Question about Tricity Bendix TM220W Electric Dryer
My tumble dryer wont heat up i think its either the element or the termostat but i am unsure how to take the appliance apart to test it. can you help?
dididsaythat
  • 291 Answers
SOURCE: dryer heating element
NEED More info ...Need model # and type dryer... info u gave is misleading
Posted on Oct 09, 2007
  • 172 Answers
SOURCE: Tumble dryer not heating
Hi irshaad,
If all the componants are good, you are loosing voltage somewhere. Check the voltage to the dryer. If you do not have 220 volts then you have a blown fuse or a kicked breaker in your fuse box. This would allow only 110 volts to get to the dryer and the dryer would run and not heat. If you have the correct voltage to the dryer check the connections on the terminal block and the wires to the block. Before going any further than that I would really rather have your model so I could guide you correctly. Good luck and I really hope this will FixYa.
Mike Anderson
Posted on Jun 03, 2008
SOURCE: cant find heating element for kenmore 80 series dryer
it should be in a housing mounted just inside the back panel. unlatch the housing from its mounts and the element slides out from the bottom
Posted on Jan 02, 2009
  • 7 Answers
SOURCE: Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Posted on Jan 21, 2009
carlsbiz
  • 1124 Answers
SOURCE: What is the best way to take the dryer apart in
An easy way to see if the eliment is working is to remove the exaust hose.. Put a mirror near the opening to see if it is getting hot & red..
Depending on what type of exaust line in the house.. If it is the type that goes to the roof - or a long path to the outside exit - it could be clauged.. Be sure exaust hose is not kinked..
Posted on Jul 08, 2009
I have a daewoo dwr-we3011rr dryer and want to be sure my heating element is bad and not another issue. dryer turns on and tumbles fine but has no heat.
Try to find someone who has an ohm-meter or a multi-meter and can take your machine apart and test the heating element. One that is working should show continuity through the element., One with a blown element should show no current flow through the element.
Be blessed.
Sep 23, 2013 | Daewoo Dwrwe3011ww Dwrwe3011ww Front Load...
Tip
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
on May 10, 2010 | Abbaka White Knight 38AW Electric Dryer
My white knight condenser dryer doesn't heat up anymore what do i need to replace?
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat is this video does not help go to our video section and there are a few on other condenser dryers
Mar 25, 2010 | Dryers
Have just bought a new heater element for a CL432AV White Knight Duel Heat Tumble Drier it will not heat think I have wired it up wrong do not have a wiring diagram can you help.
Feb 12, 2010 | Dryers
My white knight tumble dryer does not heat up,tried pressing the reset button but still does not heat up
you have a heating element burnt out. You will need to remove the back of the dryer and in the bottom of the dryer casing you will see the element Looks like a toaster element. Take model and serial # to an appliance parts house for replacement. An appliance tech shouldn't charge you that much to repair if you dont want to do it yourself.
Good luck hope this helped you some
Dave
Jan 28, 2010 | Dryers
The tumble dryer is working but not heating??? cleaned all filters and water tank. any ideas???
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter. In your case it is better that y ou call in an engineer to test it. Also overloading and blocked filters can cause the thermostat to cut out and they can also go with simple wear and tear. Check your service manual for spare parts etc
Jul 19, 2009 | Dryers
Dryer wont heat up on a aquarius VTD00, do you think its the element
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. . Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter. Also overloading and blocked filters can lead to thermo cut out, it is best to check your manual and call someone out on this occasion. You may even have a red reset button on the rear of your machine some models do, if yours doesnt then call out engineer :)
Jul 19, 2009 | Hotpoint NWXR473EV Dryer
Bosch wta3510us tumbling NOT heating. Reset button?
Remove your back cover ,and then you see the heating element.On one side or on top there is a termostat(Small Black)there is a red button which you should press down until you hear a click.Start machine and element should work.You can start it for a little while but be careful.Put cover back after cleaning loose lint etc. Jan
Jan 09, 2009 | Bosch Axxis WTA 3510 Electric Dryer
I have no heat from my hotpoint aquariur ctd20 tumble dryer
The element and stats are located behind removable panel at rear of m/c.
To test , you will need a multi meter set on the ohms range for continuity check., and you need to pull the wires of the components to get a proper reading.
THE M/C MUST BE UNPLUGGED prior to this check.
Check and clean all filters, remove the front bottom left filter, and clean by running under cold water.
Hope this helps.
Plz rate my solution
Thanks.
Dec 28, 2008 | Hotpoint Aquarius WD63 Front Load...
TDC 30 tumble dryer
To test the heating element you need to access it by taking apart the back panel, and test it for continuity using a multimeter.
There are also a couple of fuses/circuit breakers that you should test.
Entering the model number here you get the exploded view, and replacement parts.
Sep 15, 2008 | Hotpoint TDC32 Electric Dryer
Tricity Bendix TM220W Electric Dryer Logo
43 people viewed this question
Top Tricity Bendix Dryers Experts
Tim Whalen
TO Lady
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
