Question about Canon PowerShot S2 IS Digital Camera
On power up of the camera, both LCD screen and viewfinder are black. Batteries are brand new. What could be the problem?
I took mine to a local, reputable, camera shop and they told me the sensor went out and it would be $199 to replace. hope this helps.
Posted on Jan 11, 2011
  • CameraR
    CameraR Jun 19, 2011
    Actually the S2 IS is very prone to stuck shutter problems, which are very similar to CCD failure. But fortunately, a stuck shutter can be fixed in most cases by the user without even putting a screwdriver to the camera:
    http://camerarepair.blogspot.com/2009/05...
2 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: When camera is turned on no picture appears in
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Sep 12, 2010
When I look to the viewfinder I have a blank screen
Viewfinder, screen and pictures are blank / black - Nikon ...
https://www.ifixit.com/.../Viewfinder,+screen+and+pictures+are+bla...
iFixitMay 4, 2015 - When I look through the viewfinder or at the lcd it is blank / black. Also when I take a picture and view it on my computer, the picture is blank ...
SONY ' eSupport - There is no picture or a black screen ...
https://us.en.kb.sony.com/.../there-is-no-picture-or-a-black-screen-appear...
Dec 8, 2015 - There is no picture or a black screen appears in the viewfinder or LCDwhen attempting to ... Look to see if an image can be seen in the viewfinder or LCD. IMPORTANT: Some camcorders have both a viewfinder and LCD.
There is no picture or a black screen appears in the ...
Jan 11, 2016 | Cameras
Screen went black
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Feb 27, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Monitor stays black
You may have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD screen on and off to save batteries. You would then use the optical viewfinder in its place. To try turning the screen back on, press the DISP button once.
Nov 04, 2009 | Cameras
Black screen will not take photo
May sound silly but, make sure the lens cap is off. If so, then look to see if the automatic iris is opening when you power on the camera, you will know it is open when you can see the glass of the lens. Fresh/fully charged battery/batteries would be something else to try.
Sep 18, 2009 | Konica Minolta DiMAGE Z6 Digital Camera
Cannon SD 750 - when i try to take a picture a black screen appe
Think that you accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Jul 29, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Dark and blurry
It will clear instantly with a fresh battery.
The viewfinder screen has an LCD overlay and even when the camera is switched off the screen uses a small amount of power. When the batteries are flat the screen is unpowered, the crystals in the LCD align randomly to both darken and blur the viewfinder image.
Please don't forget to rate my answer.
Jul 18, 2009 | Nikon N65 35mm SLR Camera
Pentax K200D NO LCD just viewfinder visual
Pentax K200D is a SLR Digital Camera..... in SLR you can the images in LCD after it has been taken.... while cliking image you need to use the Viewfinder......
Mar 24, 2009 | Pentax K200D Body only Digital Camera
Kodak C643 Screen black
One way out of the glare is to use the optical viewfinder (if your camera has one) to preview your image instead of the LCD. Another possibility is to buy a camera that has a backlit LCD.
Mar 09, 2008 | Kodak EasyShare C643 Digital Camera
Viewfinder/lens problems
Alkaline batteries just don't have the power for more than a few pics in a digital camera. Digital cameras for the most part should only be used with rechargeable NiMH batteries. Walmart sells these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance. Really, you'll slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
And yes, your camera's optical viewfinder is off by a couple inches from what's show in the LCD. Take a look at the front of your camera. This offest is equal to the distance between the other end of the optical viewfinder, and your camera's lens. This should only be a problem for close up pictures. Recommend leaving your LCD on and using that to center your pictures. If using rechargeables, it shouldn't be a problem.
Jan 30, 2008 | Canon PowerShot A430 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
914 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
