The tv 'runs' - sometimes for hours, sometimes just a few minutes. cut on and off - most times you can hear a ticking - then the power light comes on and the set will. Sometimes the power light will flicker - no ticking sound. Once we let it go 'off' and it 'ran' ticking sound for 5 hours before we unplugged it. Most nights we run it for a few hours - works great - then it goes off - so we just unplug it and leave it till the next day - set may be on five to six/eight hours or not on for days.
  • 17,129 Answers
This is typical with many sets when it goes old as there is a high possibility that the components over a period of heating and cooling , tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs.
Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points. Please find below two links for tips on poor start ups, as if the set is totally failed the SMPS might be faulty.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
http://www.fixya.com/support/r6055091-slow_start_up_circuit_cold_starting
Posted on Jan 03, 2011
Screen and sound cuts out at times.
I would check the power board capacitors. Many people are losing the electrolytic caps on these boards. It is possible yours are failing only when they heat up.
Apr 13, 2013 | Televison & Video
2002 Jeep liberty headlights cut off and then back on at random times. weather makes no difference nor hot or cold. went a way for a few months and now it has started all over again. hear clicking sound...
the clicking your hearing is the relay trying to stay engaged, its heating up causing the relay to power down, which in turn you lose the lights, the heat is caused by the electrical current supplied to the replay, Not the outside temp , locate that relay and replace it, and your problem should be gone
Aug 10, 2011 | 2002 Jeep Liberty
, power cuts off ,
the power cable is broke, but not completely thats why come in and out ...
Dec 13, 2009 | RCA HD52W56 52" Rear Projection HDTV
Sharp 2DR-S100S Ticking sound, will not turn on
does it tick all the time are just a few minutes and can you turn it off and back real qiuck and see or hear high voltage come on are see a flash is sounds like you have what is know as startup are shutdown circuit trouble
Feb 22, 2009 | Sharp 25R-S100 25" TV
Ticking noise from TV - Sony 50' rear projection 1080p LCD
The problem is ht leakage . remove the ultar cap of the tube and clean both the tube and cap with wd 40. then reinstall cap using some silicon glue.
this will correct your fault.
Jul 11, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
No power
That day while you were out it might have rained or lost total power in the house and your TV might have suffer what is call power surge or lighting damage ,those two thing do a lot of damage to any electronic equipment,you need to get a qualified service technician to diagnose the problem.Sometimes there is no reason and the tv's just fail.Good luck.
Sep 18, 2006 | JVC AV-32980 32" TV
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
