are not using an extension cord on this heater, it has to be plugged directly into wall socket. Post model number on here so we know what unit we are dealing with.
Oct 09, 2009 | Lakewood Oil-Filled Electric Radiator...
My lakewood HV18 just stopped. Spinning the shaft
I think you need to buy a new fan. Unless this thing cost several hundred dollars it isn't worth rewinding and a capacitor isn't likely to cause it to stop working, the cap is for STARTING it spinning anyway and sometimes they are used to HELP it run better, but it will try to run if you spin it and since your's does nothing, more than likely the windings are gone.
Sep 09, 2009 | Lakewood HV 18-c Floor / Box Fan
Lakewood 200I Floor / Box Fan Logo
144 people viewed this question
Top Lakewood Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
