What does the technical fault F176 on a Miele W3725 washing machine mean?
  • 139 Answers
SOURCE: washing machine
That fault code is to do with the drain pump either its jammed or not working remove the front plate at the bottom of the machine undue the filter and check to see if it is either a blockage or something jammed in the pump..
hope this helps cheers
Posted on Jan 21, 2008
jsrock516
  • 5911 Answers
SOURCE: Fault code C1
"C1" is known as an Instantaneous Current Limit Error. This will occur when the Motor Controller detects a current spike of 26 amps or greater at the motor windings. Overloading the washer, excessive water and/or excessive suds can cause this problem.
The manufacturer recommends the following:
- Wash smaller loads and use the correct detergent (HE only for Calypso machines). NOTE: Make sure the HE detergent is not double or triple concentrated as this will also cause suds problems.
- Check for objects under the nunate plate. This is the wash plate. Sometimes clothing can get stuck under the plate and cause the motor to bind up. To remove the nunate plate, follow these instructions:
1. UNPLUG THE WASHER.
2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back against the wall in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back.
3. Remove the tub ring. This is the plastic donut shaped ring that sits on top of the wash tub. There will be a tab on either side of the outer tub near the back that you can use a screwdriver to release the tub ring. The ring is filled with fluid and is used to balance the tub. So, if you hear liquid sloshing around, this is normal.
4. Remove the center cone from the wash plate. Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it.
5. Remove the nuts and the wash plate should lift out. Be careful not to damage the gasket under it. Clothing can get tangled in the leveler under the wash plate. This leveler should have a key on it. The wash plate will only go back in with this key mating to a slot on it. So, remember how you took it off. In addition, when putting the wash plate back on, make sure you tighten the nuts in a cross pattern and evenly tighten them as you go. This will ensure the gasket seats properly. Don't forget to put the tub ring back in.
- Check for objects stuck between the inner wash tub and the outer basket. NOTE: It is best to do this with the nunate plate removed. Use a flashlight to peer through the holes in the wash basket to see if anything is catching on the tub.
- Check the Motor Controller. You will need to determine if there is power getting the the board first and that the fuse on the board is good. If any components on the board are defective, the board has to be replaced. If you have power to the board and the fuse checks good, check for continuity between the Machine Controller and Motor Controller.
There is a tech sheet inside your washer along the interior cabinet (usually the front panel) that explains all these procedures to you. I would advise you to research the tech sheet for exact locations of the pin outs for the circuit boards. Its easier for you to view it rather than me explain it. If you need further assistance, please post back and let me know. I hope this helps you.
Posted on Jul 03, 2008
mgprice
  • 744 Answers
SOURCE: Miele Washing Machine Code: Check drain
This means that the drain attached to the pump is clogged, remove the drain plug check fro debris and replace...you should be good to go.
Posted on Jun 23, 2009
  • 4 Answers
SOURCE: miele W1712 washing machine drain fault
Just had the same problem, after Much patience and persistence I found the blockage at the y piece that joins the pump to the outlet hose air trap towards the top of the machine LHS with the top and cover off.
It was clogged solid therefore no back pressure on the top little ball valve (between the air trap and the outlet) therefore no seal therefore norain therefore a drain-fault that persists regardless of a cleaned pump filter.
Posted on Dec 04, 2009
  • 70 Answers
SOURCE: miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Posted on Apr 01, 2010
Testimonial: "thanks, you confirmed what we sort of expected"
Miele washing machine W3725 is coming up with Technical fault F51 ?
F51: Pressure Sensor
Symptom
In the operating mode, the display indicates Technical fault.
The program is stopped, the water intake valve is closed, and the drain pump is
switched on for 120 seconds.
Cause
Electrical defect in analog pressure sensor (ADS). The values are out of range.
x
Note
The pressure sensor is integrated into the power/program electronic (ELP)
This will usually require a professional to repair.
Dec 10, 2016 | Miele Washing Machines
My miele w3725 front loader washing machine appears to be leaking drops of oil into the wash and staining the clothes. What could be the cause?
Hi dear,
Seems like your washer has bearing seal damage. It will be expensive repair. You may contact Miele to get a quote. Thanks.
Jan 01, 2016 | Miele Washing Machines
Miele W3725 washing machine appears dead. No lights on control panel. 240V AC wall socket is OK. Is there a fuse for power coming into machine? Can't seem to find one.
go to google and type in miele washing machines on one of the pages you will find a contact us tab
make a call to a service department and they will advise over the phone
May 12, 2015 | Miele Washing Machines
Miele w3725 won't start
If the Start LED keeps flashing, either the door is not closed properly, or the door switch is broken.
Mar 01, 2015 | Miele Washing Machines
What mean technics error in whaching machine miele
There should be an error code that follows - What is the model number?
Aug 16, 2014 | Miele Washing Machines
What is code error F50 on my miele W3725 washing machine mean
I have today purchased a Miele 3985 machine with a know F50 Fault code appearing
Before I went to the expense of calling a Miele technician, I explored the blocked / clogged drain path
I removed the drain pipe and noticed there was a lot of 'residue' / gunk in there
I cleaned what I could, and blew through the pipe back into the machine
Then I did a cotton wash cycle at 90degrees, with a 1litre of bleach to clean the drain path
The wash looked extremely dirty during the cycle
It appears that this resolved the F50 fault code issue with my Miele 3985 Navitronic
Aug 08, 2014 | Washing Machines
Miele w3725 front loader. message on screen "waterproof fault"
For our model Alemnesh's suggestions were spot-on. It's hard to believe that a machine with such a good reputation would (a) allow this fault to occur so easily and (b) not have its own manual provide explicit guidance as to how to fix it.
Oct 03, 2010 | Miele Washing Machines
Our miele w3725 is coming up with drain default
You'll need to clean the filter and/or remove the hoses to inspect the inlet strainer & clean it out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 29, 2009 | Washing Machines
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
