The belt fell off my kenmore fl washer, how do I replace it?
Good morning, I just opened up he my Kenmore washer front load model 417-42042100 and the belt has come off. I don't see a tension bar, so how do I replace it. Thanks
  • guapo10 Jul 09, 2008
    Thanks Holy Terror, I bought a new belt just in case, replaced it and all is working so far. The belt looked fine, no fray or rips. I did notice some grind marks on the plastic tumbler casing. Tightened the belt. Thanks for the advise.
    Novelist:
  • 172 Answers
The question is why did the belt come off? this is unusual.
The belt does not have a tensioner the motor does this. you will need to loosen motor and then apply belt tension. Typical belt tension is 70lbs.
While you have the machine open make sure the driven pulley is tight, and doesnt wiggle or move you may have bearing problems.
How does the belt look, frayed or ripped you could have a bad belt unlikely but this could have been original problem, however check machine out first.
Posted on Jul 09, 2008
How to replace the drum baffles on a Kenmore HE3 front load washer?
Hello Dennis
Appliancepartspros does indeed show an entire kit for EXACTLY YOUR problem... $34
Good time to compare SEARs prices... for those very same parts!!
Happy hunting!!
Sears
Water Filters Lawn Garden Appliance Parts
Appliance parts
http://www.appliancepartspros.com/search.aspx?model=kenmore%20he3t
May 15, 2016 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Oasis HE 27082 Front Load Washer
ohm the release solenoid. could be shorted or open. check for voltage to the circuit
Sep 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Our washing machine will not drain, and keeps bringing up "LD" error code. It keeps beeping and the timer isn't going down.
  1. residential washer displays error codes. Though designed to indicate the nature of the error, to anyone without a copy of a washer manual handy, the codes might as well be Martian cryptography. Luckily, the Manage My Life website has partnered with Kenmore and made manuals for each make and model of Kenmore washer available online. The error codes are differentiated between top and front-loading machines.
  2. FH Error Code
  3. When a front-loading Kenmore residential washer displays the "FH" error code, the machine is experiencing a water-inlet problem. A water-inlet problem is the result of the washer receiving too little water to operate. The Kenmore owner's manual suggests five home remedies for this problem: Check that the water faucets connected to the washer are turned on; that the inlet screens in the washer's connection hose are not clogged; that the hose is not kinked; and that the hose is not frozen. If none of these problems are present, turn off the washer, unplug it, plug it back in, and restart the machine.
  4. FL Error Code
  5. The "FL" error code on a top-loading Kenmore residential washer indicates that the machine has over filled. When a residential Kenmore washer is overfull, it will beep every 10 seconds. The pump will cycle on and off every 30 seconds in an attempt to rectify the problem. To stop the pump or restart the machine, either disengage and then re-engage the power source to the washer, or push the overfill reset switch. If water continues to enter the machines after the "FL" error has appeared, shut off the inlet flow faucet or the machine will overflow.
  6. F02 Error Code
  7. The "F02" error code on a front-loading Kenmore residential washer indicates that the machine is experiencing a drainage problem. Home-remedy solutions for this error code, as suggested by the Kenmore manual, are similar to those for the "FH" error code: Insure that the drainage hose is not kinked, frozen, or clogged. If none of these problems are present, check that the hose is less than 96 inches, or 8 feet, above the floor. A hose more than eight feel from the floor will not drain properly
Dec 06, 2010 | Kenmore Washing Machines
Washer makes knocking noise while in spin cycle. Shock absorbers have been replaced and are good and machine is level. Kenmore Elite H E 3T Model #44932
Check your front and rear counter-weights. They are made of concrete and start to chip away. More so the rear than the front. When you open it up look on the base and see if you have chips or chunks of concrete. I had that problem as well - also make sure you spray lube inside,check your "Spider" wheel, and belt.
Jul 12, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My Kenmore front load 4304 washing machine tub
I would need the complete model # to get you a breakdown showing the piece i believe to be broken and in need of replacement. I believe this Kenmore F.L. was built by Frigidaire and they have had a problem with a specific piece on this machine. I will be glad to help once you get me the full model, should be around the opening of the door.
Oct 25, 2009 | Kenmore 43042 Front Load Washer
One of the fins on my Kenmore front loading washer fell off
The entire agitator must be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 06, 2009 | Kenmore Washing Machines
Magnet fell out of dispensing drawer and I don't seem to be able to find where to replace it. Washer will not start without it. Kenmore model 417 44152400
I dont see why there would be a magnet in the dispenser draw in the first place,,,, is it possible it somehow got in there by accident and when it fell out you thought it belonged in there ?
Mar 12, 2009 | Kenmore 46462 Front Load Washer
Kenmore elite calypso model 11022086
FL means flood condiction..clean or replace your pump..
Jan 09, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3 model # 11044832200 gives me a f15 error code. have already unplugged and replugged every connection between the CCU, MCU and drive motor, machine will fill and drain properly but will...
it because you change cycles in the wash mode,,over reset...all fixes accept reset unplug .needs technician...if you fell you can do this repost question,,as replacing motor control unit
Dec 26, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore model 41743142200
Un plug washer remove belt by lossing the tensioner , bring to appliances center and assemble again /
Jan 07, 2008 | Kenmore 45081 Front Load Washer / Dryer
Washing Machines Logo
260 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
