Question about Denon AVR-600 Receiver
Hi My Denon AVR-600, get's stuck on the stand by mode with red led on but nothing shows on the display. Thank you
  • 6 Answers
SOURCE: Denon AVR-1508
sounds like overload protection
turn the volume all the way down, then turn it on
if that doesn't do it you may have a short in one of the speaker lines - try disconnecting them one at a time
Posted on Jan 13, 2008
SOURCE: when you turn on the avr 600 the display says "protect"
The Control IC broken
Posted on May 31, 2008
  • 119 Answers
SOURCE: AVR-600
The problem is past that point once the protect continues to activate the amp is in need of service
Posted on Feb 26, 2009
mattvierra
  • 74 Answers
SOURCE: Denon receiver AVR-3300: Unstable source selection
Very important you have run system set up menu it configures your receiver with inputs analog or digital,speaker size,input,room correction etc Different input modes can be selected for the different input sources.
The selected input modes for the separate input sources are stored in
the memory.
q AUTO (auto mode)
In this mode, the types of signals being input to the digital and
analog input jacks for the selected input source are detected and
the program in the AVR-3300’s surround decoder is selected
automatically upon playback. This mode can be selected for all
input sources other than PHONO, MD/TAPE and TUNER.
The presence or absence of digital signals is detected, the signals
input to the digital input jacks are identified and decoding and
playback are performed automatically in DTS, Dolby Digital or PCM
(2 channel stereo) format. If no digital signal is being input, the
analog input jacks are selected.
w PCM (exclusive PCM signal playback mode)
Decoding and playback are only performed when PCM signals are
being input.
e DTS (exclusive DTS signal playback mode)
Decoding and playback are only performed when DTS signals are
being input.
r ANALOG (exclusive analog audio signal playback mode)
The signals input to the analog input jacks are decoded and played.
t EXT. IN (external decoder input jack selection mode)
The signals being input to the external decoder input jacks are
played without passing through the surround circuitry Your remote is searching for inputs because you did not properly run system set up!!! Here is a link to your manual [PDF] AVR-3300/1 3.3E*
Posted on Jul 22, 2009
  • 5 Answers
SOURCE: Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Posted on Mar 09, 2010
I have a old denon avr-1804. try to switch on power but can not. just appear a main power red light flashed rapidlly. please tell me why?
Greetings
the red flashing LED is that the Device is in protection mode.
the internal power supply . +15 volts and -15 volts are defected you need to be replace it ... Regulators 7915 and 7815 .... these you should change , might also need to check capacitors .
these are common defects for Denon . AVR units.
Good Luck
Hope this helps
May 26, 2016 | Denon Audio Players & Recorders
Denon AVR 789 no display
Time to send back to Denon (seriously). Hopefully you have a warranty on your product (I bought mine at Fry's and it took a few months for the warranty work to be performed). Good luck!
Jan 15, 2012 | Denon AVR-789 Receiver
When on the stand by button on display come and display showing protect how do i rectify the protect mode?circuit diagram?
protect mode comes on generally when speaker have shorted. disconnect the speakers & try. If it powers on properly try one speaker at a time till you find out which speaker is causing the problem
Dec 23, 2010 | Denon AVR-2800 Receiver
I have a denon avr amp it powers up then goes in
disconnect all connections cycle power if the power stays on reconnect equipment one at a time cycling power after each peice reconnected. If the power goes back to stand by with nothing connected the reciever needs repair
Jul 18, 2009 | Denon AVR 2808Ci Receiver
My Denon AVR-1802 is permanently stuck in tone defeat. The display actually shows that the tone defeat can be turned off and on, but the tone controls, ie. bass and treble do not alter the sound in any...
Is this only when using external inputs? The manual says the Tone Control will not function in Direct Mode. Try Stereo and various DSP surround modes to see if the Tone Control works.
Apr 21, 2009 | Denon AVR-1802 Receiver
AVR-600
Feb 25, 2009 | Denon AVR-600 Receiver
124 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
