Question about Deadbolt Electronic Keyless System - Bright Brass
I have a Sclage Plymouth deadbolt lock system Model No. BE365PLY716. I do not have the key. I want to change the entry code. Can I do this without a key and if so, how?
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
The only man that can do this
is the one that you bought it from
all the others way are against the low and
can not be righting in this site
Posted on Jan 03, 2011
Can i purchase multiple keypad deadbolt with same key?
Yes, Thank you for your inquiry; At FactoryLocks.com we carry Schlage BE365PLY505. The key number is stamped on the key. You can purchase the same entry on our website, factorylocks.com with your existing locks key number. Enter the 5 digit key code on our shopping page that is on the key. We'll get it keyed and out to you quickly.
May 09, 2014 | SCHLAGE LOCK COMPANY Schlage BE365VPLY505...
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
Key turns freely in deadbolt, but suddenly won't engage the lock
get in a locksmith ( possible ******* entry attempt damaged the tumblers)
or
replace the lock unit
Nov 20, 2017 | Locks & Locksmithing
Schlage keyless deadbolt BE365PLY716 Will not unlock. We put in the code the light turns green we turn to unlock but it just spins like it isn't catching on whatever it needs to to unlock...help!!
Your problem sounds like an internal mechanical one. Schlage has a lifetime warranty against mechanical defects and a 1 year warranty on the electronics, if you are the original owner. Just so you know.
Here is the contact information for Schlage:
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Please contact them. Hope this helps!
Feb 05, 2012 | Schlage Locks & Locksmithing
I have the digital door lock, but the keys are sticking down and now the lock will not unlock using the code. I opened the back and tried changing the code. The tumblers will not fit into some the holes...
Contact Digital Systems at either of these numbers (located in Mount Pleasant, MI) for customer service:
(989) 773-2363
(989) 775-1411
http://lockeyusa.com/
email:info@lockeyusa.com
Aug 13, 2011 | Lockey Digital M210 Mechanical Keyless...
How do i rekey the deadbolt to fit the doorknob key?
You would need to take it to a lock smith or an ace hardware. also bring one of the doorknobs so they can key it alike. Unfortunately, keying locks is not something that you can do without advanced equipment and experience.
Aug 15, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Deadbolt Electronic Keyless  System - Bright Brass Logo
46 people viewed this question
Top Deadbolt Locks & Locksmithing Experts
jdthefixer
Bill Boyd
David Belitz
David Belitz
Are you a Deadbolt Lock and Locksmithing Expert? Answer questions, earn points and help others
