Question about Maytag MZD2752G Side by Side Refrigerator
I have Model number MSD2357HES side by sde. I am having a problem with my freezer and also the refridge side... freezer froze over only on number 4 setting and also did not make ice. Fridge side not as cold as it should be being set a number 7. This fridge is 5 yrs old stainless steel been ok thus far. I clean out the vents and the behind the vegtable and meat drawers. Now, my filter light is on so I no I need to replace it which I'm preparing to do. Can you help me?
  • 1073 Answers
SOURCE: Refrigerator - water liking under the meat drawer
defrost drain stopped up cleanout the drain from the freezer to the drain pan
Posted on May 07, 2008
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
NorseXNW
  • 8 Answers
SOURCE: A puddle of water is laying under vegtable and fruit drawers
Clean out the evap drain tube.
Posted on May 23, 2009
  • 1796 Answers
SOURCE: GE model pds18sbmarbs stainless steel
Hi!!
The evaporator fan motor is located right in between freezer and the fridge compartment on top of item #19. The fan motor can be accessed thru the bottom of the fridge. Click on the following link if diagram below is not clear enough and to get parts names. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5100598&diagram_id=22155726#d22155726
To get to the evaporator fan motor, you need to remove item #2 or items #14 & #15 on the graphic depending on your model, to access the evaporator drain pan, item #8, the fan motor is attached to the back of the drain pan.
If you haven't bought the replacement fan motor, you should order it from this site, it is about $30 less than if you order it from GE.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Nov 15, 2010
bobicehouse
  • 1524 Answers
SOURCE: Refridge is warm, freezer is working fine. There
This is known as the CZT or Climate Zone Technology fan and if you direct wire it and it does not run, replace.
This is the cold zone fan which supplies cold air to the meat and crisper drawers.
Posted on Feb 07, 2011
MAGIC CHEF REFRIDGE
What is the complete model number of your unit?
Dec 04, 2012 | Magic Chef Refrigerators
Side by side kitchen aide 48"
What is the model number of the unit?
Nov 12, 2012 | Refrigerators
Refridge. light went out. Bulb is good. Indicator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My maytag side by side refridge/ freezer gets cold in freezer unit(below zero) but only down to 50 in fridge
That tells me there is a blockage between the freezer side and the freezer side. Look inside the rear of the freezer for a layer of frost building up on the rear wall. If yes then there may be a defrost problem beginning to show. I also need your model number and I need you to look for a vent control on the temperature control panel. See if you can increase the amount of air flow to the refrigerator fresh food section. If not then there possibly is a blockage in the duct that comes from the freezer side. Possibly ice or a damper is stuck closed. You will need to unplug and remove the rear panel in the freezer to confirm this. Try to find your model number and let me know what you find. Thanks, Sea Breeze
Aug 25, 2009 | Whirlpool Refrigerators
Whirlpool side by side (106.56692501). Refrig was not cooling but freezer is. Freezer is slowly heating up though. Unit is still running. It just isn't blowing air into the refrigerator.
You have ice in freezer fins. You need to remove back panel inside of freezer, melt all the ice replace panel, plug refridge back in. The ice causes bad airflow to the refridge side, causing to heat up.
Jul 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag side by side. opened freezer ice buildup. refridge not cold. i hear a fan or motor on. but either side getting cold. turned up thermostat but nothing.
Is there any way you can find me that model number. I need to know that to be able to pull your model up and advise you if it has Adaptive Defrost, Defrost Timer Or a control Board. Thanks, Sea Breeze
http://appliancepartsandtechnicalservices.blogspot.com/
http://appliancepartsandtechnicalservices.blogspot.com/575f459.gif
Jun 17, 2009 | Refrigerators
Instruction manual needed.
You might find it at kitchenmanuals.online That is the web address and they have manuals for many different models of the Amana side-by-side refrigerator.
Jan 25, 2009 | Amana Refrigerators
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Cooling coil in freezer compartment froze up
id say your right the unit should defrost for 30 mins of every 8 hours of compressor runnig time now that's not normal time because the thermostat cuts the unit off and on every now and then . the timer for defrost measures how long the compressor runs and it varies with how often the doors are open im sure parts of your defrost system are inoperative send me an e mail with your model number and i will help b4829@yahoo.com
May 26, 2008 | Jenn-Air JCB2388G Side by Side...
Maytag MZD2752G Side by Side Refrigerator Logo
57 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
