Question about Home
I have a Glacier Bay 1.28 gpf toilet. There is a bucket that dumps the water into the toilet. The water does not stop when it reaches the water line resulting in a continuous leak down into the rest of the tank. There is no observable change in the water line in the bowl itself. What can i do to stop the waste of water that is always flowing?
  • 17 Answers
SOURCE: toilet bowl gurgles after flushing cycle
Sounds like your toilet is not vented properly. Possilbly something caught in the trap is causing it to syphon
Posted on Jan 23, 2010
  • 102 Answers
SOURCE: I recently bought a Glacier Bay 303-635 All-in-One
Try adjusting the water level down about a half inch or so and see if that helps. It could just be siphoning. Otherwise the valve may be defective. Hope this helps.
Posted on May 11, 2010
co7196
  • 3433 Answers
SOURCE: My Glacier Bay flush handle does not allow the fla...
It is more than likely the flapper. Easy fix. Ck the chain for too much slack. Good luck_Ned-
Posted on May 26, 2010
bloues
  • 56 Answers
SOURCE: water leaking inside toilrt bowl
The flush megnisems rubber has parished.
Step1. open sistern and locate the flush meganisem, [shoold 90% of time be the gajet in middel]
Step2.unhook or unscrew all the handels conected to it,
Step3. turn the meganisem left, it wil pop out and at the bottom after you pop it out u see a black rubber that looks damaged, go to plumbing shop with the rubber and they will give u 1 ,its cheeep.
that should fix it.
plz rate my advice
Posted on Jul 12, 2010
  • 5 Answers
SOURCE: Porcher 6.0 Lpf / 1.6 toilet. Plumber said he
Try replacing the flapper, they are cheap and so long as the tank and or bowl are not cracked you can replace all of the internal parts and basically have a brand new toilet much cheaper then replacing the entire unit. Go down to your local hardware store and everything you need is in one simple kit with very simple instructions. Good Luck.
Posted on Jul 22, 2010
I need a repair manual for a Glacier Bay Toilet Model#N23167
Hey Pam.
What is your toilet not doing?..
please reply to me on here
Jul 18, 2017 | Glacier Bay Home
Where can I get a replacement handle/flush lever for a 2006 Glacier Bay 1.6 gallon toilet?
Glacier Bay Toilets are made in China by "various manufacturers" a local plumbing parts supplier is your best bet.
Jan 11, 2016 | Home
HOW TO SET WATER LEVEL GLACIER BAY TOILET
There should be a adjustment screw at the top of the fill valve, screw it up or down to adjust the tank level.
Sep 13, 2014 | Fluidmaster Glacier Bay Flapperless Toilet...
Glacier bay instructions
If it has a fluid-master assembly, there's a metal bar on the side of the float with a small metal adjusting tab on it, squeeze the tab together and raise or lower it on the bar to change the float setting.
Aug 23, 2014 | Home
Water won't stop running in glacier bay n2316 toilet
Replacement parts you can find on amazon. take a look here Amazon com glacier bay toilet parts Hope this was helpful. cheers
Jul 03, 2012 | Home
I have a Glacier Bay dual flush toilet that makes hissing noises sporadically. How do I make it stop?
I have a glacier bay dual flush toilet. I have had it since 2009. When it started the hissing noise I tried diff things to fix it. New water valve, new washer from tank to bowel.
The food die in the tank showed water was leaking into the bowl. As a result the water would try to keep filling the take every time a little water escaped making it hiss. Sound familiar?
Finally I contacted someone on line home depot and the glacier bay manufacture was the main people. You need a silicone washer that goes in the main center piece mechanism that lets the water into your tank. You need to remove the center main piece in your tank. at the bottom inside the mechanism itself is a washer the size of a coffee mug top circle.
You can only see it if you take apart the two pieces. Once this goes inside your problem WILL BE SOLVED. The manufacture sent it to me for free. She knew right way. What causes the problem is cleaner tablets in the tank or bad water. So that's it folks
Jan 28, 2011 | Home
Glacier bay gal toilet.
Does the tank lid have a seal on it to keep water from coming out?
May 30, 2010 | Home
I recently bought a Glacier Bay 303-635 All-in-One toilet. It was installed just fine, however everytime I flush the toilet the tank fills up to the water line, but the spout over the water line tube keeps...
May 11, 2010 | Home
Home Logo
109 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
