Trutech vhs and dvd rw
I have lost the instructions and need to know what to do to the dvd after recording a vhs tape to be able to play the dvd on another player.
    Genius:
  • 1,550 Answers
Go to http;//audio.manualsonline.com maybe there you find it.Good luck.
Posted on Jul 09, 2008
How do I finalize my disk once I have finished recording from VHS tape. How do I get the finalize to light up on menu on screen?
If they are +RW discs they cant be finalized and can only be played on +RW compatible players. Use +R, -R or -RW if you need a wider compatibility (DVD-VIDEO). Finalizing is quite easy following directions in the manual.
Apr 20, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
Using a JVC /DVD/S-vhs dual dubbing Deck model jvc sr-mv55u Trying to do a straight dub from an edited S-VHS tape to a formated for video DVD for archival library. I am following the instructions in the...
now days dvd player comes with advace tacnoloy
u not need make vedio dvd u make to your dvd as a data dvd & dvd plyer read it isely so dont need to do vhs or vcd
Mar 29, 2008 | Televison & Video
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
DVD player will not read any discs.
> I tried recording a VHS to a DVD according to the instructions in the manual.
There can hardly be instructions in the manual to do this since that model is not a DV Recorder, but if it isn't reading any DVD then you have a warranty problem assuming your unit is still within the warranty period.
That unit is capable of recording DVD content to VHS tape but not the opposite.
Mar 13, 2010 | GoVideo DV2130 DVD Player/VCR
Vhs tapes recorded to DVD+R's
try forwarding the tape to the end and then rewind to the start again, this can help to seat the tape correctly on the spindle . the audio track part of the tape is in a specific region on the tape so misalignment may be the issue with those cassettes.
also try to press the tracking up and down when playing the video
May 12, 2017 | Televison & Video
Toshiba D VR660KU DVD VCR combo
The unit will only allow 2 hour recording on the DVD+R format. The DVD-R format is adjustable for longer recording time, just understand that the longer recording times = the lower the quality of the recording.
Jun 01, 2008 | Toshiba D-VR4 DVD Recorder/VCR
VHS record to DVD
Insert the VHS and rewind or fast forward to the point you want to begin copying from.
Insert the disc you plan to use and format it if necessary. It will usually prompt you if it is necessary to do so.
Put the television on the channel or input needed to view the recorder on-screen.
Select the DVD drive and set the record mode you prefer - XP, SP, LP or EP.
There are two things you can do:
1. Press and hold the dubbing/copying button on the recorder itself in the direction of the DVD for 3 seconds. If you are using a DVD-R/RW or +R you will receive a message stating to press Play to record without finalizing or press Record to record and finalize. If you are using +RW or -RAM, these cannot be finalized - therefore this message will not display.
2. You can access the Functions menu and go to Copy, then select the copy direction VHS to DCD and select Start Copying.
Apr 01, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Recording dvd from vhs
you may not need a remote to dub a vhs tape to dvd.
look on the front of the recorder. see if there is a arrow showing dubbing vhs to dvd/ dvd to vhs. since you do not have the manual, you'll probably have to play around with it a while to figure it out. you will also need to know which format the dvd will record on. [dvd-r,dvd-rw,dvd+r,dvd+rw or ram] you can look up your recorder brand & model # online, then search for a manual you can download.
good luck.
wg
Feb 13, 2008 | LG RC797T
Pause Protected
dbronx,
You might try unplugging the unit for several minutes in an attempt to reset the logics from ROM... TruTech is just one of those WallyWorld/Target specials that have very little support and breakdown frequently.. If I might suggest, it sounds as though you haven't had this unit long - take it back and get your money for it and go out and get a major player in the market. At least when it breaks you can more easily get some support...
A lot of these off-brands we get in here for repair just aren't worth the time and effort to repair and you would be surprised how many brands there are...
Bill
Nov 16, 2007 | TruTech T650-DR DVD Recorder
I have recorded (on to dvd-rw) my old VHS tapes. They won't play on computer
The PC requires a compatible DVD player software! What are you trying to play the DVD with?
Sep 28, 2017 | Hitachi DV-RX5000U DVD Recorder
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
Electro Med Services...
