Question about Panasonic KX-T7633 Corded Phone
Transfering calls I cannot forward calls to other phones in the office when an external call is ringing in. All other extensions become busy and other people have to pick up the line ringing in.. How do you solve this problem
  • troy_2005201 Sep 07, 2008
    i failed to transfer phone calls to other phones
    Scholar:
  • 38 Answers
It sounds like your dealer didn't properly set up incoming call distribution groups. They probably just gave you the "default" settings and left you a manual, took the check and said, "Good bye, and good luck!"
I think you mean transfer instead of forward. Your incoming calls should go through an Incoming Call Group - even if you're the only person in the group. Then you can handle the calls as they come in, transfer them out, and if you run out of buttons the system can even queue the calls up until you can get to them.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Posted on Oct 14, 2008
I have put a main greeting on my Norstar M7310 phone for all 5 incoming lines, however one of our incoming lines has grabbed a personal message form another extension and callers get that personal message...
You need to know what extension is causing the forward directly to voice mail. Chances are that this extension has ringing lines programmed to it and the forward on busy is to voice mail. ANY PHONE THAT HAS RINGING LINES SHOULD NOT BE SET TO FORWARD ON BUSY. If they happen to be on the phone when a call comes in it will go straight to their personal mailbox.
Aug 09, 2013 | NorStar M7310 Phone
How do i forward calls to an outside line on Nortel M7324
You can forward an extension that is not used at all, and has the lines assigned to ring that you want to forward to an outside number. In programming have the extensions set to forward on busy to the external number using 9+ the number desired. When you leave for the afternoon, take the handset off the phone, and replace it when you return. NOTE THIS EXTENSION MUST NOT BE USED BY ANYONE -- IF THIS EXTENSION IS BEING USED AND A LINE RINGS IN IT WILL BE FORWARDED OUT.
Mar 19, 2013 | NorStar M7324 Telephone
Want to assign another extension to access another extensions voicemail box on a Norstar CIS system
Configuration/Sets/BBB/LineAccess/LineAssignment:
Assign the Line XXX to BBB as Appear and Ring or Ring Only (on intercom key)
Now the line rings on both sets
Administration/Capabilities/Sets/ AAA & BBB:
-Change AAA\'s Forward No Answer Ring count to 4 rings
-Change BBB\'s Forward No Answer Ring count to 3 rings
-Obviously make sure the Forward No Answer is pointing to the DN of the voice mail system on both sets
-Make sure Forward Busy is set to Non on both sets
Because the ring count is shorter on BBB all calls will dump in the mailbox of BBB
Nov 30, 2012 | NorStar M7324 Telephone
At my office when we have more then 2 calls come through on an extension line, the 3rd caller gets auto directed to general mailbox...can i change this? would like private calls to stay at correct number...
Check Forward Busy under Capabilities in programming, any phone that has lines ringing this setting should be set to NONE.
Also make sure line 3 is assigned to ring at those phones.
If unsure of programming the phone system or password call your local tech to come in.
Nov 27, 2012 | NorStar M7208 Corded Phone
The Panasonic KX TA824 system phone How can I make that when somebody is on the corldess phone that is connected to the system Lets say extension 105 when a call comes in to extension 105 I should not get...
On an 824 you only have one option, call forward busy/no answer. It means all calls transferred to that extension would go somewhere. Since an 824 has no ring groups, you can't make the system do a double hop (CF busy to 101 and if 101 is busy CF to something else) but at least it's something.
From the cordless, dial 712 1xx # with xx being the extension of the forwarded number. (710# cancels).
Carl
Oct 31, 2010 | Panasonic KX-TA824PK Phone
Voicemail is not picking up for incoming calls...
Sounds like you need to set the call forward no answer to the VM pilot DN for the set with the new mailbox.
May 26, 2010 | NorStar Startalk Flash 2 Phone
I bught a kx-ta824, I just have one CO line and i want to put 4 extensions , but i couldn't. I can just recive 1 call and then the line sounds busy.
With one CO line you can only make or receive one external call at a time. You can have extensions connected on intercom calls, but once your CO line is in use, anyone calling in will get a busy signal, as will anyone in the office trying to make an outside call. You'll need additional CO lines if you want to have several outside calls going on at once.
Apr 10, 2009 | Panasonic KX-TA824PK Phone
How do i redirect calls to another extension?
I missed your mentioning voice mail, so I guess that means you don't have it.
On your phone you have a FWD/DND button. It's programmed by dialing forwarding codes into the intercom, then the button is used to turn the featores on and off.
The code is *710x destination and maybe # where x=2 for all calls, 3 of busy, 4 for no answer and 5 for busy/no answer. When it's set, the light should be on solid. Pressing the button will make it go out and cancel FWD. You can set different forward destinations for busy and no answer.
You can also have different locations for intercom or outside calls. Those codes are in the TDA Users's manual.
Carl
Jan 07, 2009 | Panasonic KX-T7630 Corded Phone
Call forwarding to outside line
To send a call to another telephone within your system, or to an external
telephone. You may not be able to transfer a call on an external line
to an external telephone, depending on the capabilities of the lines.
1. Make or answer a call.
2. Press the feature button then press 70.
3. Call the person you want to transfer the call to.
4. Stay on the line if you wish to speak to the person first.
5. Press the Release button to complete the transfer.
If an external call is transferred to a busy internal or network
extension, or is not answered after a few rings, the call automatically
rings you back.
Sep 24, 2008 | Nortel T7316E 2-Line Corded Phone
Forwarding calls between extensions
Yes, press Feature 4, then enter the extension of the line you wish to forward the ring to. You can also go into the phone configuration to forward after a set # of rings. To ring another extension at set times you will need admin access.
Jul 02, 2008 | Nortel Meridian M7208 Corded Phone
Panasonic KX-T7633 Corded Phone Logo
234 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
