Question about Fujitsu ScanSnap fi-5110EOXM Pass-Through Scanner
Scanner jams with all kinds of paper. - Fujitsu ScanSnap fi-5110EOXM Pass-Through Scanner
    Problem Solver:
  • 10 Answers
You should clean the drive rollers. If that doesn't solve the problem, you need to replace them -- drive rollers are a consumable item on this scanner.
MyEfact
Posted on Jan 04, 2011
  • boydmcc Jan 04, 2011
    i tried cleaning the rollers and replacing the PAD assembly with no success. Scanner only has approx 2000 scans use. I was hoping that some adjustment of the pad would help.
    Looking for someone who had similar problems with this scanner. Always feeds multiple pages.
Please advise what you charge for solving following problem:\r\n"Paper jam on Brother MFC-260C:Following Brother User's Guide, I removed the Jam Clear Cover, and pulled out jammed paper, but got only...
1. Unplug machines power cord from the power outlet. 2. Lift the scanner cover using the plastic tabs, located on the left and right side of the machine until it locks securely into the open position. 4c89ecbe03c0173ae1000000cd8620c6.gif 3. Remove all of the paper scraps stuck inside the machine. NOTE: The print head can be moved manually with hand to assist with removing all of the paper scraps. 4c89ed1103c0173ae1000000cd8620c6.gif
4. Turn the machine around and open the Jam Clear Cover (1). Look inside the machine and remove any jammed paper. Then close the Jam Clear Cover (1).
5. After removing all of the paper scraps, Close the scanner cover by lifting the scanner cover to release the lock. Gently push the green scanner cover support down and then close the cover.
6. Remove the paper tray from the machine.
7. Place one of your hands under the LCD unit and into the opening of where the paper tray was.
8. Using your hand, lift the front of the machine approximately 6 inches off the surface.
9. Look inside the tray areas roof of the machine and you should see a row of black rollers. See picture below.
10. Look in-between each of the black rollers for a piece of stuck scrap paper. (A flash light may need to be used if you are having trouble locating the paper scrap).
11. Using a pair of tweezers, the paper scrap can be easily removed from the exit rollers.
12. Place the machine gently down onto the surface.
- If paper scraps were found and removed from the machine, continue to STEP 13.
- If no paper scraps were found inside the machine, the paper in the tray may be causing the issue. If the paper is slightly curled, the print head will catch the edge of the paper and tear it. To resolve the issue, the paper must be replaced.
- If you do not have replacement paper, follow the rest of this solution, after you have replaced the paper.
- If you replaced the paper, continue to STEP 13.
13. Put the paper tray back into the machine.
Dec 18, 2010 | Brother Office Equipment & Supplies
Had paper jammed - removed jammed paper - but nerror light still on
Before you can clear a "PAPER JAM" or "PRINTER JAM" error, you must locate where in the unit the paper is jammed.
First, unplug the machine for safety and disconnect the telephone line. Next, follow these instructions based on where the paper jam is located.
Paper is jammed inside the paper tray:
  1. Pull the paper tray out of the machine.
  1. Pull out the jammed paper to remove it.
  1. Reload the paper in the paper tray.
  2. Reinstall the paper tray.
Paper is jammed inside the machine:
  1. Remove the jam clear cover on the back of the unit. Pull the jammed paper out of the machine.
  1. Re-insert the jam clear cover.
  2. If you can not pull out the jammed paper, lift the scanner cover from the right-hand side of the machine until it locks securely into the open position.
  3. Remove the jammed paper.
  4. Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area.
  5. Gently move the print head to the center.
    Note Be careful to not force the print head to move.
    If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us".
  6. Examine under the print head. If anything is found, remove it.
    Note Use a flashlight if necessary to check thoroughly.
  7. Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
  8. Reconnect the power cord and telephone line.
Note To prevent paper jams, do not put multiple kinds of paper in the paper tray at the same time.
If the message continues to appear on the LCD, the machine will require repair. Please contact Brother Customer Service from "Contact Us".
Thanks for using fixya......
Oct 26, 2010 | Brother Office Equipment & Supplies
My Documate 152 is saying paper jam but no paper jam
E08 error message which indicates papert jam is caused by lose or mis-alligned input paper tray (automatic document feeder).
Resolve issue by powering off the scanner, opening the paper path section, removing the adf, and then re-seating the adf.
Mar 26, 2010 | Xerox DocuMate 152 Pass-Through Scanner
Scanner will not load from top feeder. Error says paper jam but no paper is jammed into the feeder.
the rollers may be broken, this would give the appearance of the paper jam to the printer
sorry not sure how to fix this one
Oct 09, 2009 | Visioneer 9450 Flatbed Scanner
Printer jam
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-10
Jul 21, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Scanner is not picking the paper
It is likely that your paper is the problem. Get some new or different paper and try again.
Jun 18, 2009 | Fujitsu fi-5120C
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
HP G85 PAPER JAM ERROR ,but still prints from scanner fine
Remove the rear cover...clean the rubber rollers with alcohol
Feb 17, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
E9 code
E9 code means there is a paper jam.
Clearing Paper Jams
Document Feeder, a warning dialog box opens after a few
moments.
1. Press the ADF cover release on the top-left of the scanner
body to open the Automatic Document Feeder cover.
To reduce the number of paper jams, smooth and straighten the
paper before scanning and adjust the guides to the paper size.
This should help. Please let me know if it does. Thank you, Binary Bob
Dec 04, 2008 | Xerox DocuMate 252 Path-Through Scanner
Fujitsu ScanSnap fi-5110EOXM Pass-Through Scanner Logo
119 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
