Question about GE Heating & Cooling
Ge model # az32h12d5bm2 blowes heat for 2minutes then goes cold
Check your thermostat and mode selector setting. The thermostat setting should be set at "warmer" and your mode selector setting should be set at "low heat"
Posted on Jan 04, 2011
Simpson minimax dryer not getting hot does spin timer works will run for about 2minutes then blows fuse
It is most likely a failed heating element, when it attempts to heat it causes a short, blowing the fuse
Jun 05, 2016 | Dryers
Heat blows cold air front and rear when sitting still or @ low mph.
Usually a sign of low coolant or a blockage in the circulation.
Feb 26, 2013 | 2003 Chrysler Town & Country
All mechanical function work well except dryer will not heat up ,blowing cold air.Model DCLR333ETOWW GE
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 01, 2011 | Kenmore 62822 Electric Dryer
General Electric DVL223EB1WW Electric dryer no longer heats up. Still blows air, cold, but no heat?? Any suggestion?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 15, 2011 | GE DVL223EBWW Electric Dryer
I have a GE DPGT750 Gas Dryer. The dryer will not heat up. Air is blowing out of the exhaust outside. However, the air is cold.
heatman101
Aug 28, 2010 | GE DPGT750GC Gas Dryer
My GE Side by Side is not working wierdly. the top few shelves on both the freezer and refridgerator are not cooling but the bottom shelves are cold.
Check to see if your evaporator fan is blowing in the freezer, then check your condensor fan behind the back panel. If those are both running make sure your coils are clean underneath your fridge. Cold goes down heat goes up, that's why it is warm up top and cold down. Start there. Good luck!
Aug 21, 2010 | GE Refrigerators
Not getting heat from dryer
check the high limit switch and glow rod
Sep 15, 2009 | GE Dryers
Getting heat instead of cold
probably the evaporator is not good,and also there is no gas in the the circuit and when it blow air its only heat is coming out
Aug 22, 2009 | GE Zoneline AZ25E12D3B Air Conditioner
Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Jun 07, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
