Question about LG WM-2277HW Front Load Washer
LG washer 2016 gets FE warning. What can be the problem
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
The error code FE refers to the fact that water is overflowing ( normally means the inlet water valve is stuck open and continues to let in water beyond the expected and/or sensed level.. so the water pump turns on to drain it and keep the level down. This kind of problem would probably warrant a a service call from a tech since the majority of troubleshooting would require diagnosing the failed component itself and is not something that I recommend you try.
There are too many pieces of hardware that have a direct impact on how this works and I highly doubt you want to play the shotgun approach..try this to see if it fixes the problem and if not..try that...
Before calling for service.. try this..
1. Remove or disconnect ac power from the washer..let it sit unplugged for at least an hour..then try washing 1 towel at the lowest cold water setting to see if that works ..if it does..repeat the process using only hot water.. if that works... then try the same test using warm water.. ( this test may help determine if the water inlet valve .,.either hot or cold is leaking through it)...
If you still get the FE test..call for service..
BTW..if only one of the two tests fails.. ( Hot water only generates an FE error.. then chances are the hot water inlet solenoid valve assembly is either sticking open or the controls to that are commanding it to remain open.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 03, 2011
  • rongarney
    rongarney Feb 26, 2013
    thanks i will try that.
  • SHAWN
    SHAWN May 15, 2014
    WHAT CAN YOU TELL ME ABOUT THE LG ERROR CODE LE.. BUT THE LE ON THE MACHINE IN LIKE A UPSIDE DOWN F???
Why on an LG Front loader does the FE code come on and not on Rinse & Spin?
Here is the LG site for washing machine error codes, you can scroll down and find the FE code there:
http://www.lg.com/us/support/product-help/CT10000010-20150140270078-other-error-codes
The site shows the following:
The FE error code indicates the washer is overfilling. This is usually the result of a faulty water valve.
1. Close both water taps.
2. In order to drain out any trapped water, power the washer back on and press the Spin Speed button until No Spin is selected and press the Start/Pause button.
3. Once the washer has drained, restart the wash cycle.
Jan 26, 2017 | LG Washing Machines
On my LG tromm washer has an error code FE, what is the solution to this problem or how do i get it fix???
The FE error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.
Feb 21, 2015 | LG Washing Machines
Fe warning light
Fe error code means "Water Overflow Error". Check the upper level sensor of the machine.
Dec 22, 2013 | LG Washing Machines
LG front load washing machine WM2233H Error code is FE
I found this information on the internet. I hope that it helps.
" Getting fe code on lg washer.
"This means that the washer is overflowing. This is a built in fault that turns on the drain pump so that the water doesn't get so high that it gets into the floor. If water is continually flowing into the washer you will get this problem. If this is the case the water valve is most likely the problem. To confirm unplug the washer and if the water doesn't stop flowing into the washer the water valve is the problem.
Thank you,
Shawn"
I hope that this helps you out
Apr 21, 2011 | LG WM2233H Front Load Stacked Washer /...
I am getting fe error after the water fills in.it doesnt start washing. What to do?
The FE error isn't common to all washers. In fact, I could only find information on it in relation to LG washers. I actually found this link here which explains it pretty well:
http://www.managemylife.com/mmh/questions/208013-lg-wm2032hw-error-fe
Jun 23, 2010 | Washing Machines
Warning light
Go to:
http://www.lge.com/
Choose your country and download your free manual.
Cheers.
Satisfactory response? Please vote! :-)
Mar 02, 2008 | LG WM-1290FHB Front Load Washer
LG WM1832CW Front Load Washer
FE means water is overflowing. Check pump filter. Check water level switch and hose. Also check that drain hose isn't too low causing it to refill itself continuously. In any case the drain pump should run for 4 minutes to try and eliminate the extra fill
Dec 28, 2007 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
768 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
