Question about HP Computers & Internet
I have just hooked up my computer after moving, and when I turn it on, my monitor says that there is no input???
  • shockusaf Jan 04, 2011
    my monitor still says no input, even after trying your suggestions??
  • 4,281 Answers
First make sure the vga cable from monitor to computer is connected properly.
Then when you power up the computer check the num lock led on key board .When you press num lock key if it is turned on and off then computer gives display to monitor then you need to change the screen resolution .
For that when you power up the computer press F8 key 5 to 6 times then enter in enable vga mode then go to display property settings and change screen resolution to 1024*768 then apply and ok.
But if num lock led stay constant when you press num lock key on key board then open cpu cabinet.
Then reconnect RAM memory reconnect both connection to harddrive Pull cmos cell from motherboard for 10 minutes then all settings defaults then check.Also make sure motherboard is not ground with cabinet.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Jan 03, 2011
Gateway fpd 1530says
If you see a message box that says "Power Saving Mode" after pressing the power button, then it simply means that the monitor/display is not detecting the computer. Check the connection/cable between the display and the computer and make sure your computer is not in standby mode by moving your mouse.
From what you stated in your problem, you dont need a inverter or a bulb. If you have any image like the message box displayed then its working fine. It just isnt seeing any signal changes on the input and therefore goes into power saving mde. Try another cable or hook it up to a different computer to check the cable.
Oct 16, 2012 | Gateway FPD1530 15" Flat Panel LCD Monitor
I want to connect my dell inspiron 1525 to my lcd hd ready tv but have no idea how to? Does anyone have any advice?
The 1525has a a hdmi port which you can plug a hdmi cord into. This may not support the audio. the tv and pc should detect the new monitor automatically or you may have to toggle it by hitting F4 key.
Apr 22, 2011 | Dell Computers & Internet
Moved computer to new location. rehooked all. monitor wont start
Without seeing your make or model on you monitor it is difficult to give you any advice.
But with that said.. If your monitor is a flat screen there is a power cord that plugs into the wall the cord is connected to a small box (power converter) out of the box is a small connector that goes into your monitor. It is small and you may have to turn you Monitor over to see exactly where it connects.
Your computer will work whether or not you have Internet service.
Sep 08, 2009 | Star Logic 17" LCD Monitor
Monitor issue
Just sounds like the monitor cable is loose or bad or the input mode on the monitor is set wrong - set it to auto or step through the modes.
Aug 10, 2009 | Envision H191W Monitor
Bought Samsung 2233BW Monitor, hooked the two plugs, power and DV1 cord started computer and switched on monitor, NOTHING HAPPENED. Silly thing just unhooked Samsung and hooked back up the AOC monitor no...
You might need to go into the monitor's setup menu and select the digital input. (That's DVI, by the way, for Digital Video Input, and not DV1.) Some monitors automatically detect the input but not all of them. Obviously, this doesn't apply if the Samsung has only a DVI input. It might also be necessary to tell the video card to turn on the DVI output. You can do this with your old AOC connected and use the video setting utility supplied with the video card.
May 22, 2009 | Computers & Internet
Hook up monitor speakers to PC?
how i hook up my JBL SPEAKER TO MY COMPAQ COMPUTER LOST MY DIAGRAM TO THE COMPUTER FORGOT HOW TO HOOK THE WIRE TO MY COMPUTER
Mar 18, 2009 | Compaq fs740 17" CRT Monitor
My computer is only 2 years old. I recently moved and hooked my computer back up yesterday. I turned it on and the monitor says no service input and automatcily goes into sleep mode. What do you think is...
The monitor is not detecting that it connected to a video card. You did not specify which computer model but if there is only one then you must ensure that the connectors are seated properly. If there is a built-in connector and a add-on video card connector also then make sure that the monitor is connected to the correct connector. When the computer is off there will be a yellow light indicator on the monitor and when the computer is booted it will turn green normally.
If you have another computer, even a laptop you can connect the monitor to that to ensure that the monitor is working and the cable has no bent pins at the connector therefore verifying whether the trouble is at the computer end or monitor. Please repost if you try these steps and still need help.
Jan 19, 2009 | HP Pavilion F1703 17" LCD Monitor
No signal
mine did the same thing...it was on rgb...didn't have ability to plug in computer to tv as suggested previously and I kept trying to hit input button on side of tv after turning tv on..didn't work but when I pushed input button before turning on tv when i turned on tv input screen was up and was able to move input to hdmi...everything works now.
Jan 04, 2009 | Vizio L32 32 in. LCD HDTV
FLOATING BOX WITH ATTENTION INPUT NOT SUPPORTED
Your monitor has several different video inputs.
Go to the configuration settings on your monitor and select the video input that matches the video cable from your computer.
Nov 12, 2008 | Computers & Internet
Computers & Internet Logo
516 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
