Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Freezer freezes and refrigertor will not stay cold
    Brigadier General:
  • 3,917 Answers
Hi
Check the back wall or floor of the freezer section for frost. Check the freezer or evaporator fan to see if it is running. Check the condenser coils under the unit for blockage from dust. Check the condenser fan to see if it is running.
If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with the doors open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jan 03, 2011
Refrigerator is not cooling
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 23, 2011 | Refrigerators
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigertor not cooling but freezer working
your temp control fan has probibly gone out. The way you find out is to find the fan which should be located near the temp control switch behind a plastic vent. If this fan is out there will be cooling in the freezer but not in the fridge. Also, if you open that area and find a large chunk of ice you defroster rod has gone out. Would recommedn replacing both at that time. Get model and serial number of unit and take to an appliance parts house they can assist you in the right part and any type of installation problems. Good Luck
Jul 15, 2009 | Refrigerators
Refrigerator part not cold,ice on back of freezer
low gas level in the system needs a bit of top up of 134 a gas
May 11, 2009 | Refrigerators
Freezer is not freezing properly and the refigerator is not cold
You have a defrost problem. The fridge gets cold air from freezer, if ice blocking from no defrost, no fridge temperature.
Apr 26, 2009 | Kenmore Refrigerators
I have a kenmore refrigertor and it's not stay cool at all. what
when you say not cool is the freezer freezing or the refrigerator not cold
Apr 07, 2009 | Kenmore 57029 Side by Side Refrigerator
Fridge not cold enough
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor, Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting, YOU CAN TRY turning FREEZER CONTROL To A WARMER FREEZER SETTING Allowing.. MORE AIR.. to refrigertor side.
Sep 25, 2007 | Samsung RS2534 Side by Side Refrigerator
Freezer of refigerator (coils keeps freezing over)
I had the same problem, i took mine outside and spayed degreeser on the coils and power washed it off. the coils get built up with dust. make sure you dont have it pluged in when power washing it. lol. good luck
Jul 28, 2007 | Hotpoint RLA80 Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
