Question about Kenwood RCR0907 Remote Control
My receiver doesn't receive any signal from the remote control
  • Kenwood Master
  • 17,130 Answers
First of all check your remote with a IR tester. You can use your phone camera with the remote pointed to it for IR detection. This will confirm the remote. Now make sure that there is no loose components in the remote that have come off the board and changed the frequency. If so remove and re-solder.
Now check the IR detector in the receiver, use a multimeter to check the voltage on the IR detection as the remote is used. If there is no voltage check and change the IR, if not the signal track must be traced to the processor.- suspect the processor.
Posted on Jan 03, 2011
Doesn't receive signal from remote control
if it works intermittenly then the remote dosent need reprogrammed. SOoooo....
line of site comes to mind. your box needs to see what your remote shoots out. sometimes something ends up in front of the reciever spot on the cable box (FYI: a flashlight at the right angle can help find the sweet spot on most devices)
maybe the dvr is going bad watch EVERYTHING you want to see one last time and have it swapped (like death, you can't take anything with you)
good luck (I hope its just a line of sight problem)
Apr 01, 2013 | Motorola Mobility DCH3416 (160 GB) DTV...
The remote to my aircon doesn't seem to be sending a signal
If you get a mobile phone and select its camera, then look at the LED at the front of the remote thru the camera, press some keys on the remote unit and you should see the LED light up on the remote on the mobile phone camera screen (it picks up Infra Red which we can't see). this will let you know if the remote control is working. if it is, the receiver at the indoor unit is either covered with something, check thoroughly, or the receiver is faulted, replace via technician. Have fun Tim B TB Electrical
Nov 29, 2012 | Carrier Heating & Cooling
Remote control doesn't work
Have the remote itself first checked---most tv shops have a tester--point remote at it and press buttons and it reacts-----Many digital cameras will react on their display screen in a very dark room in the same way.
If remote itself tests good the set has a receiver that takes the signal from the remote and it may be bad.
Aug 29, 2012 | LG 37LD450 37 in. TV
Directv remote and LG remote will not control tv, just receiver
Let's start simple first. Your TV is not responding to either remote control, but specifically if your factory original LG remote does not operate the LG TV, then the problem could be with the IR receiver in the TV itself.
Ensure nothing is blocking the IR receiver on the TV. Move anything out of the way.
Test both remotes to ensure that they are sending an infrared IR signal to the TV. Use a digital camera (such as the one on your phone) and point the remote into the camera lense and press the power/volume/channel buttons. You should see a faint flashing light in your camera viewfinder. This indicates that the remote is sending IR signal. If you don't see anything, then there is no signal. Try FRESH batteries.
If your remotes are working, and since this is an LG, look at the back of the TV by the video inputs. Look for a port called "REMOTE CONTROL IN" or similar. It looks like a 3.5mm headphone jack. This port is used for external remote control and may be dirty.
UNPLUG the TV, then use a regular 3.5mm male headphone jack to plug in and out several times. You basically want to push all the way in and all the way out several times to dislodge any dust and remove any oxidation that has built up in the port. 10-15 times should do fine.
Then plug in the TV and try your remote.
Best of luck.
Nov 05, 2017 | LG 32LG30 32 in. LCD HDTV
My remote doesn't work
Have you tried replacing the batteries? If you spilled something on it, it might break it, or if you dropped it. Is something in the way of the TV Receiver thats blocking the signal?
Nov 19, 2011 | Televison & Video
Romote control is not working.there is a battery in it ,red light comes up but fan is not reponding.is there any way i can manually control the fan ,any button hided some where? or i can make sure remote...
normally in Hunter fans its not the controller but the receiver goes out, if your controller has a new battery and the receiver doesn't get the signal,, the fan isn't going to work, I've never been able to Locate Hunter receivers, tons of the remotes, you can contact them on line at this link
http://www.huntershoponline.com/cc_contactus.asp
Aug 26, 2011 | Hunter (25417) Ceiling Fan
Hi, I have a Yamaha rx-v450 amp that won't change sound modes (stereo, hall, jazz, rock etc) from the remote control but it works from the buttons on the unit. I've checked my remote by pointing it...
Hi! Transmitting doesn't mean it's working, What you should do to test it is use a good quality universal remote such as a Logitech Harmony and first program the preset code for your receiver into the Universal Remote. If that works, you know your OEM remote has gone bad, at least for those buttons. If it doesn't then you you should attempt to have your Universal Remote "learn" the IR signals from your receiver's remote If the controls still don't work, there is a problem with either your IR receiver on your receiver or the the circuitry that proceesses the signals into commands. Good Luck!
May 11, 2011 | Yamaha RX-V450 Receiver
I have a problem code...its says check EO
Signal transmitting/receiving
error
(Indoor controller does not
respond to remote controller
signal.)
During individual unit control
1) Bad contact of transmission
wire
2) Signal transmitting/receiving circuit
is abnormal.
1) Check the transmission wire.
2) Check with another remote controller. If "EO" is
still indicated, replace the indoor controller
board.
If other check code appears. replace the original
remote controller.
P3 Signal transmission error
(Remote controller does not
respond to indoor controller
signal.)
wire
is abnormal.
3) Wrong operation due to noise
wave emitted
Nov 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Bought new Vizio 55"
Had same problem - turned off Adaptive Lumina, Backlight control, and Ambient light sensors on the Vizio advanced picture settings and the Dish remote now works. Vizio was emitting an infared signal that interfered with the Dish remote signals with these settings on. TV still works and looks just fine... But best of all Dish remote works too.
Nov 08, 2010 | DISH Network IR Remote Control
Direct TV Remote Satellite Won't Receive Signal
What is the AUX Fisher brand code for an RCA remote control model# RCR160SBM1
Nov 06, 2007 | RCA DIRECTV Satellite Remote Control
Kenwood RCR0907 Remote Control Logo
138 people viewed this question
Top Kenwood Televison & Video Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Kenwood Televison and Video Expert? Answer questions, earn points and help others
