Question about HP Deskjet D2360 InkJet Printer
My hp d2360 has several gaps either in black or colored after an interval, when I cleaned the ink waste pad the first print was neat and all black but later it has gaps
  • HP Master
  • 511 Answers
Did you refill the cartridges? If yes, you seem to much inkrefill. When hp refilled cartridges, respiratory holes must beclosed as usual. The hole should not be sealed but should notbe too loose. If too tight, the ink will not come out, if too loose,ink will flood because the force of gravity. At the time of printing, and emerging gaps, try to head off and check the bottom of the head is the ink floods.
Posted on Jan 03, 2011
HP PSC 1610 All-in-One color printing problem
It sounds like the waste ink pad is saturated or the driver is corrupt.
Look on the right side of printer where the cartridges park. See if ink is globbed on the pad below the cartridge. If it is it will have to be cleaned. What happens after the cartridges go through the cleaning process it will print. Then the cartridges park on the waste ink pad and gets plugged up again.
If it is not that it could be the drivers are corrupt. Uninstall the drivers and reinstall.
Apr 03, 2012 | HP PSC 1610 All-In-One InkJet Printer
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
Black or color printer not printing new inkjet
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any inkjet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
How to clear blocked print heads:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
-if that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Jan 25, 2011 | Brother MFC 210C All-In-One InkJet Printer
I've changed my colour ink cartridge three times now and it still wont print red.
If you allow the red color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Dec 17, 2010 | HP DeskJet 3650 InkJet Printer
Not printing all colours, heads clogged? Printing red and blue but not yellow.
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or viceversa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. Make sure that the yellow ink is not empty. If it's not empty, head may be clogged.
If that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Dec 11, 2010 | HP Photosmart D5160 InkJet Printer
Color stopped printing, changed cartridges, still will not print color. Now my black ink cartridge is acting up by starting off not completely printing text. What do I do now, buy a new printer?
Dec 06, 2010 | Lexmark JetPrinter X1185 All-In-One InkJet
Black color will not print. Installed a new black
Dec 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Not printing text
CLEAN THE BLACK INK CARTRIDGE AND THEN NEEDED REPLACE IT.
THE PROBLEM SEEMS TO BE DUE TO A CLOGGED BLACK INK CARTRIDGE.
Dec 12, 2007 | HP Deskjet D2360 InkJet Printer
Printer prints in color but has gaps
Have you tried a new colour cartridge? This is a classic sign that the cartridge may be low on ink. When printing text, assuming you are printing black, it is likely that the black cart is doing most of the work so the gaps are insignificant. You could try printing text in several different colours. If the colour cartridge is low, you'll find that some colours may be ok but others may have gaps.
Best to try a new cart if you have one.
Dec 11, 2007 | HP Deskjet D2360 InkJet Printer
HP Deskjet D2360 InkJet Printer Logo
80 people viewed this question
Seeker5211
Seeker5211
