Question about Samsung HLT6176S Television
I have a samsung tv HLT6176SX/XAA and I do not have cable however I was able to get a few channels. One day I went under the menu button on my remote to the channel settings to try and get more channels, I don't remember wht I did but now I don't have any channels. HELP
SOURCE: Samsung lcd faults
Found this on FixYa and it worked:
I had a similar problem and the way to solve this is to reset the set from the remote. Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Peter
Posted on Apr 06, 2008
  • 4 Answers
SOURCE: Samsung LE26R Digital Frozen
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Posted on Jun 10, 2008
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
SOURCE: Retuning digital TV
You need to use the (what looks like a large sattellite) button to retune your tv.
Some Samsung tv's let you access the button but other models have a "D MENU" button on the remote. Press this button, then scroll down to the icon that looks like a large sattellite. Then scroll across and click on "Auto Store" this will then go through all the available channels
Posted on Sep 30, 2009
57 varieties
  • 1653 Answers
SOURCE: samsung le26r74bd won't retune digital channels
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Posted on Oct 02, 2009
I bought a used samsung t.v. and the remote don't work. its got new batteries but don't work it might be a samsung universal remote do i need to but my t.v. code in it. how do i do it and what is...
Hello
Three digit universal remote codes to check with Samsung tV are:
004/ 005/ 009/ 015/ 104/ 105/ 106/ 109/ 133/ 172
Four digit codes are:
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jul 26, 2011 | Samsung TV Remote Control
My wife thought it was hooked to a cable box for high number channels and pushed 707 on the remote TV sig went out. TV powers up but no menu no signal just a power light and the background is on but no...
Hello
have you tried pushing 003 on the remote or the AV buttons?
All I can think of is that you must the get tv BACK ON the right channel or AV Input.
Hope you have a better day
Nov 25, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I Have a Samsung flat screen ser# LNS4692DX/XAA that video went out and went to dark blue on all channels,still have good audio but cant even get a menu screen any suggestions?
Unplug tv from wall socket for minute to get it reset, replug back in and turn it On
Do you get Menu screen now or tv shows channels?
If problem still not solved then let me know how old is this tv and any related info about problem like storm or lightning in area that caused this problem in tv. Does tv show picture in dvd playback?
Thanks.
Nov 04, 2010 | Samsung SPN4235 42 in. Plasma HDTV
TV only works on HD stations
Your TV has an SD/ED component input and an HD component input. You are using the HD input. It can only accept HD signals. You need to correct the settings in you cable box. You need to "fix" the video output so that it converts everything to HD. If you have a motorola box, you can usually turn the box off and press the menu button to access the cable box setup menu. Set the 4:3 override to Stretch or Full. If you need more help with this, post back with more information: cable provider, cable box used. I hope this was of some assistance.
Mar 28, 2010 | Samsung DLP HL-P5663W 56" TV
Verizon fios remote codes for samsung receiver
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
Feb 20, 2010 | Samsung Audio Players & Recorders
SVA television. Have model # EV1703 Remote no
When you say the remote doesn't get the channels I have to assume the channel entry behavior changed. I am not to familiar with this brand but these are the basics for most tv's. If you have not removed the cable input to the tv or unhooked anything before the problem started here are a few thing you could try. Push the menu or setup button on the remote and under the channel or setup option on the tv make sure it is set to Cable and not Air or Antenna. Run the tv through the auto channel search to reprogram the cable channels. This process can take close to 1 hour on some tv's since it has to scan through the digital and analogue tuners. This will allow your tv to add the correct cable channels and remove the unwanted ones. You should be able to enter the channel number or move up and down with the channel buttons on your remote.
Dec 10, 2009 | SVA-USA EV-1703 17 in. LCD Television
I have purchased a Samsung V 375 - it says it automatically tunes in and installs itself - trouble is I can't get the TV to display the signal by manually searching through mhz channels - I have the rellow...
Forget the mHz channels for now.
On the TV, or TV remote, look for a button that is labeled "Input" or "Video" or something like that. Depending on your TV, there might be a few choices that present themselves once you do this, such as "Video 1", "Video 2", etc. Keep going until you find what looks like the DVD player signal.
If there is no button as described, then look for another button on the TV remote or on the TV labeled "Menu". Then scroll thru the menu until you find "Input". Choices here might be "Cable", "Antenna", "Video". You'll want to choose "Video", or "A/V", or "Line".
Let me know...
---axoplasm
Nov 02, 2008 | Samsung Televison & Video
Daewoo DVN-14F6N
Same problem...Went to Goodwill Store, they usually have a large basket of remotes. I found a Daewoo remote for a TV only, HOWEVER on the bottom it has a AIR/CABLE button. The remote doesn't say Daewoo on it only..."Remote Controller R-25B03". The rest of the button of course work with the TV portion of the DVN-14F6N.
Sep 17, 2008 | Daewoo DVN-14F6N 13" TV
Hitachi F361 VCR Digital Auto Tracking (not 631!)
I had the same problem when I got the TV from someone and I didnt have a remote. I went out and got a ONE FOR ALL remote and once I got it set up I had it in VCR mode and hit the AV button and now I can get to the channels. Hope it works for you.
Oct 31, 2007 | Hitachi VTFX631A VCR
Televison & Video Logo
62 people viewed this question
Henry  Thomas
Henry Thomas
