Question about Kenmore Washing Machines
Kenmore washer Mod # 110.20442990 will drain but not spin.It makes a noise during spin but does not spin. We opened the lid and pushed the switch mechanism down and it still would not spin.
  • pappyt Jan 03, 2011
    would this be the switch if it still doesnt work ?
    Brigadier General:
  • 3,917 Answers
Hi
Please check the bellow link to get a detailed idea related to your query:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#itpumpsbutdoesntspin
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jan 03, 2011
2 Suggested Answers
  • 1937 Answers
SOURCE: Top loading Kenmore (mod 24832200) doesnt spin rinse or spin cycl
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24832200
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
See the following for how to access the console.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=61f80e08f3f0ad9fa07bd1a70b21c4cd
This is the Whirlpool PDF on installation and maintenance of direct drive washers. See the section on how to bypass the lid switch and on the transmission.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If everything else works OK,, including the drain, and the timer moves, the problem could be in the transmission / gearcase.
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again. The Sears site for your washer may have a sub-component section on the gearcase with a part number for the Neutral Drain Assembly repair kit.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
You can also see this site for removing the transmission.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
With ours, all told, it cost less than $30 (including new 80-90 weight gear oil) vs. about $170 for a new transmission.
The job is a bit complicated and messy but not too difficult.
Posted on Nov 12, 2009
Kenmore 70 series washer will not drain? It makes an electric click noise which makes me think the lid switch is ok, but i don't know. Won't drain or spin.
There is a good chance the lid switch is bad. The model number is usually under the lid hen you open the lid check at the back of the opening when the water injector is.
May 17, 2014 | Kenmore 24932 Top Load Washer
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Aug 30, 2009 | Kenmore 22422 Top Load Washer
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series mod 110225842400 stopped working during cycle. Tub won't drain and will not agitate.
Hi, When the washer is in spin or wash cyles, do you here any motor noises? It sounds like the lid switch might be bad. Sometimes you can actually see if the lid switch is broke or not. Please let me know if The lid switch appears to be the problem or if I can assist you further.
Vic
Jun 20, 2009 | Kenmore 20172 Top Load Washer
Washer won't spin or agitate
bad lid switch or bad motor coupler or both-mike
Jun 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer makes noise but, wont drain or spin
Check the lid switch (the part that gets pushed down when you close the lid). Try pushing it down with something. If you do not hear it make a CLICK sound, then it needs to be replaced.
Note: ALWAYS unplug appliances before attempting to make any repairs!!
Mar 14, 2009 | Kenmore Washing Machines
Water won't drain
This is usually caused by the lid safety switch. When the switch malfunctions, The washer believes the lid is open and the washer will not spin or empty. The switch is intended to prevent injury during the spin cycle. The timer could be bad but it is usually the switch..
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
My BWD 129 washer dryer is not spinning or draining
I have a similar problem - washer wouldn't spin or drain. The problem with my Kenmore 90 series is that the lid switch needs to be replaced. It's a safety feature. During normal operation when the washer is spinning or draining - and you open the lid - the lid switch sensor knows that the lid is opened and then "stops" the machine. A new lid switch needs to be installed. I have picked up the part, but am still trying to figure out "how" to get inside of the washer. The only difference between what you describe, and my problem, is that there is no "unusual" noise coming from the machine. Hope this helps lead you in a good direction. Another good site is Bob Villa's site.
Jan 15, 2009 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
168 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
