Furnace goes on red light stays on exhaust fan for heat chamber goes on gas igniter comes on but soon as gas comes on furnace kicks off have to shut off power for furnace for it to reycyckle but same thing happens
  • 111 Answers
Sounds like flame sensor problem.flame sensor is metal rod ,usually close to ignightor,placed so its in flame when lit with one wire going to it.try taking it out and polish with steel wool and replace.if that doesn't work,replace it
Posted on Jan 12, 2011
    Problem Solver:
  • 14 Answers
Check your filter to make sure it is not plugged. If it is plugged - replace with filter recommended for your furnace. Every manufacture recommends you have your furnace checked and cleaned on an anual basis to keep itrunning safely and at it's top efficiency. If the filter is plugged or the blower wheel plugged, the furnace will shut itself off. Make sure all registers are uncovered - suppply and return registers.
Posted on Jan 03, 2011
1999 Goodman down draft natural gas furnace. It starts as normal, the burners fire and it warms up, but the blower doesn't start, after a couple minutes the burners shut down and the blower immediently...
IT SOUNDS LIKE THE FAN CYCLE RELAY OR BOARD IS NOT MAKING THE FAN COME ON WHEN IT SHOULD THE BURNER SHUTS OFF PROBABLY BECAUSE IT REACHES THE HIGH LIMIT.
Feb 03, 2015 | Heating & Cooling
I have a kenmore Dryer 110.76932690. Motor runs fine. Glow bar ignitor does not light. Flame doesn't come on. Changed Internal Bias Operating Thermostat still doesn't ignite. What could be other
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
Aug 30, 2014 | Dryers
Why dose my Kenmore elite dryer come on and then goes right back off and say f2
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
IS IT GAS? IF SO Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
Air Flow and Heat
Warning
Jul 21, 2014 | Kenmore Dryers
MAYTAG DRYER FLAMES KICK ON FOR 5 SECONDS THEN CLICKS OFF
Thermal Fuse
Air Flow and Heat
Warning
May 03, 2014 | Frigidaire Electric Dryer
I have a goodman modle gms80703ana and at first the inducer fan would kick on in it's normal cycle then the furnace would shut off do to a pressure switch. Now the inducer fan only come on perodicaly...
First unplug your furnace to reset it then plug it back in with thermostat set to heat high enough to make the heat come on. As soon as the inducer motor came on you JUMP the 2 wires that go to pressure switch. Your igniter should come on and gas valve should open for heat. If the flame stay on the blower should come on after a few minutes. If it get to this point your problem could be pressure switch itself or inducer clogged.
Jan 30, 2014 | Goodman GMS807034ANA Heater
My furnace works on ac and blows on ac but on heat it does not blow but i hear a humming sound coming from the furnace
Most furnace operating on Oil or gas will heat the combustion chamber before starting fan to prevent cold air draft at start-up, can last a minute or two. Eiter the main flame does not come on or the chamber thermostat have fail. Try to modify fan option on room thermostat from auto to on. Cold air coming out: burner problem or no more oil or gas, warm air: burning chamber thermostat problem, leave room thermostat fan option to on until repair.
Jan 02, 2014 | Comfortmaker Heating & Cooling
Goodman GMP 100-5 Rev B Serial # 9902602550 The status light stays illuminated. It isn't blinking. I believe my igniter went bad. When I turn on my heat on the system, The exhaust fan kicks on,...
Hello, the first thing is check the igniter for any crack or white spots on it, also, if you have a multimeter check the resistance of the igniter, should be between 40-90 ohms. You can purchase a igniter at any Heating and Cooling supply store.
Mar 11, 2011 | Goodman GMS90703BXA Heater
Rheem 90+ NG Furnace. When furnace starts, draft inducer starts, ignitor glows and gas ignites. Burners stay lit for 10 seconds or so, then the flame reduces for a few seconds then goes out. Main blower...
Check the draft inducer air switch ( vacuum diaphragm switch) If the switch is opening when the burner starts, you might have a blockage on air piping coming into the furnace. Also prime the condensate trap on the condensate drain from the combustion fan. Also check the gas pressure, if your gas pressure is dropping, the gas pressure switch will shut it down. If it's too high the moment it comes on could raise the pressure in the furnace dropping out the combustion fan proving switch.
Oct 29, 2010 | Electric Circuit Breaker Kit for Furnace
Heating & Cooling Logo
152 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
