Question about Ricoh Aficio 3025 All-In-One Laser Printer
Scanner to e-mail
I have a 3235c all in one. when the scanner goes to e-mail me the image it doesn't do anything for about 5 minutes, then gives me this error:
Check the status and connection.
To check the current status, press [scanned files status].
so i checked that, and it has files sitting there going back months all of which say error, but it won't let me see what the error is.
any thoughts would be great.
  • Anonymous Nov 19, 2008
    get error when scanning to email
That USUALLY means that the scanned files is too big or the email settings for smtp server is not set properly. Try just scanning in one page and see if you get that same error. If so try checking the email smtp settings on the unit itself.
Posted on Apr 07, 2009
  • 58 Answers
Its not connected properly, you need to check destination, passwords, users names etc.
http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 23, 2009
Solid black image on Ricoh 3235C
Check exposer lamp to see if it comes on first. try printing counter report if same problem. Then could be drum unit or not getting a charge to roller on drum. then board could be bad.
Jan 26, 2014 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
White spots on scanned images
First thing you should do is to check whether the original image is clean and no dust or anything.
The next one is to clean the scanner glass. Use a clean cloth to wipe the scanner glass to make sure there is no dust or anything that might reflect the light from the scanner that can cause white spots.
Please give us update regarding this issue.
Thank you,
Jack
Feb 17, 2011 | HP PSC 2410 All-In-One InkJet Printer
Code u1040 03 pontiac gp
Hi, if you are receiving a u1040 code ,the car needs to be put on a good scanner to see which module is not communicating this includes the pcm-ebcm-bcm-sir/sdm-ipc-radio and the pass key 111, you need to check the battery hots, ignition hots ,grounds and serial data lines to each module if the scanner cannot communicate with any of the modules, the serial data line will have a very low amount of voltage and will be moving between low voltages check all the fuses and relays battery connections and grounds, the ignition relay is a good one to check, also for the antitheft reprogram relearn there is a 30 minute relearn process ;;try to start the vehicle and release the key do not turn it off wait ten minutes until the security light goes out then turn the key off for 5 seconds and turn the key back on wait 10 more minutes for the light to go off again turn the key off for 5 seconds and then back on for 10 minutes more after the light goes off turn the key off for 5 seconds and now try to start the car, if it still doesn’t start then check for any connections under the hood for water damage or critter damage.
Take care
Aug 06, 2010 | 2003 Pontiac Grand Prix
Hp scanjet 8250. I want to set my scanner to default to PDF when I am trying to email. That is the way we do most of our scanning and right now it defaults to RTF.
Have you considered simply scanning from within Adobe Acrobat or similar software that produces .pdf and then use the email feature within Acrobat?
As I look over the HP User Manual, I can't see any method to set the default output. It simply says...
Use the E-MAIL button() to scan documents or pictures and insert them in an e-mail message as an attachment. You must have an Internet connection and a supported e-mail application.
1. Place the original face down on the scanner glass or face up in the ADF. If you are scanning two-sided originals from an ADF, slide the DUPLEX switch to two-sided mode.
2.Press the E-MAIL button().A message appears asking if the original is a document or a picture.
3.Select Document or Picture, and click OK.Note:A preview image will not appear when scanning from the ADF. To change this preview setting, see the HP Photo & Imaging software Help.
4. Select the final scan area (the area inside the dotted lines) in the preview image.
5. Make adjustments to the preview image if needed.
6. Click Accept.The final scan area is scanned and your e-mail application is opened. The scanned image is added as an attachment to the e-mail message.
7. The Save As dialog box appears. Type a file name and choose a file type, and click OK.
8. Complete the e-mail as usual.
Aug 07, 2009 | HP Office Equipment & Supplies
Code error ffff:0024
While I am trying to scan the images, I am getting the error Code[ffff:0024] & I am unable to scan anything from Epson 1500 model. While I switch on the scanner, it sounds lot from the scanner for continuous 2 minutes. I couldn't get scanned anything ... please
give me the solution.
Mar 30, 2009 | Acer Scan to Web 3300U Flatbed Scanner
How to scan documents then email them
To scan and send the documents via. e-mail. First of all you must run the setup from the cannon cd (comes with printer), use full installation (recommended option) complete the installation.
If this is already done then :-
1] Put the document that you want to scan in the scanner,
2]Open "control panel" and open "scanners and cameras" folder. (switch to classic view if needed)
3]Switch on the printer (if it's on only then proceed to next step)
4]You will see your scanner icon (if necessary refresh the screen)
5]Open it and click "next"
6] (OPTIONAL) Select scan image type.
7]Click "next".
8]Choose a place to save your image.(default is my pictures)
9]Click "next"
10]and now image scan starts, at last click on finished.
11]Now open your e-mail account, choose "compose mail" fill in the details
12]now select "browse" (for gmail) or select upload file
13]select the address of the image where you saved it (default my pictures)
14]click ok.(you can only upload 1 file at a time)
15]send the mail. !!
16]Thus, you can send image by scanning like as stated above .
Jan 07, 2009 | Canon PIXMA MP130 All-In-One InkJet...
I have an HP 4570c Scanjet that suddenly started scanning images distored with a blue yellow tint and streaks running through the page. I have tried all the "homing" fixes (shut down everything,...
This is driving me nuts, too on my HP d135 multifunction. I hate to give up a working (albeit old) printer/copier/fax because the color scanning goes, but I haven't room for a separate scanner.
Would love to know the fix for this.
Dec 09, 2008 | HP Office Equipment & Supplies
Ricoh Aficio 3025 All-In-One Laser Printer Logo
364 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
