Hi my heater has stopped working started again and has now stopped yet again
  • 37 Answers
Details?
Posted on Jan 03, 2011
Heater blowing cold air
You have to bleed airfrom the system.take to the shop
Dec 12, 2013 | 2002 Chrysler Concorde LXi
Heater blower motor problems
check your relays but most likily is the blower motor itself
Nov 18, 2013 | 2002 Buick Rendezvous
I have a Nordyne Intertherm water heater in a 2004 manufactured home. The water heater is tripping the internal circuit breaker. The first time this happened I found that a wire nut had melted. I never...
hi,
if its an electric water heater then it sounds like a calcified or shorted element. you have to shut the water heater off at the breaker box, drain the tank and replace the elements theres usually two. they make a special element wrench at the hardware store they just unscrew and screw back in. make sure all your electrical connections are tight..
jm
Jul 04, 2017 | Heating & Cooling
My heater stopped as a blanket covered it by mistake
after letting it cool down the heater should reset it's self and work again...
If it does not then it is no good anymore as the thermal switch is not replaceable...
heatman101
Jan 17, 2011 | Lasko 5365 Ceramic Compact Heater
My heater will shut down after running for about 10 mins. there is lots of propane, and all the connects seem to be tight and secure. i've checked the gap in the sparking unit (spark plug) and its around...
Hi check the flame sencer is clean check tubes to pressure switch ,jump out presureswitch , check fan control switch is clean, agian jump this out see if it works then .
Feb 27, 2010 | Reddy Heater RLP100 Portable Forced Air...
2002 taurus, power windows all stopped working at once along with lighted window switches. Drivers window stuck down. Relay was hot! Also heater blows cool air, started doing this after I added radiator...
LOOK FOR BLOWN WINDOW CIRCUIT BREAKER.YOU HAVE A SHORT IN WINDOW SWITCH OR BAD WINDOW ELECTRIC MOTOR.YOUR HEAT PROBLEM IS A STOPPED UP HEATER CORES.THE STOP LEAK STOP ITS HEAT.THE STOP LEAK HAS STOPPED OR PLUGGED YOUR HEATER CORE SO COOLANT CANT PASS THROUGH IT.YOU GOING HAVE TO FIX RADIATOR LEAK AND REPLACE HEATER CORE TO GET HEAT AGAIN.
Jan 28, 2010 | 2002 Ford Taurus
Vulcan Quasar 40 air issue
Hi the problem you have is your heater is cutting out due to the over temp switch getting to hot the reason for this is that your fan is not working thus not enough air flow is getting through the heat exchanger to keep it cool
your heater is designed to not exceed a certain temprature so as not to become a fire risk
to solve your problem you will need to replace your fan
this will solves your problem
Jul 27, 2009 | Heating & Cooling
Zanussi DW907 Dishwasher stops early in cycle
the heater relay may have gone on the pcb or you may have a stat/wiring fault in the heater circuit.
Feb 15, 2008 | Dishwashers
WHF5000 stops and does not starts again
buy a newer heater and save your money for good things
Jan 04, 2008 | Windchaser (WHF5000) Utility Heater
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
