Question about Hilti Tools & Hardware - Others
I need a trigger mechanism and firing pin for my hilti DX400
5 Suggested Answers
  • 33 Answers
SOURCE: Hilti TE6A battery dril 36volts,trigger problems
what about the brushes. even if they arent worn completely down they sometimes will not have enough pressure on the commutator tabs to keep the tool running. if it works better upside down or sideways that is often an indication of faulty brushes. the springs that hold the brushes against the commutator may also be weakened to the point that they don't properly force contact. you may also have burned or blank spots on the commutator/armature.
try new brushes and make sure the associated wires arent broken, pinched or otherwise damaged. also clean the commutator with a polishing cloth or very very very fine sandpaper, being careful not to scratch, groove, or otherwise damage the tabs. also, the bearings that fit in the housing to stabilize the armature may be worn or seizing, which will cause the armature to move erratically and/or bind.
if all of these things have been done, and the problem STILL exists, then probably the motor itself (armature/field) is breaking down. the brushes and bearings at least are probably in stock at a local tool repair shop, and of course all parts can be purchased through hilti.
Posted on Dec 04, 2009
rowdy45176
  • 2176 Answers
SOURCE: where can i find a firing pin assembly for a hilti
you can either call them direct at 1-800-879-8000 or try Hilti.com for the breakdown, I would try the phone call first. Let me know if you still have a problem.
Posted on Jan 31, 2010
  • 123 Answers
SOURCE: hilti te22 trigger problem
the switch for the TE22 has been discontinued for years. Your best bet is to find a used one on ebay. Since it is a double throw switch somtimes you can get away with jumping one side "the bad side" and getting it to work for a while. The cord goes on the top connectors and the motor on the bottom. If you determine that one of them is bad then take the cord wire and move it directly to the motor connection below and secure it with the motor screw. A quick drawing below to show what I mean.
Hope this helps
Glenn
Posted on Nov 11, 2011
rowdy45176
  • 2176 Answers
SOURCE: hilti dx400 owners manual
call them at 1-800-879-8000 or go to their site at hilti.com. I would recommend calling them. Let me know if you need more assistance.
Posted on Feb 08, 2012
Trigger sf 4000
I would contact Hilti or a Hilti dealer. Here is a link to their site. You will have to remove any fasteners that hold the housings together so that you can replace the switch.
Hilti
Aug 25, 2012 | Drills
Framing nailer won't fire nails
Usually safety foot is not making full contact to trigger mech. First test trigger valve. Remove nails, remove the trigger to expose the trigger firing pin. Connect air and test fire by pushing in the firing pin with your finger (dry fire onto wood or old coiled rubber hose, use very quick pushing action against trigger pin). If the gun works, replace parts and adjust the safety foot so that the lever below the trigger is pushed all the way up and lever depresses the trigger pin all the way in. Good luck
May 26, 2012 | Air Tools & Compressors
HELLO I HAVE THE HILTI TE76-ATC WITH CODE 330200 WE CHANGED CARBONS . HOW I CAN MAKE THE RED LIGHT FROM ON TO OFF.
Are you mechanically inclined??? This is a little involved to do. First UNPLUG tool and remove the back section/trigger, there are about 6 screws holding the assembly to the back of the tool. REMOVE as an assembly. SQUEEZE trigger and PLUG into electrical outlet, while holding trigger unplug and reassemble, try this if light still on plug assembly in squeeze trigger and while holding the trigger unplug and retry. One if these should take care of resetting the light. If not the only other way is to send it to HILTI and have them reset it. Let me know if you still need more assistance and results.
Feb 17, 2012 | Drills
Hilti dx400 owners manual
Jan 23, 2012 | Drills
Porter Cable FN250c wont shoot with every trigger pull. sometimes it shoots correctly (10% of the time), other times it just pops (no nail) and other times it shoots two nails at once. Also when it...
Worn trigger and or worn firing valve. Remove the trigger and look for wear on contact surfaces (worn pin that holds trigger, worn inner lever inside trigger, worn or loose firing pin in valve ). Easy test for worn trigger. Remove the nails, remove trigger, fire the gun against wood with finger to test for proper action. If it works better without trigger, consider replacing trigger with new (I would also order the oring repair kit that includes the firing valve )
Jul 26, 2011 | Porter Cable-Cable FN250C 1-inch...
Paslode framer when you depress trigger there no resistance and it does not fire
Paslode framer has a lever inside of trigger that may be bent or missing. Easy to check. Remove air line and nails. Remove trigger by pulling pin. Check under trigger for missing parts. Test gun by connecting to air and place nose of gun against wood or hard rubber and then depress firing pin. If gun fires then problem is with lever under trigger or safety mechanism which is in two parts. Check safety for bent or broken piece, usually upper part will be missing lip that actually pushes on the lever. If however gun does not fire when firing pin is depressed, time for replacing orings in gun. Parts are available at www.toolpartsdirect.com . Good luck with your repair and post again if you have other questions.
Jun 30, 2010 | NRS Paslode 501000 Powermaster Plus...
Where can i find a firing pin assembly for a hilti 16 gauge nail gun model # fnb212 .it is broken.
Jan 30, 2010 | Air Tools & Compressors
How do i remove the chuck on a hilti dd100 core drill i was told you just knock out the pin but it dosnt seem to budge and its starting to get butchered
go to Hilti.com and type in your model number for an owners manual on this tool. It looks like it has a locking mechanism that you just need to pull back. Let me know if you can't find it and I will get more specific info, or you can call them at 1-800-879-8000 and speak with tech services for this
Oct 01, 2009 | Hilti Drills
Tools & Hardware - Others Logo
191 people viewed this question
Top Hilti Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Hilti Tool and Hardware - Other Expert? Answer questions, earn points and help others
