WATER LEAKING FROM DOWNSIDE WHILE RUNNING - Washing Machines
  • Washing Mach... Master
  • 17,130 Answers
The first thing you must do is to have a good observation of the fault. Since the leak is from the bottom side, you must check the hose , the hose clamps , the tub and the drain pump/valve.
The possible areas of leak can be from any of these, remove the couplings, clean and set them back.
Make sure also that there is no leak from a failure of the washer water seal on the spindle of the agitator. If so remove and change the seal and reset.
Posted on Jan 03, 2011
Is my water heater leaking?
You have water leak that you can hear running water.
Could be broken pipe under house.
Could be water running out of tank at TP valve.
Turn off all water taps and put ear against each pipe at tank.
If TP valve is leaking, then replace TP valve.
If pipe is broken under house, then call contractor.
Copy following links for troubleshoot walk-thru.
http://waterheatertimer.org/images/Ear-against-pipe-200.jpg
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#listen
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 28, 2012 | Reliance 606 Series 40 Gallon Electric...
Sir, my fridge is leaking water inside and dropping downside of refrigerator, please give solution.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 26, 2010 | Whirlpool Refrigerators
My car is running hot and leaking water? i have changed the thermostat and it didn't help. there is water leaking from looks like the side of the engine maybe? the gage on the inside of the car didn't show...
if water is leaking from side of engine .. look to see if its leaking on side of intake check thermostat housing again check water pump or if its leaking towards the bottom of block it could be a freeze plug all easy fixes freeze plugs can be replaced with an expansion plug that has a nut on it to tighten to fit or replace with oem and a hammer
Sep 18, 2010 | 2002 Ford Taurus
My Kenmore 700 series washer has been leaking water. When the tub is filling with water, water seems to leak along the front bottom edge of the machine in several areas. I'm left with a huge puddle of...
First ck to see if your water pump is leaking. It normally leaks when the machine is running not just filling. Also look at all the attaching rubber hoses under the machine and see if water is leaking down the back right side of the machine and then running around the frame to the front long shot but possible.
Aug 11, 2010 | Kenmore 15864/15862 Top Load Washer
HEATER CORE LEAKING 2001 FORD EXPEDTION
The downside is of course, no heat, or warm air to defrost/defog windshield. Changing a heater core is generally a labor intensive job. If you decide to do it yourself, invest in a good manual, or online source so you know how to get it out in step by step process. I would suggest checking alldata diy site, which cost is in the upper $20 range for 1 yr access to your vehicles repair info. You can print up any sections you want to bring outside to work on the vehicle. Good luck.
Apr 30, 2010 | 2001 Ford Expedition
TRUCK IS RUNNING HOT AND WATER IS LEAKING
There are many locations water can leak from. Worst case is the head gasket its blown and the water is leaking into the combustion chamber or the block. Best case check hoses and radiator. Also make sure no air is in the system. Check freeze plugs as they corrode out.
Apr 16, 2010 | 1999 Ford F150 Regular Cab
Replaced water pump, now antifreeze leaking out from an area behind altenator and belt tensioner. Can you help?
take a flash light with the engine running and look at the corners of your intake manifold soo many times people have changed the water pump on the goofy engine WHEN!! it was the intake manifold gaskets leaking water to the outside and running down the front LOL
Jan 14, 2010 | 1995 Buick Park Avenue
Leaking water
Very common problem with these systems. This depends on humidity in the air. Some systems have a setting that you can turn off the dehumidifier. The downside to this is it doesn't cool quite as well as humididty absords heat. The drain pan in your system is probably overflowing. You have a couple options, you could "hard drain" it to outdoors, empty the drainpan regulary, or change the air settings (this may not solve completely if you live in a humid area).
Aug 30, 2009 | Haier HPM09XC5 Portable Air Conditioner
Water leaking from bottam while in running cycle
water leaking from under the machine while running. Also will not stop filling in the rinse cycle.
Jun 14, 2008 | GE WHRE5260E Top Load Washer
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
